Like Tree4Likes
Old 04-10-2016, 08:23 AM   #256
Aitutaki's Avatar
Originally Posted by sakadachi View Post
Finally got around to installing my new HobbyWing ESC's to replace the TBLE02-S on both my Sabre Mini's.
Only now, I got a bad bearing somewhere on my 4WD Mini. I can hear the worn bearing .. I'm guessing it's the spur bearing... what do you guys think? I will be replacing that first tomorrow to see if the noise goes away... if not, process of elimination.
very beautiful and clean setup.
i am gonna re-animate my sabre mini again. and so i ordered some hop ups like spool, new leakproof diffusing ver. II , sway bars....
let's see how i can compete against some other big cars again . unfortunately i will have to use the tamyia type a tires, this will a poor experience, but still i looking forward into this.
Aitutaki is offline   Reply With Quote
Old 04-10-2016, 09:57 AM   #257
sakadachi's Avatar
On the gear diff, the only change was the o-rings. I use the same o-rings on my SabreFD Mini's gear diff and the leak stopped.
As for stabilizer, I made a set for my FD Mini but for the 4WD Mini I was able to tune everything using various springs I bought and changing pistons.
Yeah, I am not a fan of those 60D S-Grips. They are too meaty and sidewalls soft unless you use some super firm inserts.
4PKS-R, DX4S, EX-5UR: Sabre4WD Mini, SabreFD Mini, M01, M02, M03, M04, M05 (2), M05ProV2, TA05 M-Four, CupRacer, BSR M-Rage, WR02, GF01 (2), CC01 (2), CW01, CR01, DF02, TT02B, TA02, RS4, MicroRS4, MR01, MR03-S (2), MR03VE, DigiQ (7), & more.. Updates of projects I am working on in my profile page.
sakadachi is offline   Reply With Quote
Old 04-10-2016, 01:25 PM   #258
Aitutaki's Avatar
thanks mate, what O-Rings do you use? so i can fix the leaking on the existing diff housings too.
and i am gonna use real TC tires. i will try my best in the Tamiya Euro Cup (TW Class)
i will upload pictures later this week...
in addition; i also have some troubles installing the ESC, and was also wondering if it would be ok, mounting it on the Servo.do you have a good experience with that mounting place ?
thanks
Old 04-10-2016, 02:47 PM   #259
sakadachi's Avatar
Aitutaki- For the o-rings I'm running the PP-GDRS01
I use a dab of AE Green Slime as well during assembly.
http://www.top-racing.jp/ and go to Sabre Optional Parts/Drive Train
Huh, TC tires, huh? cool, looking forward to your pictures.
As for the ESC, I'm okay with the placement over the servo since everything is fairly low anyway; it hasn't offset anything drastically. I do not get any odd left to right turn bias. Car turns very evenly while accelerating out of a turn left or right.
Old 04-11-2016, 02:41 PM   #260
eR1c's Avatar
+1
eR1c is offline   Reply With Quote
Old 04-11-2016, 07:30 PM   #261
sakadachi's Avatar
Thanks, eR1c!
Old 06-02-2016, 07:24 AM   #262
tmg2112's Avatar
Thought I'd post these pix of the Mini build and ask for a baseline for gearing for a 17.5 motor with 48p gears.
TOP RACING Sabre Mini 4WD-img_1753.jpg   TOP RACING Sabre Mini 4WD-img_1748.jpg
______________________________________________________
I don't want to grow up. I hate grown-ups.
tmg2112 is offline   Reply With Quote
Old 06-29-2016, 10:19 AM   #263
Raman's Avatar
Trader Rating: 56 (100%+)
Carpet set up.
I decided to Unshelf the Sabre queen now that we have a carpet track here in LV.
Does anyone have a carpet set up that works to post?
Raman is offline   Reply With Quote
Old 07-16-2016, 12:23 PM   #264
Raman's Avatar
Has anyone figured out how to mount stabilizers to the front?
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Old 07-16-2016, 07:46 PM   #265
sakadachi's Avatar
If I ever need one, probably make something like what I did on my FD-mini.
http://www.rctech.net/forum/members/...front-bar.html
Rear
http://www.rctech.net/forum/members/...i-m05-bar.html
Old 07-16-2016, 08:58 PM   #266
Raman's Avatar
The rear was pretty straight forward using this set
http://apexhobbies.3dcartstores.com/...01_p_1874.html
How did you attach the linkage to the arm? The arm is designed for the linkage to be entered in the centre.. and a 3 mm screw slides right in.. so you can't use the hole.
Old 07-24-2017, 08:12 AM   #267
Hey All, old thread, I know. Curious what treaded Shimizu tire and wheel everyone was running on these for asphalt and carpet? Looks like the hard tire is impossible to get ahold of now.
-Mike B.
Carnage9270 is online now   Reply With Quote
Old 07-24-2017, 08:28 AM   #268
Raman's Avatar
For Carpet i recommend the Pit Shimizu inner mesh series.. they come in a range of shire from 24
Up to 40. I'm running 30s on all 4 corners with sweep hard inserts
The best place to order these is through banzai hobby in Japan.
Tq carries the 60D series which are s m h. I have never run those personally or the treaded..but Shimizu is an awesome tyre
Old 07-24-2017, 09:14 AM   #269
Thanks man, what rims are you putting them on?
-Mike B.
Old 07-24-2017, 09:34 AM   #270
Raman's Avatar
They work with Tamiya m chassis rims.
The wheels I use go with the body I use.
https://www.tqrcracing.com/shop/product_view.asp?p_id=5142
The wheels listed below this link will work as well..
