Old 07-01-2014, 08:34 AM   #46
marshallsbbq's Avatar
Trader Rating: 39 (100%+)
Default Top Racing 2WD Mini Sabre
Does anyone run the 2wd version I have a question about gear ratio?
marshallsbbq is offline   Reply With Quote
Old 07-01-2014, 04:08 PM   #47
Raman's Avatar
Trader Rating: 51 (100%+)
Michael over at top USA is pretty quick at responding to emails.
topracingusa@yahoo.com
Raman is offline   Reply With Quote
Old 07-01-2014, 06:46 PM   #48
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
Default gearing
we are working on gear ratios for the car in 17.5. I am starting with a 76 64p spur and charging pinions until we get speed and low temp on motor. stay tune for results.
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 07-07-2014, 07:45 AM   #49
b20btec's Avatar
What's a good tire choice? I'm assuming 55mm?
b20btec is offline   Reply With Quote
Old 07-07-2014, 08:41 AM   #50
Raman's Avatar
Ride inch up are good.. They're 60D. You have to use them with the ride rim.. They basically increased the rim diameter and offset that with lower side wall.
I have used Sweeps with good success as well. They're 55 but your stuck with their rims. Their pink inserts are the best
Pit Shimizu are also very good. They're like Sorex for Minis. They have 60D classic inner mesh that come in S M D shore in both slicks and threaded.
Then they have 55D slick racing inner mesh series that go from 40 shore down to the 24, plus an sp rear slick for RWD cars. Throw out the inserts and use sweeps.
http://www.pit-shimizu.com/index_page_english/index_e.html
Tqrcracing has all these in stock.
Old 07-07-2014, 09:30 AM   #51
b20btec's Avatar
http://www.pit-shimizu.com/index_pag...h/index_e.html
Forgot to mention I'm looking more for treaded tires. Will run this with a 27 turn brushed setup and switching back and forth to 17.6 also.
Old 07-07-2014, 10:51 AM   #52
Raman's Avatar
http://www.tqrcracing.com/shop/product_view.asp?p_id=6099
Old 07-11-2014, 09:38 AM   #53
b20btec's Avatar
Thanks bud. I may have to be all three compounds and try it.
Old 11-04-2014, 03:06 AM   #54
Callahan_88's Avatar
I have just ordered en Atomic VM2 when i came across the Sabre mini car.
And now i am thinking of selling the VM2 to get the Sabre instead.
But i cant find any one-way diffs for the Sabre.
Go big or go home! :)
Callahan_88 is offline   Reply With Quote
Old 11-04-2014, 04:30 AM   #55
Trader Rating: 25 (96%+)
one way diffs are over rated... I found that they are not worth it when trying to brake into a corner, the rear will kick out from behind you like butter. I found a front spool to be much better for me when I did testing with a FOW on a TC a while back.
billdelong is offline   Reply With Quote
Old 11-05-2014, 01:56 AM   #56
I want the one-way so i can use it for drifting.
I want this one just for its adjustble wheelbase.
Old 11-05-2014, 10:02 PM   #57
Raman's Avatar
You may be able to use the one from the TOP Photon
http://www.top-racing.jp/Eng+JP/Cate...e%20Train.html
I would email "T.O.P. Racing USA" <topracingusa@yahoo.com> and ask to make sure
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Old 11-06-2014, 12:07 AM   #58
bigb11's Avatar
what gearing is everyone running with 17.5 brushless?
Old 11-07-2014, 03:14 PM   #59
Took contact with Top-racing and they are thinking of making an one way for the Sabre 4wd mini.
And if the do so i will buy two cars.
Old 01-09-2015, 04:51 PM   #60
eR1c's Avatar
thinking of getting one of these for our open 4wd mini class.
Have you guys been able to get parts easily? I see TQR has some parts ...yet I don't see a lot like belts, chassis, etc.. are all parts available somewhere? My hesitation w/ purchasing is parts availability. What if TQR stops caring parts ..then am I stuck?
thanks,
eR1c is offline   Reply With Quote
