Old 01-24-2014, 09:18 AM   #256
howardcano's Avatar
Trader Rating: 35 (100%+)
Originally Posted by wwddww34 View Post
I compared the rubber tire sizes on my F104 and F103 cars and here's what I found...
None of these tires would meet the USLMP Rule for 50 mm Max tire diameter. Maybe the Tamiya Mini Tires would be small enough, but it would be impossible to lower the rear axle far enough to accommodate such small tires.
The rule is: Max WHEEL diameter 50mm.
That's the rim, not the tire.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 01-24-2014, 09:21 AM   #257
wwddww34's Avatar
Trader Rating: 9 (91%+)
My bad. Thanks for the clarification on that rule. I get the words "wheel" and "tire" mixed up often.
That being said it looks like the F104 wheels will work just fine since the wheel diameter is 44 mm.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 01-24-2014, 09:37 AM   #258
howardcano's Avatar
Actually, the full-scale LeMans organizers refer to the tires as the wheels! I was entertained when I read the real LeMans rules, because I thought that a 28 inch rim sounded a bit big. I think something was lost in the translation.
Howard Cano
Old 01-24-2014, 10:12 AM   #259
nrtv20's Avatar
Originally Posted by JLock View Post
So, with the new bit of information coming to light, it looks like the tire rule needs to be re-evaluated.
As of right now foams are the rule; rubber tires are still being evaluated.
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 01-24-2014, 10:34 AM   #260
robk's Avatar
Trader Rating: 22 (100%+)
F104 wheels won't work as the offset is wrong. Tamiya's wheels for the prototype cars they were selling ( nissan, castrol jag, sauber mercedes) would be almost perfect but they do not make them any more. So right now we are stuck with foam.
Old 01-24-2014, 01:26 PM   #261
wwddww34's Avatar
So if I have an old Tamiya F103RS chassis with a Toyota TS020 body and a set of Pit Shimizu 0544 fronts and 0542 rear tires mounted on F103 rims, would it meet USLMP Specs?
Old 01-24-2014, 08:47 PM   #262
Ed Delgado's Avatar
The only issue might be the tail of the body. From what I understand of the rules you cannot have a wedge style tail.
Ed Delgado is offline   Reply With Quote
Old 01-25-2014, 01:02 AM   #263
wwddww34's Avatar
I don't see what you mean by "wedge style tail." Here's a pic of the Tamiya F103 with Toyota TS020.
Old 01-25-2014, 06:18 AM   #264
Norman2's Avatar
Hi, Your Toyota does not have a wedge wing. Attached photo of what he means.
Regards
Norman2
LeMans LMP1: 200mm Pan Class Discussion-pan-car-wdge-wing.jpg
Norman2 is offline   Reply With Quote
Old 01-25-2014, 07:00 AM   #265
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Norman is right...I think what the rules mean is more of a continuous shape through the rear of the body. the TS020 you posted has an open shape
trackdesigner71 is offline   Reply With Quote
Old 01-25-2014, 07:11 AM   #266
howardcano's Avatar
"Wedge" tail:
Non-"Wedge" tail:
Howard Cano
Old 01-25-2014, 06:15 PM   #267
topdrag's Avatar
OK took the new car out today had fun, Question I ran the tires as they came and the car started hoping thru the sweeper. Do we cut these down? whats the fix? thx ahead of time
topdrag is offline   Reply With Quote
Old 01-25-2014, 09:13 PM   #268
robk's Avatar
Cutting them down will help.
Old 01-26-2014, 07:22 AM   #269
topdrag's Avatar
How much? and is that my only option? Thx. how's the rubber tire search coming?
Old 01-26-2014, 08:13 AM   #270
"Wedge" tail:
Non-"Wedge" tail:
Some of us(me) are not that talented to cut the "wedge" out and remount it.
RoyU is offline   Reply With Quote
