Need help on XS3 Pro Radio
this may be a Duuhh, but did you check the D/R?
I did the same thing when I used to own a Pro and felt pretty dumb when I figured it out. Also, pick up some good rechargeables for the transmitter cause that thing eats batteries like my son does to candy.
are the frequency the same on receiver and transmitter?
If it doesn't even change from the L to the R settings on the EPA, then your steering wheel for some reason is not recognizing the movements you are making with it. It sounds like DOA man. Call Horizon and ask them an estimate of what they'd charge to fix it.
Remember on the plug that goes into the RX, the black wire is on the outside. I've made that mistake before.
