Old 07-12-2005, 06:46 AM   #1
Elk666's Avatar
Default old battery packs, need help
Hi, i have some 3000 packs that have been sitting on the shelf for like 2 years, i'd like to give them a try and am not sure if i have to cycle the packs b4 charging them.
should i cycle them?
if so, is there any setting i should nknow about? ( i have a quazar pro charger)
i haven't touched any of my electric stuff for over 2 years and am very rusty
thanks for any help
Elk666 is offline   Reply With Quote
Old 07-12-2005, 10:01 AM   #2
DrOlds's Avatar
Charge them at a low rate-3 amps or so,(they will prob false peak several times)let them sit for a day,discharge them at 20 amps or so then tray them all the way down to 0.0(probably overnight),let them sit another day then charge like normal-5 amps,then cycle them again.If they are still good it should bring them back.
DrOlds is offline   Reply With Quote
Old 07-12-2005, 10:52 AM   #3
My opinion . Charge them at low amperage (I'd start at 2 Amp) until slightly warm, but they have to be dishcarged on a tray the first couple of times, the Trinity 2 Amp discharge tray or similar would be fine. Don't discharge them as a pack and don't discharge below 0.5 Volts each cell. Repeat couple of times increasing charge current 1 Amp each time, after 3 cycles or so it should be safe to discharge them as a pack. If they're still ok when you begin, then you should end up with batteries that are fine.
andsetinn is offline   Reply With Quote
Need 2-4 packs TC 6C matched battery packs 7.5man R/C Items: Wanted to Buy 4 01-17-2008 04:37 PM
Tekin Battery Nurse and battery packs gasman1 R/C Items: For Sale/Trade 7 01-10-2008 09:45 AM
BATTERY CASE FOR 6 CELL PACKS HOLDS 5 PACKS speedemall R/C Items: For Sale/Trade 2 06-08-2007 02:58 PM
10 6 cell battery packs, 3 stock motors and 2 sakio battery cases $52.00 ??? bigoTC3fan R/C Items: For Sale/Trade 1 09-22-2004 05:07 PM
What packs are best cheap battery packs for bashing? grimlock3000 Electric On-Road 3 07-28-2003 02:53 PM
SEO by vBSEO 3.5.0
