Like Tree4Likes
Old 07-02-2015, 08:32 AM   #106
Originally Posted by Aitutaki View Post
i don't see the need for another servo mount.
i do use the king headz bell crank and am happy with it
This the one you are talking about?
http://www.kingheads.com/product_inf...roducts_id=910
-Mike B.
Carnage9270 is offline   Reply With Quote
Old 07-03-2015, 10:43 AM   #107
Aitutaki's Avatar
This link does not exist, but i guess you are right anyway.
i bought it at amain
http://www.amain.com/rc-cars/king-he...op-011/p173234
i also postet a picture on the second page of this thread
Aitutaki is offline   Reply With Quote
Old 07-08-2015, 12:10 PM   #108
Aitutaki's Avatar
anybody found a sway bar solution for the 4wd mini ?
Old 07-08-2015, 12:31 PM   #109
Raman's Avatar
Trader Rating: 56 (100%+)
I believe the ones for the fwd car will work. I haven't felt the car has needed them yet.. So have not bothered
Raman is offline   Reply With Quote
Old 07-08-2015, 12:31 PM   #110
sakadachi's Avatar
Originally Posted by eR1c View Post
here are a few photos of mine,
in the last photo you can see the cars I race on the shelving below ...i go w/ a green colored theme for all my cars (hence the metallic green for my Sabre's 240z body). green is my color!
That looks awesome, eR1c!!!
4PKS-R, DX4S, EX-5UR: Sabre4WD Mini, SabreFD Mini, M01, M02, M03, M04, M05 (2), M05ProV2, TA05 M-Four, CupRacer, BSR M-Rage, WR02, GF01 (2), CC01 (2), CW01, CR01, DF02, TT02B, TA02, RS4, MicroRS4, MR01, MR03-S (2), MR03VE, DigiQ (7), & more.. Updates of projects I am working on in my profile page.
sakadachi is offline   Reply With Quote
Old 07-08-2015, 01:16 PM   #111
Aitutaki's Avatar
i understand, but i had some problems with entering fast corners.
at first, the sabre will not turn into the direction of the corner, and then, after getting slower, the car moves smooth and directly through the corners...
normally a sway bar helps in this situation
i will check out the fwd ones... thnx
Old 07-08-2015, 01:31 PM   #112
Raman's Avatar
What are you running in front .. Diff or spool?
Old 07-08-2015, 02:44 PM   #113
Aitutaki's Avatar
500k diff
Old 07-08-2015, 03:50 PM   #114
Raman's Avatar
500k diff
Ive been running the spook for past few races. I like the way it drives with the spool.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Old 07-20-2015, 11:03 AM   #115
Aitutaki's Avatar
Had the chance to race the mini sabre last weekend, in 13,5t fixed timining blinky class. after a long time absence my driving itself was poor. and i missed about 0,3-0,4 sec against the other "real" TC drivers. (Xrays, Yokomos, ...)
maybe a spool would bring some 0,1, 0,2sec but i was running 1.000.000 diff. will order the spool in the near future for a try
but still it was funny fighting with this underdog...
Old 07-20-2015, 11:38 AM   #116
Haha good stuff. Should have mine this week. Hoping I have an esc small enough to fit back there.
-Mike B.
Old 07-20-2015, 12:01 PM   #117
Aitutaki's Avatar
https://www.youtube.com/watch?v=NkF0r9TTg40
here an short video, the orange car is the sabre mini.
as you can see, some grip rolls costs a lot of time, but i think this was due to the shorty batteries and the unbalanced weight.
nevertheless a lot of fun
Old 07-20-2015, 12:12 PM   #118
sakadachi's Avatar
This chassis is very cool. Does your oil diffs leak at all?
Also I'm sure it is, but these are 210mm wheel base, correct?
I have the FWD Sabre Mini and figured out how to mount a Tamiya Rover Mini body without drilling new holes on the body. I was checking out the 4WD's instructions just now, and I think I can fit a Rover Mini body on this as well, if 210mm.. hummm.
Old 07-20-2015, 12:23 PM   #119
Aitutaki's Avatar
building it due to instructions, it is 210mm.
i got about 220mm by turning the spacers around. so that the ride BRZ body fits perfectly, and the long batteries will also fit.
the mini body did not fit, due to the front bumper. i did not make it run. but it wasn't my biggest wish to get it fit
Old 07-20-2015, 12:28 PM   #120
sakadachi's Avatar
Thanks, Aitutaki! Does your diff leak at all?
On the FWD, here's a picture of how I cut the bumper, mounted the front posts, and rear posts, to get the Rover Mini body to fit my FD. I had to use my M-Four body posts for the rear and drill new holes on the lower deck (if anyone wants to mount it). I think I can do the same on the 4WD's..
From the instructions manual on the 4WD, I would have to place the receiver on top of my servo and mount the ESC where the receiver goes to make room for the rear posts.
http://www.rctech.net/forum/members/...-indicator.jpg
http://www.rctech.net/forum/members/...-body-post.jpg
http://www.rctech.net/forum/members/...abre-final.jpg
More pictures here:
http://www.rctech.net/forum/members/...refd-mini.html
