Old 09-04-2002, 06:55 PM   #1
Default Tweak question
If a touring car is grossly heavier on the left side (say, due to a battery pack), does the car tend to turn a larger radius (lazier) to the left or to the right?
mandy is offline   Reply With Quote
Old 09-04-2002, 08:17 PM   #2
King-G's Avatar
Send a message via ICQ to King-G
The side of the car with the more weight, has greater weight distributed to the 2 tires on that side of the car, hence more grip. so if the battery is on the right side, and the electronics on the left are lighter, without any weight on the left the car may pull tighter turning to the left, or not go straight on acceleration.
tweak is more of a twist issue, where there is less weight on the front left tire for instance.
best bet is to play with balancing your car left/right using either those Hudy balancing points, or making some out of some nails and a block of wood. add weight to the light side, and reduce it from the heavy side (if possible)
once your left to right balance is perfect, tweak will only ever be an issue after a big collision when the chassis has twisted slightly, or youve bent a hingepin.
King-G is offline   Reply With Quote
Old 09-04-2002, 11:52 PM   #3
Send a message via ICQ to JesseT
Right. Especially of power. I would imagine... ;-)
JesseT is offline   Reply With Quote
Old 09-05-2002, 06:28 PM   #4
Thanks King
Tweak and ride height question. RandomTask Electric On-Road 9 06-12-2006 09:27 AM
Tweak! performula Nitro On-Road 9 05-10-2006 01:14 PM
Tape -vs- battery brace "To tweak or not to tweak is the question" dawgmeat Electric On-Road 37 11-17-2005 12:05 PM
Engine tweak question Beholder Nitro On-Road 4 06-17-2004 09:54 PM
MIP Tweak station question asimo Electric On-Road 5 12-04-2003 10:46 AM
SEO by vBSEO 3.5.0
