Old 07-10-2005, 03:30 PM   #1
Default 3 channel vs. 2 channel?
What are the differences between 2 channel and 3 channel FM radios??
Are TC3 pinions standard pitch or metric pitch?
AZNracerx1989 is offline   Reply With Quote
Old 07-10-2005, 05:26 PM   #2
TTT... i need this info quick cmon
Old 07-10-2005, 05:39 PM   #3
2 channels means you can control two servos or one ESC, one servo. Three channels means you can control three servos or two servos and one ESC.
TC3 pinions are standard pitch
smojoe is offline   Reply With Quote
Old 07-10-2005, 05:40 PM   #4
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
extra channel lets you control a transmission (ie shifting to reverse on a tmaxx or shifting gears on a nitro sedan (i think))
tc3 is standard 48 pitch, unless it has been changed. It comes 48p from the factory
|◤ReflexRacing.net◢|◤Gravity R/C◢|◤HWNA◢|◤AVID R/C◢|
Old 07-10-2005, 06:55 PM   #5
ChadCapece's Avatar
3rd channel lets you run a fan or personal transponder.
ChadCapece is offline   Reply With Quote
Old 07-10-2005, 11:54 PM   #6
SoCalLosiRacer's Avatar
Each function of your car that you control from your radio (steering, throttle, etc) is a channel. You generally need at least two channels (one for steering, one for throttle), and additional channels can be used for things such as shifting a transmission into reverse. As for plugging things into the receiver (PT, Fan), you don't actually have to have a transmitter that is capable of operation that many channels, you just need to have a receiver that has enough open slots; you could have a three channel transmitter with a 5 channel receiver, and, assuming they were both set up for the same frequency, control your car without a problem and have several extra slots to use for accessories like a transponder or fan. (I mention frequency because I think most receivers that have more than 3-4 channels are meant for air use, which would be a different frequency band - correct me if I'm wrong).
SoCalLosiRacer is offline   Reply With Quote
what are the differences between a 2-channel, a 3-channel and a 4 channel transmitter bosley Radio and Electronics 8 03-12-2011 08:44 AM
LOTS OF BRAND NEW PARTS! NIB, 7 channel radio! 3 Gas motors, 2 4 channel radios! KrechKrawler R/C Items: For Sale/Trade 1 05-23-2006 10:56 AM
which is better Airtronics MX-3 3-Channel FM, Futaba 3PM 3-Channel FM, or Futaba 2PL kidrobot Electric On-Road 2 05-13-2006 06:06 PM
For Sale Brand New Airtronics M11 3-Channel FM Transmitter/Module Only Channel 65 Marcos.J R/C Items: For Sale/Trade 6 03-10-2006 06:07 AM
WTT: Channel 75 Futaba FM RX crystal with channel 74 Speed_Racer R/C Items: For Sale/Trade 0 09-23-2005 05:43 PM
SEO by vBSEO 3.5.0
