Old 09-02-2014, 04:35 PM   #1306
CristianTabush's Avatar
Originally Posted by JustWill75 View Post
I was thinking of picking up a aluminum chassis for the Tc6.2. Planed to try it out on high traction carpet. I've talked to a few team drivers and they say it's not needed. What do you guys think?
Is it needed, no. But will it make your car better. DEFINITELY. Hands down makes the TC6.2 a better car on carpet. I don't necessarily think it is only it being an aluminum chassis (although the lower cg is helpful) but rather decreasing the excessive flex the 6.2 has. The stock chassis also improved when combined with our top deck, although the gains were much higher when using both.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is online now   Reply With Quote
Old 09-02-2014, 04:37 PM   #1307
Originally Posted by turtlehill View Post
Anyone using the RSD aluminum chassis on asphalt? Any issues vs the c/f chassis?
I have not done a lot of testing on asphalt with the Aluminum chassis, but the RSD7 Carbon chassis worked very well. If the track is high grip, the aluminum chassis should do well.
Old 09-02-2014, 06:46 PM   #1308
NutDriver's Avatar
Trader Rating: 14 (100%+)
Any idea when the lightweight suspension will be in stock?
http://www.reflexracing.net/RSD-TC62...ER_p_2368.html
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 09-02-2014, 07:49 PM   #1309
Late this week/early next
Old 09-03-2014, 08:58 PM   #1310
NutDriver's Avatar
Since we're talking about RSD parts, how hard is it to adapt this to the 6.2 chassis?
http://www.reflexracing.net/RSD-AE-T...er_p_1007.html
USVTA member #111
Old 09-03-2014, 09:05 PM   #1311
I don't know if it can be made to work. The bulkhead distance is not the same. Also, the sway bar cylinder gets in the way.
Old 09-04-2014, 07:44 AM   #1312
NutDriver's Avatar
I was considering using a longer bolt through the sway bar cylinder anchor point and looking to secure it from below with a nut. Might have to get one and give it a shot.
USVTA member #111
Old 09-08-2014, 02:25 AM   #1313
Hoping for some help in relation to diff height.
Is it a case of higher diff for low grip tracks and lower for higher grip?
By changing diff height i will also end up changing axle angle, how critical is this?
svturtle is offline   Reply With Quote
Old 09-10-2014, 03:53 PM   #1314
JustWill75's Avatar
Send a message via AIM to JustWill75
^^^ Anyone care to answer? I'd like to know too.....
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 09-10-2014, 05:08 PM   #1315
The axle height is a tuning tool that personally I hardly ever run. However, in theory, too high or too low will make the car stiffer under roll than a "centered" drive shaft position.
On the 6.2 I always run my diffs in the mid low position. If I wanted a little more roll in the middle of the corner, I could raise the rear diff to the mid high position. If I wanted my car to be a little flatter, I would lower them more.
The effect on the suspension is probably due to drive shaft angles wanting to straighten out under load. The more angle, the stiffer the suspension should act.
Angle should also have a bit of an effect on straight line traction. When the bones are angled upwards towards the diff, the car would tend to lift and lose traction as the car would "squat" removing force on the tires. Opposite would be the case ( and how most cars are from the box) if the drive shafts are angled upwards towards the wheel. This would force the arm down exerting more force on the tire.
Old 09-11-2014, 06:22 AM   #1316
Thanks Cristian.
The fact that it is something that you rarely adjust, is enough for me to leave at standard mid/low myself and concentrate on other adjustments.
Good to know how it works though
Old 09-11-2014, 04:36 PM   #1317
I personally have had great results with the front diff in the high position and the rear in the low position
ed
Edwin Pibal is offline   Reply With Quote
Old 09-12-2014, 09:56 AM   #1318
Rick Hohwart's Avatar
I run the diffs full low most of the time. I have found that raising the diff will give you more roll and traction on that end of the car.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 09-12-2014, 10:27 AM   #1319
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
Anyone that is interested I have some Hiro Seiko Titanium bottom and AE Blue alumn screw kits left from a big order I placed a few weeks ago. Shoot me a PM for details.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 09-13-2014, 06:45 PM   #1320
So my dad and I are considering a return to on road after a 15 year hiatus. I am considering the tc6.2 or the detc410. Granted this is the tc6.2 thread I want to know why I should choose this platform over the durango?
RBraswell is offline   Reply With Quote
SEO by vBSEO 3.5.0
