Old 08-04-2014, 09:54 AM   #1276
CristianTabush's Avatar
Originally Posted by TJames987 View Post
any tips from the pro's on how the free up their 6.2's for more corner speed and less pushy on a large parking lot track?
I am running Yokomo yellow front and rear blues with basically the kit setup except for inner holes on the bulkheads for camber links (long link)
Narrow up your car a bit in the rear and add some front arm sweep. I would run the suspension mounts like this:
FF
Fr
RF
Also, raise your roll center to 1mm under all mounts. This will increase the reaction time of the car helping it gain overall traction and steering.
Go to short links all around, it will again allow the car to react quicker and switch directions faster.
If you are running the stock rear diff oil, I would try something heavier. I was running 3000cst on a medium grip parking lot and the car felt better than with 1500, which is already heavier than the 40wt I think they suggest. So heavier should help.
The last couple of adjustments would be adding about 1 more mm of shims to your steering for a more aggressive corner entry and shortening your wheelbase in the rear and/or front. For a smaller turning radius and better low speed steering.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is online now   Reply With Quote
Old 08-04-2014, 10:27 AM   #1277
ViperZ's Avatar
Originally Posted by samnelso View Post
They're certainly a good thing for tracks that run boards. With curbs or dots servo saver isn't needed. With that said, I run them on my cars as well, although I'm not sure if they actually help mitigate breakage. Today's servos certainly are not going anywhere and I probably run them more out of habit that anything. Note, offroad does not use them.
BTW your cars look good and nice camera work.
Makes sense, thanks for that and your comments on my cars! I'm just getting back into the 1/10 competitive car scene and have a lot to learn.
Some of you here have the car setup down to a science!
So I ended up going with another RS Gen 2 ESC and a 13.5 Redline to try the Super Stock Class... I was so wanting a RSX, but our track isn't big enough for modified, and I can't see myself really running in that class at big open events... Walk before I run
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 08-12-2014, 08:45 PM   #1278
Default Rear Diff Clearance
Hi I am new to RC and have just built the TC6.2, and have notice the rear diff spool is almost touching the chassis, is this normal?
AE Driver is offline   Reply With Quote
Old 08-13-2014, 09:30 AM   #1279
samnelso's Avatar
the flange of the gear diff gets very close to the side of the cutout in the chassis, but should not be touching. Mine, with the mid-low cam adjusters, is maybe .010-.015" from touching.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 08-14-2014, 10:09 AM   #1280
Questions??
Hey guys!! I've been around on road for a long time , stepped away about 10 years ago possibly longer! I used to be into 1/8 on road and 1/10 touring (carpet). I purchased the 6.2 around Christmas or New Years, and have been pleasantly surprised, so I decided to upgrade a few things! I know there's nothing wrong with the gear diffs, but I saw a pic, which I can't find now, and it had a white gear differential housing, I'm not sure if it was on a 6.1, or 6.2, but I guess that doesn't matter considering the similar drive trains! I just wanna know if anyone knows what car they came from, and also what manufacturers have differentials that fit into the Associated machine? Any help would be greatly appreciated! I went through all 80+pages trying to find the post, with no luck!
im2tall is offline   Reply With Quote
Old 08-14-2014, 11:36 AM   #1281
AE-Reedy
Tamiya uses a white diff housing. AE are all black.
Sean Cochran is offline   Reply With Quote
Old 08-14-2014, 01:22 PM   #1282
Thumbs up
Thanks for the feedback!
Old 08-14-2014, 10:33 PM   #1283
samnelso's Avatar
Gents,
I felt compelled to put together a build tips video over the course of my latest build. Mostly for fun I suppose, but nonetheless I hope some find it useful. Check it out, like, comment, and share.
+ YouTube Video
Old 08-15-2014, 03:26 AM   #1284
ViperZ's Avatar
Nice, Thanks Samnelso!
Old 08-15-2014, 04:57 AM   #1285
hanulec's Avatar
Trader Rating: 27 (100%+)
very cool Sam.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-20-2014, 04:14 AM   #1286
ViperZ's Avatar
I finished my TC6.2 last night. Looking forward to testing it at the club. Just need a servo saver as the Racers Edge one is too big in diameter. Hopefully I put it together right....
Old 08-20-2014, 05:54 AM   #1287
TJames987's Avatar
Trader Rating: 10 (92%+)
anyone else having trouble with your front toe going way out of whack for no apparent reason. ive had to put it on the gauges almost every race and found that i went from 0 toe out to like 4 or 5
anyone else have this issue?
TJames987 is offline   Reply With Quote
Old 08-20-2014, 06:17 AM   #1288
OttoKrosse's Avatar
Sounds like your ball cups are moving on the turnbuckle, likely due to the threads on the turnbuckle are not holding firm in the ball cup.
My rear ball cup on the right side kept getting knocked out of whack almost every run, simply change the ball cup and be sure to slowly thread the new ball cup onto the turnbuckle.
The threads on the Associated turnbuckles are not very deep so knocking them out of whack is only a matter of time. There are heavier turnbuckles, balls and ball cups out there if the problem persists.
This space for rent.
Oo=00=oO
OttoKrosse is offline   Reply With Quote
Old 08-20-2014, 10:37 AM   #1289
Trader Rating: 41 (100%+)
Originally Posted by ViperZ;13479501[URL=http://s1338.photobucket.com/user/byfung/media/RC%20Touring/DSC_4052_zpsec43de42.jpg.html
[/URL]
Your build looks great!
Are those blue aluminum battery holders? Where did you get them from?
markpoleon is offline   Reply With Quote
Old 08-20-2014, 11:21 AM   #1290
Castradamus's Avatar
Trader Rating: 53 (100%+)
I believe those are the AE battery hold down:
http://www.teamassociated.com/parts/details/31645/
Destiny | Xenon USA | Speedzone | High Velocity RC | TQ Wire | dIgItS pAiNt
He who is not courageous enough to take risks will accomplish nothing in life. - Muhammad Ali
Castradamus is offline   Reply With Quote
