Team Associated TC6.2 Touring Car >
Like Tree3Likes
Old 07-26-2014, 01:41 PM
  #1246
wtcc's Avatar
I am using the 13lb springs from RSD. If your track is not really dusty I wouldn't go any softer. The green AE are 11.5lb. If you have grip roll go softer, if not try harder (springs) In the end it is not so easy to recommend from far away. In doubt, try it yourself. Suspension dynamics are very complicated and hard to predict.
Some more words to my steering conversion:
1. It works pretty fine on track!
2. For maximum precision you need to get rid of all the slop in the steering assembly, because the link from servo to steering brace is changed from servo to steering arm. In my case the original kit shims are 0.3mm too short and the bushing too long. This leads to little, but disturbing direction changes.
Nevertheless, with these changes plus just 1mm shims under the arm mounts all around, I could better my personal best around 150 thousands of a second
wtcc is offline
Old 07-28-2014, 09:02 AM
  #1247
NutDriver's Avatar
Trader Rating: 30 (100%+)
Would someone be so kind as to direct me to a good baseline setup for USGT on carpet for this chassis?
Thank you in advance.
Scott
NutDriver is offline
Old 07-28-2014, 03:07 PM
  #1248
JRnotEwing's Avatar
I started with Andrew Cartwright's sedan setup off the associated site as a baseline and have been tweaking from there in my USGT
http://www.teamassociated.com/cars_a...anuals_setups/
Scott
JRnotEwing is offline
Old 07-28-2014, 04:44 PM
  #1249
turtlehill's Avatar
Default Green Springs
Originally Posted by Trav515
Has anyone tried the green rear springs vs the silver? If so would the greens be better for a low to med asphalt track that has 180 degree corners and is very technical? I am running 30wt oil in the front with 30 in the rear with front and rear gear diffs.
Thanks Travis
TC6.1
I was using the AE green springs on the rear but I switched to the RSD TC6.2 white(13lb) and I like that better. The light blue(14lb) works well too. The spring set comes with 13,14,15, and 16 lb. springs. $22.99 at Reflex Racing.
turtlehill is offline
Old 07-28-2014, 06:47 PM
  #1250
NutDriver's Avatar
Thank you, JR.
Scott
Old 07-29-2014, 11:59 AM
  #1251
Default TC 6.2 Steering Blocks
Anyone know who has aluminum steering blocks for the 6.2? I've looked all over the web and can't come up with anything. Would like to find some to help eliminate ball stud thread stripping, and they would be more durable all the way around.
Thanks,
Jerry B.
boylrmakr is offline
Old 07-29-2014, 12:10 PM
  #1252
Trader Rating: 177 (100%+)
Thanks,
Jerry B.
Just get longer ballstuds. the 12mm ones work well
thecaptain is offline
Old 07-29-2014, 05:39 PM
  #1253
ViperZ's Avatar
Good thing I've been following this thread! Here's my club card beside the TC6.1
ViperZ is offline
Old 07-29-2014, 07:52 PM
  #1254
samnelso's Avatar
My new kit arrives tomorrow. Can't wait
samnelso is offline
Old 07-29-2014, 10:18 PM
  #1255
Thanks for the input. Guess I'll have to stick with the delrin.
Jerry B.
Old 07-30-2014, 05:48 AM
  #1256
Default missing parts
I received mine yesterday and started to build...I then realized I was missing bag BB from the kit....anyone know who to contact about getting this bag??
FireRacer88 is offline
Old 07-30-2014, 08:13 AM
  #1257
Call Associated and let them know. They'll send it right out.
Carnage9270 is offline
Old 08-01-2014, 05:37 AM
  #1258
Any one that has used this car for VTA??? if so anyone have a good starting setup for carpet....I know there are plenty of setups for the 6.1 but Im looking for one from anyone that used a 6.2
Old 08-01-2014, 07:52 AM
  #1259
Pauly6401's Avatar
Trader Rating: 53 (100%+)
Someone about 10 posts up asked the same question for USGT. Probably a good starting point.
http://www.rctech.net/forum/13430277-post1248.html
Pauly6401 is offline
Old 08-01-2014, 07:59 AM
  #1260
I use Andrew Cartwright's setup for Scale Spec (VTA with looser rules) works fantastic. Like glue on the track.
