Old 07-16-2005, 02:36 AM   #1
pro4racer's Avatar
Default cleaning bearings
just wanted to give my bearings in my pro4 a good clean ive bought trinity royal oil to re-oil them but was wondering whats the best product to soak them overnight in.
i was thinking WD40 or motor cleaner
any other ideas will be much appreciated
pro4racer is offline   Reply With Quote
Old 07-16-2005, 05:05 AM   #2
nw racer's Avatar
I just spray mine out with motor spray, then oil them up and make sure they spin free with no noise in them.
nw racer is offline   Reply With Quote
Old 07-16-2005, 05:29 AM   #3
DIMO's Avatar
Default FUEL
DUde, soak em in RC nitro fuel or 2 stroke lawn mower fuel itll clean em goooood. Then soak em in the Royal i leave em doused for min 12hrs i know its pointless but hey. If you want ultra free spin use micro lon. My $.o2
DIMO is offline   Reply With Quote
Old 07-16-2005, 04:59 PM   #4
DORIFT's Avatar
I open up the metal shields on bothside of the bearing.
Sprayed out all the dirt/grit once you can see inside the bearing as there are lots hiding inside with some CRC products.
Lube the bearing with "Team Atlas RESPO E.P.O" bearing oil. Close up the sheilds and ready for action.
I tend to open up the bearing to lube them inside once everymonth. Else for general maintenance, I do them after every use by just spraying them and lube them with out opening them up.
DORIFT is offline   Reply With Quote
Old 07-16-2005, 07:20 PM   #5
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
be carefull with some cleaners.. some cleaners are very agressive, and can pit the metal and cause corosion.. Ive had it happen twice.. it usually wrecks the bearings if they sit to long...
the best way i have found, is to soak them in motor sparay for a few minutes.. then i use an air compressor to forcefully blow them out.. this has worked very well for me.. i dont have to take the seals off anymore either..
HERE IS MY TRADER FEEDBACK ON HOBBYTALK. http://www.hobbytalk.com/bbs1/itrader.php?u=8257
burbs is offline   Reply With Quote
Old 07-16-2005, 09:06 PM   #6
Steve Bahnatka's Avatar
Send a message via AIM to Steve Bahnatka
to get your bearing clean buy the rpm bearing blaster. works great . after cleaning make sure you lube 'em up.
Steve Bahnatka is offline   Reply With Quote
Old 07-16-2005, 09:38 PM   #7
jeepnyy's Avatar
I use Ultrasonic jewelry cleaner with wd30. But I've heard that kerosene is better to use with the ultrasonic cleaning machine. I also use Zubak speed lube after cleaning.
jeepnyy is offline   Reply With Quote
Old 07-17-2005, 09:23 AM   #8
pro4racer's Avatar
hi i just bought the eagle wave cleaner.
what is the best liquid/solution to use in this piece of equipment.
Old 07-17-2005, 09:45 AM   #9
Default Cleaning bearings
I keep small glass food jars around so that I can fill with cleaning solutions, recap, and save for use again. I also use coffee filters to clean fluid some before reusing it. I like using brake cleaning fluid, I just spray into small jar, 4 oz or so size, and place bearings in it and shake around. I will use another jar to clean a second time to be sure all grease, dirt, residue is removed. You can also use laquer cleaner, even automotive engine cleaner. After cleaning bearings then blow out with compressed air or allow to dry on paper towels. Be sure to remove shields to insure that all dirt is cleaned out.
I just bought an ultrasonic cleaner at Habor Freight on sale for $25. I also bought some liquid ultrasonic cleaner from jewelry department at Wal-Mart to use in ultrasonic machine.
After cleaning bearings, I re-oil with Mobil 1, or I use grease, depending on the application, whether its for on-road or off-road. I prefer grease in off-road bearings because it will help seal the bearing to prevent dirt from entering. Oil is preferred in on-road bearings to reduce rolling resistence as much as possible.
John Patterson is offline   Reply With Quote
Cleaning Bearings ~AR~ Gizmo Electric On-Road 12 06-13-2007 06:28 AM
Car cleaning and bearings. simon_allen Electric On-Road 6 03-07-2007 07:29 AM
Cleaning bearings offroader Electric On-Road 18 08-28-2006 07:25 PM
Car Cleaning, Bearings? Fervidsea Electric On-Road 11 02-08-2006 03:43 PM
Cleaning Bearings mtc3od Electric On-Road 12 11-18-2004 09:00 AM
SEO by vBSEO 3.5.0
