Old 01-22-2014, 09:09 AM   #211
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Originally Posted by Pro10noob View Post
What did you do to get it to accept the SP wheels to fit?
Use a Tamiya style rear axle and front steering blocks?
Do you have pics of it?
Regards Roy
Im sure howard will post his findings once he is finished
trackdesigner71 is offline   Reply With Quote
Old 01-22-2014, 10:24 AM   #212
Rick Vessell's Avatar
Regards Roy
On my WGT conversion I bored out the rear bearing inserts to fit metric bearing and used a F104 axle assy. For the front I drilled mounting holes 5mm inboard for the front suspension to get the width right. I used the SAE bearings as they fit the wheels with only minimal play.
I am running F103 wheels and rubber slicks from Pit currently. Haven't tried bolting up the SP foams to see if the offset is similar.
Originally Posted by howardcano View Post
Reposted in this (more appropriate) thread:
Looks good. Gives us another modern choice for the WGT chassis cars.
Rick Vessell is offline   Reply With Quote
Old 01-22-2014, 10:42 AM   #213
Pro10noob's Avatar
Perhaps a silly question
Can't you use the F103 or F104 steering blocks?
Or the one form the 3racing F109?
You can use the metric bearing then
Also Speedpassion rear axle and the 3racing F113 rear axle are inch size and they can accept the centre nut wheels.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 01-22-2014, 10:46 AM   #214
Regards Roy
Just built it with what I had on hand. I also wanted to see what the minimal work required was for others who wanted to try it but didn't want to spend for parts.
Old 01-22-2014, 10:53 AM   #215
Pro10noob's Avatar
@Rick.......Good point
Use what you have on the shelf
Regards Roy
l===/o\===l
Old 01-22-2014, 01:56 PM   #216
wwddww34's Avatar
Trader Rating: 9 (91%+)
This topic has caught my attention since "USLMP" was added to the same page that USVTA and USGT rules are located --> http://www.usvintagetransam.com/rules/
I have been participating in USVTA and USGT races for the last 2 years. I have also been racing 1/10 scale rubber tire F1 at my local track. This topic sounds like I could put a really cool Le Mans body on my Tamiya F104 and *WaLa* I have a USLMP car.
I just need clarification on one rule: Max wheel diameter 50mm. Why?
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 01-22-2014, 02:10 PM   #217
Im not Rick but my guess is that it is to keep with the relatively scale look. With tires for the LM1, at least rubber tires, not currently available it allows for more tire options until those tires can be had comercially
Old 01-22-2014, 02:11 PM   #218
liljohn1064's Avatar
Trader Rating: 17 (100%+)
The LM-1 Tires/Rims are those dimensions and the current spec. They are premounted foam. That's why the the obscure notation to the future rubber tires: They don't exist yet.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 01-22-2014, 02:15 PM   #219
Oh, uh... heh, heh... oh. That's NICE!
Old 01-22-2014, 02:21 PM   #220
You can pretty much drop an LMA body right on an F104 or similar wheelbase! The F103 will be short. The SP LM-1 tire set is a direct fit to any metric Tamiya F1 clone; 5mm front axles and 14mm rear hexes.
Old 01-22-2014, 03:51 PM   #221
snoopyrc's Avatar
http://www.redrc.net/2014/01/team-mu...ll/#more-76345http://www.redrc.net/2014/01/team-mu...ll/#more-76345
Does this change anything?
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 01-22-2014, 04:10 PM   #222
Manny's Avatar
Those look great! Sports Prototype bodies always fit pan car chassis better than GT bodies. Team Muso have more stuff on their website
Manny is offline   Reply With Quote
Old 01-22-2014, 06:34 PM   #223
Just make sure to switch the front wing for a front bumper on any F1 chassis
Old 01-22-2014, 07:44 PM   #224
mikel33's Avatar
Trader Rating: 2 (75%+)
I'll be honest, after watching the race this weekend with Rick and the others I think the foams are the way to go, at least on carpet. Perhaps outlaw truing them down past some meaningful diameter.
Michael Larson.
Village Idiot Racing - Now accepting driver applications.
mikel33 is offline   Reply With Quote
Old 01-22-2014, 08:19 PM   #225
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
I agree keep it with foams for Carpet IMO.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
