Old 10-10-2014, 03:22 PM   #1366
Trader Rating: 1 (67%+)
Send a message via AIM to racer034life
No news from the world's about the tc6.2 or even a update?
Sold All my R/c car stuff to by a zx-14, Access Hobbies, CRC, ARC,
racer034life is offline   Reply With Quote
Old 10-11-2014, 09:51 PM   #1367
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Check the results... not looking too good for us but I am hoping for a Worlds kit with all the bells and whistles.
Kyle Predmore
Facebook - "AE Fanboy"
B6D|B64D
TC7|TC6TEK|12R5.2|10R5.1
Logi Maker is offline   Reply With Quote
Old 10-12-2014, 09:50 AM   #1368
TC5Driven's Avatar
Default Building TC 6.2
I have a question on building the 6.2. In order to get rear toe of 3 degrees I set the inner hinge pins next to the rear gear diff with a 1 dot in the front and a 3 dot in the rear of the hinge pin. Does this give me 3 degrees of rear toe? Do you set the rear toe with the inner hinge pins or is the rear toe only set at the rear hub carrier, outer hinge pin or can you set it either at the inner hinge pin or outer hinge pin? Does it matter? Directions are not really that clear.
Any help would be great.
TC5Driven is offline   Reply With Quote
Old 10-12-2014, 12:52 PM   #1369
Pat Clark's Avatar
Getting back into hobby after 5-6 year leave. Picking up 2 tc6.2 kits. What factory or aftermarket parts are recommended. I read somewhere about bladders, pistons and springs...RSD? What body is recommend to start with ltcr, mazda 6, mazda 6gx? Going to run 17.5 and 13.5 what spur gear is pretty standard? Also a rollout for a d4 would help.. We used to run 100 but I'm pretty sure that may have changed.. (Man i have no use for my 4200's and brushes.. LOL)
Any help would be great!!!
Pat Clark is offline   Reply With Quote
Old 10-12-2014, 12:57 PM   #1370
S_fender's Avatar
1dot front and 3 dot rear does'nt give 3.
Same dot front and rear give 3
S_fender is offline   Reply With Quote
Old 10-12-2014, 01:04 PM   #1371
OttoKrosse's Avatar
RSD Bladders and pistons are a good choice, you can drill a 1mm hole in the shock cap to reduce rebound created by air pressure as the shock is collapsed.
LTCR, Mazda Speed 6 or the GX6 are good choices, pick one you like.
Common spur gear is 96t 64 pitch.
That's all I got.
This space for rent.
Oo=00=oO
OttoKrosse is offline   Reply With Quote
Old 10-12-2014, 01:12 PM   #1372
Svendc's Avatar
They use the stiffer and lighter arms and doing tests with other chassis on the moment. Words from FAST Rick H.
VBC Wildfire D08
AE B5M CE
Svendc is offline   Reply With Quote
Old 10-12-2014, 05:18 PM   #1373
Trader Rating: 23 (100%+)
Servo saver - I got back into RC after about 8 or 9 years and my TC6.2 chewed through servo horns (might be coz of my driving though )
Yokomo BD7 15 | Team SILVERBACK | LRP | FUTABA
Zhangesh is offline   Reply With Quote
Old 10-12-2014, 07:31 PM   #1374
I was in a similar position almost two years ago. The cars are so similar but very different due to the brushless and lipos.
Yes, RSD pistons, bladders, and o rings. Makes the shocks super smooth.
I can't tell you about rollout with the 13.5 or D4. I would ask some locals. In 17.5 I run a 95t Spur.
I'm assuming your running carpet due to the time of the year...so I'd start with a Mazda Speed 6. Yokomo Pink and Blue springs. Both are tried and true.
Must have options: DCV front axels - makes a huge difference in corner speed. Of course diff oils and shock oils for tuning.
Other options: TC5 sway bars - easier to work with IMO. Steel spool outdrives - no worrying about breaking the plastic ones or blades. Front gear diff - great tuning option. CF roll center shims - so much easier.
Andrew Cartwright | Reflex Racing
A_Cartwright is offline   Reply With Quote
Old 10-12-2014, 07:41 PM   #1375
The standard blocks have 3deg toe built in. If you use the same dot front and rear then it's 3deg. Each dot is 1/2 deg plus or minus depending on how you put it together.
You can also change the toe on the hub carrier also. This isn't commonly used but available.
Bottom of page 27 goes over this in the manual. Hope this helps!
Old 10-12-2014, 11:11 PM   #1376
Give me a shout tomorrow.
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 10-13-2014, 12:44 PM   #1377
TC5Driven's Avatar
Old 10-13-2014, 12:47 PM   #1378
TC5Driven's Avatar
Thanks for the info. It makes sense now
Old 10-13-2014, 12:50 PM   #1379
TC5Driven's Avatar
I now see what you mean. the toe is built into the chasse. I would have made a big mistake on my toe setting. thanks
Old 10-13-2014, 01:43 PM   #1380
freeman2385's Avatar
What's the best steering servo for the tc6.2 I would like to use a low profile to give a lil more room and less weight, but the choices are endless lol anyone using a low profile servo?
freeman2385 is offline   Reply With Quote
SEO by vBSEO 3.5.0
