Team Associated TC6.2 Touring Car
#1426
About the car. I didn't felt any issue about flex management. If the chassis would be narrower maybe we could run lower ride height expecially in long and fast sweepers.
I'v founded a real problem on plastics play... Too much in Chubs and uprights.
I solved with an hole and a screw under each part, but i hope in a new plastic set in the future.
#1427
We know that Yokomo, Tamiya, and Xray were all in the finals. But the other makes and their best finish should be mentioned. People are acting as if AE was completely out to lunch.
Kyosho - Krapp - 11th
Wang - HB - 15th
Hohwart - AE - 17th
Harper - Durango - 19th
Sudhoff - Awesomatix - 22nd
Fischer - Serpent - 29th
Grainger - Schumacher - 30th
Whether you have one guy or three guys, you are in the same boat. Teams like Yokomo and Tamiya with multiple top factory drivers and mechanics are going to be hard to beat.
Wang - HB - 15th
Hohwart - AE - 17th
#1428
I rebuilt my shocks last night with RSD soft bladders and the delrin piston heads on my TC6 shocks.. My only question revolves around the bladders. If I try for no rebound, the bladders don't really fall into place as all the videos show. Its kind of a balancing act putting on the top of the shock on.
I'm not sure if the bladders are just that way since they are soft and/or having 0% rebound is not the way to go. I thought at rebuilt the shocks wrong somehow.
Should I put the piston head 25% from the top and rebuild them again? Seems the piston head is virtually at the top of the shock when you go for 0% rebound and the bladder is more difficult to put on.
#1429
#1431
Are there any new revisions coming to the car anytime soon??
#1432
I just wanted to make a comment about the Worlds. They are nice to watch but the outcomes are irrelevant to me. There are too many factors that go into winning at that level to make a comparison. All that is important to me is how the cars perform in my hands. I've owned and raced most of the cars out there and, on asphalt, and the TC6.2 has been the best so far. I have not had to struggle with getting the car to turn as i have with several other cars. So far, I've been able to get it to do what I've asked it to do. My lap times have been best with the 6.2 although close with the others. The cost of ownership is significantly less too. I think it's the best car all around to own. Just my opinion
Thanks,
Oliver
Thanks,
Oliver
#1433
Thanks,
Oliver
Thanks,
Oliver
#1435
Thanks,
Oliver
Thanks,
Oliver
S
#1436
I agree with you and MDawson, you guys were the ones that convinced me to get this car and I like it so much now I have two. The performance and cost of ownership is great (having come from 15 years of owning mostly the lighter shade of blue cars). And unlike other manufactures I'm not worrying about a new car coming out on a yearly basis
S
S
#1437
The potential of the chassis and the team was shown here:
http://www.redrc.net/2014/10/2014-in...rt/#more-87832
#1438
I'm +1 with Rick with the RSD bladder you can build with the piston fully extended. When I do mine I roll the bladder on with the piston fully extended, wipe off excess, then i place the plastic cap on top and while holding the cap down with my pointer finger I slowly push the piston in and out a few times about half way or so, If there is a lot of pressure you can loosen your pointer finger just a bit and more excess oil will spill out. once you return the piston to fully extended it usually has a slight vacuum effect. Clean off the excess and cap it off being careful not to tilt the bladder and unseal the edge and you should be good to go for zero rebound.
#1439
