Old 09-14-2014, 09:58 AM   #1321
wtcc's Avatar
The 6.2 is not a bad car
From the first build on it will be very nice to drive with clear response to all setupchanges. So for a beginner or reentry driver this is a plus.
What counts against this beautyful chassis is, that it needs a lot of time to perfectly adapt it on your driving style and catching the last two tenth. Especially the corner entry and middle corner turning were hard for me increase to a top spot competitive level. My guess is the huge amount of flex this chassis has in comparison to the 6.1 for example (the Yokomo BD7 is also stiffer and has therefore a smaller setup window, but comes already with a very good basic setup).
So the 6.2 is a competitive car and can easily outpace every other chassis on the market if you diligently work with it. Not to forget it has a nice price and parts availability
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 09-14-2014, 12:21 PM   #1322
Svendc's Avatar
The RSD Top Deck is Stiffer than the original unit and increases the response and overall steering of your TC6.2.
For high grip surfaces is this big +1.
The Flex of the chassis with the stock topdeck is hugh.
Anyone who has tested this RSD topdack allready?
VBC Wildfire D08
AE B5M CE
Svendc is offline   Reply With Quote
Old 09-14-2014, 12:25 PM   #1323
Trader Rating: 48 (100%+)
I tested it with the aluminum chassis as well as their arm system. The top deck is a tad stiffer but I think what made the difference between the two is that the rsd top deck has a different design so It has different characteristics which I liked. I haven't done many back to back tests mostly because I liked how the car felt with the rsd one over the stock one.
thecaptain is offline   Reply With Quote
Old 09-16-2014, 10:02 AM   #1324
nicorozog's Avatar
Send a message via MSN to nicorozog Send a message via Skype™ to nicorozog
Default Shocks
i´ve done almost everything we used to do, to eliminate the bubbles of my shocks. After build them, seems to be good, but, after the race, or practice, shocks starts to sound really bad, in fact, i can feel the bubbles in my finger, when i try to move up side down the shock shaft.
The last tip was, sanding about 0.1mm of the O-Ring spacer, and it didn´t work out. Is important use the low friction orings? reflex soft bladders? those upgrades will solve the problem?
Thanks.
Team Associated / Reedy / Upgrade RC/ Boca Bearings / G-Force USA
Bogotá - Colombia
nicorozog is offline   Reply With Quote
Old 09-16-2014, 10:11 AM   #1325
Dan Hamann's Avatar
Trader Rating: 14 (100%+)
Reflex bladders and O-rings may help. Also crucial to make sure all the air makes it out from below the piston. Either use a shock pump or let the shocks sit for an extended period before setting the bladders. Reflex bladders make it a lot easier to see if there is any air in the shock.
RCAmerica - Xray - Hudy - RC^2 - Motiv - Team EAM - Sanwa - Avid - Max.FX - Protoform - Pro-Line - Gravity R/C - Prolevel R/C - 2MM Designs
Dan Hamann is offline   Reply With Quote
Old 09-16-2014, 10:48 AM   #1326
Trader Rating: 18 (100%+)
I tried to setup my tc6.2 with the ars suspension and it seems like I'm getting a 9mm ride height in the rear even with the shock collor at the top. droop is set at 5mm rear. otherwise it is the same geometry as stock setup
thejo3 is offline   Reply With Quote
Old 09-16-2014, 11:31 AM   #1327
wtcc's Avatar
Thanks.
The Reflex bladders should cure your problem.
Picture please.
AE / Reedy / RSD
Old 09-16-2014, 03:10 PM   #1328
Here arr the pictures... I pushed the car and here is what I get: 9mm ride height (front is correct, 5mm)
Old 09-16-2014, 04:21 PM   #1329
have you tried the ae spring retainers ?
it looks like there is too much load on the springs with the retainers you have.
ed
Edwin Pibal is offline   Reply With Quote
Old 09-16-2014, 05:20 PM   #1330
Another thing you can do when the spring cups are up that high is cut down the turnbuckle eyelets a bit to bring them back down. I did this when I started using aluminum spring cups. That should eliminate the preload.
-Mike B.
Carnage9270 is offline   Reply With Quote
Old 09-16-2014, 06:07 PM   #1331
I had the same problem. I ended up swapping out the standard shocks for TRF short shocks. car works great now.
jonston is offline   Reply With Quote
Old 09-16-2014, 07:42 PM   #1332
NutDriver's Avatar
I bought a used car that someone had put RPM spring cups on. I had the same problem until I changed them.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 09-16-2014, 10:03 PM   #1333
YoDog's Avatar
Trader Rating: 26 (100%+)
In addition to the wrong spring retainers, you are now combining front arms with the rear shock tower and the mounting points are different. The mounting points are normally much further outward on the rear arms which accommodates the lower shock tower mounting points.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 09-16-2014, 10:14 PM   #1334
wtcc's Avatar
Yupp, Yodog is right!
If you look at my conversation (some pages back), you will see that I drilled new holes for the ballstud to allow for a correct geometry. Then
your ride height problem will go away without having to buy new stuff
What to do:
1. Measure the distance between inner pin and ballstud hole of the rear suspension arm.
2. Drill a M2.5mm hole in the same distance into the front suspension arm.
3. Install everything and check if the lower damper touches the suspension arm. If it does just add a 1mm spacer.
4. Enjoy
AE / Reedy / RSD
Old 09-17-2014, 12:51 AM   #1335
WildManDriving's Avatar
Trader Rating: 27 (100%+)
What to do:
4. Enjoy
What are the Pro's and Con's of this mod?
Regards
M.Ellis
. . . - - - Now enjoying Proline tyres - - - . . .
Scale race models: RCHobbyzone, Mugen, Reds, Xpert, Contact, Neo+.
Toy cars: Xray T4'15, Hudy, Nosram/Muchmore, Protoform.
No longer defined as a Off or On-road racer, but simply a RC enthusiast.
WildManDriving is offline   Reply With Quote
