Old 12-30-2013, 05:52 AM   #1
pcnutz's Avatar
Trader Rating: 18 (100%+)
Send a message via ICQ to pcnutz
Default shock options for rc10l4o
I got the old shocks that require the kit just to change oil. I forgot its been so long getting back into carpet, could you use either tc or buggy shocks on the sides? Or if you know another affordable solution. pls lmk thanks. JJ
pcnutz is offline   Reply With Quote
Old 12-30-2013, 06:08 AM   #2
Either the IRS or older CRC shocks would work. Same internals as the shocks that you have, but the shock bodies have a screw on end cap instead of that annoying little star clip. You should be able to order just the bodies and end caps to convert over the shocks that you have.
Serzoni is offline   Reply With Quote
SEO by vBSEO 3.5.0
