Old 09-22-2014, 08:56 AM   #1351
Most people who run a servo saver uses the Xray one
Shawn Plume
www.pmhobbycraft.ca
Frantic Racing (Est. 1988)
Ophidian is offline   Reply With Quote
Old 09-22-2014, 09:26 AM   #1352
patorz31's Avatar
+1 on the Xray one. I use it it in everything that uses a Servo Saver.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 09-22-2014, 09:43 AM   #1353
RussF's Avatar
Trader Rating: 21 (100%+)
Originally Posted by speeddaddy View Post
Would someone be willing to help me on building my shocks to get zero rebound. Any help would be appreciated
While I would suggest a search for other possibly better answers I will tell you what works for me.
After full assembly and drilling the caps out with a 1mm hole.
1. Fill the shock with oil to about the top.
2. Bleed the air out by sliding the piston up and down while turning it slightly.
3. Let it sit for 15-20min (or use a pump if you have one) to get the air bubbles out of the oil.
4. Slide the piston to about the top without the piston coming out of the oil and hold it there about 2-3mm below the rim, there needs to be room for the bladder.
5. Fill the body to the top with oil (kinda domed).
6. Set the bladder on top and work all the air bubbles out, I like RSD soft bladders myself because you can see through them.
7. Set the drilled cap onto the bladder and place the threaded retainer over that all while holding the piston from moving and tighten the threaded retainer down. Lots of oil will leak out so clean it up.
The shock should have zero or close to zero rebound. The stock bladders are harder to get zero with. Good luck.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 09-23-2014, 02:30 AM   #1354
Trader Rating: 41 (100%+)
Originally Posted by thejo3 View Post
What's the best servo saver to install on the 6.2 with a SAVOX servo ?
+1 more for the Xray servo saver.
markpoleon is offline   Reply With Quote
Old 09-23-2014, 03:45 AM   #1355
speeddaddy's Avatar
Thanks for the help. Yes I have the RSD soft bladders. Thanks again
If you can't fix it with a hammer, you've got an electrical problem.
RC Sailboat, 3RC planes, SC5m, Yuneec Typhoon Quadcopter
speeddaddy is offline   Reply With Quote
Old 09-23-2014, 07:37 AM   #1356
DARKSIDE's Avatar
the AE one works great...I use it on all 3 of mine...no issues, and a lot less expensive
http://www.teamassociated.com/parts/details/25162/
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
THUNDER JAM IX Snowbirds Warm-up
January 21, 2017 Thunder RC Raceway
http://events.rcsignup.com/events/displayEvent.cfm?id=5313
DARKSIDE is offline   Reply With Quote
Old 09-23-2014, 07:38 AM   #1357
DARKSIDE's Avatar
here it is....
Old 09-23-2014, 09:14 AM   #1358
Castradamus's Avatar
Trader Rating: 52 (100%+)
I use the AE one and it works great and it is cheaper than the Xray
Destiny | Xenon USA | SpeedzoneUSA.com | TQ Wire | NAO | dIgItS pAiNt
He who is not courageous enough to take risks will
accomplish nothing in life. - Muhammad Ali
Castradamus is offline   Reply With Quote
Old 09-26-2014, 01:17 PM   #1359
JustWill75's Avatar
Send a message via AIM to JustWill75
I noticed that Team Associated don't make low friction belts like some of the other brands. Why not?
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 09-26-2014, 02:13 PM   #1360
wtcc's Avatar
Rick Howart once mentioned in the TC6 thread that there is no need for them. I used a Yokomo belt for a long time until it worn out. Since then I use the standard belt(s) and felt no difference or saw a time difference. I am running stock classes only (17.5t & 10.5t).
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 10-04-2014, 06:33 AM   #1361
ViperZ's Avatar
Nice spring perches!
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 10-04-2014, 08:38 AM   #1362
JustWill75's Avatar
Any TC6.2 news from the Worlds?
Old 10-04-2014, 09:33 AM   #1363
Dan Hamann's Avatar
12th portion is coming up first.. probably see more TC news at the end of the upcoming week.
RCAmerica - Xray - Hudy - RC^2 - Motiv - Team EAM - Sanwa - Avid - Max.FX - Protoform - Pro-Line - Gravity R/C - Prolevel R/C - 2MM Designs
Dan Hamann is offline   Reply With Quote
Old 10-05-2014, 05:39 PM   #1364
im curious if they will release anything new for the car
Edwin Pibal is offline   Reply With Quote
Old 10-05-2014, 06:10 PM   #1365
samnelso's Avatar
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
SEO by vBSEO 3.5.0
