Tamiya M03 lipo battery?
The mo3 has the oval slot? Right? You can get a lipo that looks like the old nimh 6cells, or dremel out the chassis to fit the standard rectangle packs.
Pick up a tamiya sport tuned motor or a faster brushed motor. Brushless is going to be fast, but at the same time burn through front tires like crazy.
Buy the Peak Racing 4200 mah lipo battery - no chassis modifications required, and the batteries are relatively inexpensive. I'd avoid brushless motors in the M-Chassis, since the final drive ratio wouldn't be very friendly with a higher-turn brushless motor (you'd have plenty of torque, but come up short on top speed). Lower turn (13.5 or less) would shred the drivetrain, provided you didn't shred the front tires first.
Drive the mini with the silver can motor first, upgrade the shocks, drive train and steering components, then start worrying about more power.
http://www3.towerhobbies.com/cgi-bin...&I=LXGE34&P=ML
There is a group of dedicated Mini racers based out of Australia. They race outside and use a brushless system. Here is a website run by those racers - RC-mini.net (http://rc-mini.net/joomla/index.php)
Here is the Mini thread on RCTECH.net (http://www.rctech.net/forum/electric...ni-cooper.html). You might get a faster response on your questions in that thread.
Hope this info helps.
You can shop here!!..... Great site, fast shipping!!....
http://www.tqrcracing.com/shop/produ....asp?p_id=2745
Go to the Parts Section for your other tamiya needs!
Happy racing!!
Happy racing!!
Lots of stick packs won't fit..... You'll have to measure the m03 battery opening first, and compare the lipo thickness.... I purchased the thunderpower 3200mah rounded packs, and had to dremel the battery opening a bit to fit it.... I am also happy with the Performance of these packs once I changed my charger to a Thunderpower charger instead of MRC....
Is this the motor you are referring to?
No the standard Tamiya esc is not recommend for lipo as it has no low voltage cut off. In my m03 I have the hobbywing 5t brushless set up, it chews the foam tires, I upgraded the drive shafts to cvd's and am still using the stock gears (have the harden set awaiting a breakage).... With my setup it traction rolls very easy unless you add some weight to the rear of the car (I added 85gs) and it now can turn. Always add full ball bearings and oil filled shocks to all Tamiya kits that don't already have them. Awesome fun car and people always seem to be drawn to it, even more than my gold lunchbox.
