Like Tree4Likes
Old 08-30-2015, 11:24 AM   #166
sakadachi's Avatar
Nice failsafe you got going there!
I just tried it with my full sized round lipo. You're right, the balance is much better.
Guess I will use these lipos for the time being.
4PKS-R, DX4S, EX-5UR: Sabre4WD Mini, SabreFD Mini, M01, M02, M03, M04, M05 (2), M05ProV2, TA05 M-Four, CupRacer, BSR M-Rage, WR02, GF01 (2), CC01 (2), CW01, CR01, DF02, TT02B, TA02, RS4, MicroRS4, MR01, MR03-S (2), MR03VE, DigiQ (7), & more.. Updates of projects I am working on in my profile page.
sakadachi is offline   Reply With Quote
Old 08-30-2015, 04:50 PM   #167
sakadachi's Avatar
Gave my Sabre4WD Mini proper new attire.
I think this completes this project for now. Car is dialed, so easy to drive fast. I love it.
Old 08-30-2015, 04:59 PM   #168
What did you end up using for body posts to make it fit?
-Mike B.
Carnage9270 is offline   Reply With Quote
Old 08-30-2015, 05:18 PM   #169
sakadachi's Avatar
For the front I used the factory body post but pushed it back about 7mm or so, drilled a hole on the bottom where the pin is so that there are 2 screws per post preventing it from turning.
For the rear, I used the Tamiya TA05 M-Four rear body post:
B Parts - Bumper Item# 51488 (will need 2 of these).
Drilled two holes through the chassis so that there are 2 screws per body post.
I had a long straight body post, but it was too short even with an extender, so decided to go with the #51488.
I am using the same approach on my SabreFD Mini too.
Old 09-07-2015, 04:48 PM   #170
sakadachi's Avatar
Over the weekend I installed a Thunderpower 17.5T on my Sabre4WD Mini. Perfect power and speed range for me, and runs SUPER smooth with my kit Tamiya ESC (TBLE-02S). Very happy with the results.
Old 09-07-2015, 10:00 PM   #171
Trader Rating: 62 (100%+)
17.5 use to be what we ran the minis in Norcal hobbies. It has been switched to 21.5. Still fast but 17.5 was perfect.
Anyone has a 4wd for sale? Looking for used so I can afford it.
sipaboy is offline   Reply With Quote
Old 09-13-2015, 09:25 AM   #172
sakadachi's Avatar
Yeah, especially with the 4wd mini's stability, 17.5 is no issue.
Got a couple of these rectangular lipo's last week. Much better left/right balance. Thanks again to Raman.
Old 09-28-2015, 03:12 PM   #173
c-lyon's Avatar
Which is the best place to buy the Sabre? Thanks.
c-lyon is offline   Reply With Quote
Old 09-29-2015, 04:53 PM   #174
Raman's Avatar
Trader Rating: 56 (100%+)
TQRC or direct from Top USA..
topracingusa@yahoo.com
Raman is offline   Reply With Quote
Old 09-29-2015, 09:34 PM   #175
c-lyon's Avatar
Thanks for the info, Raman. TQRC are "sold out", so I'll see what happens at TOP.
Somehow I thought Apex was the TOP rep. but I had problems, and no replies after two e-mails.
Old 09-29-2015, 10:04 PM   #176
Raman's Avatar
Apex is top but the site seems to not function correctly. Try calling the number listed on the site in contact section, and you should be able to reach top
Old 09-30-2015, 04:44 AM   #177
sakadachi's Avatar
As Raman mentioned: topracingusa@yahoo.com
His name is Michael. He is busy often, but very good.
Old 09-30-2015, 07:01 AM   #178
c-lyon's Avatar
OK thanks. Gearing suggestions for 21.5? Looks like it comes with an 84 spur.
Old 09-30-2015, 09:14 PM   #179
Raman's Avatar
I'm running 82/52 with 21.5
Old 09-30-2015, 11:59 PM   #180
c-lyon's Avatar
OK thanks.
