Old 06-05-2014, 08:57 AM   #181
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by OfnaJoe View Post
When I downloaded the 2.0 on my verizon ellipsis 7 tablet it says can't open file. Any ideal what's wrong?
Does this tablet support OTG ? Have a link to it's model?
Something about winning attracts losers with opinions......
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, B-fast, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 06-05-2014, 02:01 PM   #182
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
It might not, couldn't find it in the spec, here's a link to it:
http://www.verizonwireless.com/b2c/d...is-7?&zipRdr=y
Mugen Seiki \\ Dialed RC \\ Tekin \\ SMC \\ AVID\\ AKA \\ Futaba
OfnaJoe is offline   Reply With Quote
Old 06-05-2014, 03:24 PM   #183
Team Tekin
Randy_Pike's Avatar
Yeah they list nothing about it.
You can use some of these free tools to see if the device does indeed support OTG. Use at your own risk though.
https://play.google.com/store/apps/d...tgtroubshooter
https://play.google.com/store/apps/d....usbotgchecker
When you plug in your HW does the green led light up?
Old 06-05-2014, 03:40 PM   #184
OfnaJoe's Avatar
Light is green, And I used a OTG checker and it shows it has it. I checked with a flash drive like it said and it works. When I try the Hotwire is says not Hotwire found and starts in Demo mode. It works on my 5in IVIEW but I want it on the bigger tablet.
Old 06-06-2014, 11:01 AM   #185
Team Tekin
Randy_Pike's Avatar
Ok, does the Iview use the same cable?
Is this a HW 1.0 or 2.0?
Old 06-06-2014, 12:09 PM   #186
OfnaJoe's Avatar
Iview has a micro and this one a mini..or the other way around, It's a HW2.0. The 1.0 didn't work either.
I just bought a new Microsoft Surface and it wont let me download from the sight. Back to Best Buy to get a Samsung Note
Old 06-06-2014, 03:34 PM   #187
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Ofna joe, has to be surface pro with full windows 8.1 to run hotwire. Surface is windows rt. Pick yourself up the dell venue 8 pro for 249.00 in the micosoft store. Runs hotwire beautifully. No need for android app
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 06-06-2014, 06:04 PM   #188
OfnaJoe's Avatar
Got it sorted out......................Bought a new Samsung Galaxy Tab Pro, WOW, This thing is great, Thanks for the help guys !
Old 07-11-2014, 07:18 PM   #189
-DOZER-'s Avatar
Just installed a new Savox SB-2274SG High Voltage servo. I used the app to change my RX8 Gen2 Bec voltage to 7.4v. It worked but my Airtronics MT-4 is telling me the actual voltage is around 7.9v. Any feedback on this?
-DOZER- is offline   Reply With Quote
Old 11-29-2014, 10:12 AM   #190
please, I beg you. make a "clean version" of hotwire. One which is just a simple dialog with functional features instead of the hideous non-functional "fancy graphics".
I tap the arrow above BL-DL and end up with a throttle curve
latest version downloaded today etc etc.
Your app doesn't handle font size, online help is broken
this is probably what you wanted?
but I want something that tell me what bl-dl is versus other things etc...
it's so bad...
torg is offline   Reply With Quote
Old 11-29-2014, 03:25 PM   #191
Team Tekin
Randy_Pike's Avatar
You must be using the HW on a very small screen or using a very small resolution setting?
You can right click on ANY slider bar and it will show you what the standard selections are that would go along with the led's on the unit.
The help guides are on the main page: http://www.teamtekin.com/hotwire.html click on the "Help" tab.
Old 11-29-2014, 07:13 PM   #192
nope. 1920x1080 Vaio Pro 13 laptop. Which is a small laptop with high resolution, so I use 125% text size by default.
But the software is unusable if you choose a windows font size other then 100%... so I have to change it to 100, re-log in, do the tekin bits, then back to 125%
Old 11-30-2014, 11:33 AM   #193
Team Tekin
Randy_Pike's Avatar
Any reason why you choose 125% over just going to a larger resolution instead?
Old 11-30-2014, 08:46 PM   #194
because I want the text size to be bigger?
It's already at maximum resolution.
Another reason would be someone that needs glasses etc..
Going to an even bigger resolution would result in smaller text.
Let's not get off topic here, if that hotwire windows app was dpi aware it would not be a problem.
Edit: I also tried it on a Toshiba Encore mini, a $99 Windows 8.1 7" tablet it also had the same problem out of the box. These might become popular tool/pit box accessories (like the cheap android tablets). The people that bought that might not think to try changing the text size setting in windows.
Edit2: It may be that it's a bug report that needs to go to skincrafter or you need a newer version of their library.
Old 11-30-2014, 10:12 PM   #195
Discussion taken offline
