Like Tree4Likes
Old 10-01-2015, 04:46 AM   #181
sakadachi's Avatar
Originally Posted by Raman View Post
I'm running 82/52 with 21.5
82/25 right?
I ran stock spur /25 on silver can during setup. Not bad, not much top end.
Can probably run stock/27..
I run 17.5T now.
4PKS-R, DX4S, EX-5UR: Sabre4WD Mini, SabreFD Mini, M01, M02, M03, M04, M05 (2), M05ProV2, TA05 M-Four, CupRacer, BSR M-Rage, WR02, GF01 (2), CC01 (2), CW01, CR01, DF02, TT02B, TA02, RS4, MicroRS4, MR01, MR03-S (2), MR03VE, DigiQ (7), & more.. Updates of projects I am working on in my profile page.
sakadachi is offline   Reply With Quote
Old 10-01-2015, 07:42 AM   #182
Rodarbal's Avatar
Trader Rating: 38 (100%+)
Send a message via Yahoo to Rodarbal
Originally Posted by sakadachi View Post
82/25 right?
No, I imagine he really is at 82/52 which gives a 3.15 FDR (2:1 drive ratio in the Sabre 4wd mini, correct?). I was running a 72/58 spur/pinion combo with a silver can in my Genetic which is a 3.1 FDR (2.5:1 drive ratio). I could imagine an 82/25 in the Sabre being ridiculously slow with a 21.5T.
RJ Labrador
Off Road Big: Mugen, Mugen & Mugen
Off Road Little: XRay & XRay
Rodarbal is online now   Reply With Quote
Old 10-01-2015, 10:56 AM   #183
sakadachi's Avatar
Originally Posted by Rodarbal View Post
No, I imagine he really is at 82/52 which gives a 3.15 FDR (2:1 drive ratio in the Sabre 4wd mini, correct?). I was running a 72/58 spur/pinion combo with a silver can in my Genetic which is a 3.1 FDR (2.5:1 drive ratio). I could imagine an 82/25 in the Sabre being ridiculously slow with a 21.5T in the Sabre 4wd mini.
Sounds good then.
Old 10-01-2015, 11:06 AM   #184
Raman's Avatar
Trader Rating: 56 (100%+)
82/25 right?
I run 17.5T now.
82/52. 25t pinion will not reach the spur. 52 is the smallest pinion you can run with 82T.
I run it with a 21.5 Vulcan and timing is turned down.. It's almost as fast as my TC..
Raman is offline   Reply With Quote
Old 10-01-2015, 05:16 PM   #185
sakadachi's Avatar
Sounds good, I'm sure this info will help people greatly.
Old 10-04-2015, 07:20 PM   #186
c-lyon's Avatar
Ready to race, what's the approximate weight of the car? Thanks.
c-lyon is offline   Reply With Quote
Old 10-04-2015, 09:00 PM   #187
Really hard to say being R2R. That would depend entirely on your electronics and battery. Really it comes down to battery. You typically have to add weight to one side to compensate for it.
-Mike B.
Carnage9270 is offline   Reply With Quote
Old 10-04-2015, 09:04 PM   #188
Dan
Dan's Avatar
Trader Rating: 46 (100%+)
When we ran blinky 21.5 4WD minis at our old track, most of us were gearing our Sabres with 80T spur and 57-59T pinion. Make sure you have good fan for the motor.
Dan is offline   Reply With Quote
Old 10-04-2015, 09:37 PM   #189
c-lyon's Avatar
Thanks guys. Our minimum weight is 1450gms, 21.5 blinky, open treaded mini tires. Hope to get a car soon.
Old 10-04-2015, 10:32 PM   #190
That's pretty heavy for a mini. Better get some tungsten.
-Mike B.
Old 10-05-2015, 06:32 AM   #191
c-lyon's Avatar
Yes, it's a new class for a two race series between two cities, involving other classes as well. Weight, tires, etc may change depending on how it works out.
Old 10-05-2015, 09:56 AM   #192
Rodarbal's Avatar
Yeah, I'm willing to bet you will have to add 200 grams to get it up 1450 g. For reference, a buddy's Atomic VMII weighed in 1185 g RTR with a full size 5000 mAh lipo, Shoe-Goo'd body and all. My Genetic came in at 1220 g with a 4.2 Ah shorty pack.
Old 10-05-2015, 02:20 PM   #193
sakadachi's Avatar
Should just do an open class, aka anything goes.
After qualifier results, break it up into fast, turtle, and snail classes. Goal is to have fun.
Old 10-05-2015, 02:57 PM   #194
Yeah we run a class we call Scale Spec here in Seattle. It steals a lot of rules from VTA, but it's designed to be a low budget class and an entry level after Novice. The rules were relaxed for M chassis cars to try and bring in the people who have them. No weight restriction or tire restrictions etc. The class works out very well here.
-Mike B.
Old 10-05-2015, 03:03 PM   #195
sakadachi's Avatar
That's a good idea. When I use to race many years ago (over 15yrs ago), we bought our m-chassis for fun. It was always open class, you can drive fast or slow, whatever you want. We even lined up our cars facing the wrong direction on the starting grid so you had do a u-turn first.
I was kind of amazed at all these rules you guys have these days when I got back into RC last Fall. Tire restriction? TCS rules? Really, for m-chassis class?
