Old 07-24-2014, 05:27 PM   #1231
Originally Posted by LAGuy View Post
On Bob’s RROC 6.2 setup, he lists the front gear diif oil as “silicone ear plugs”. Can someone let me know what that is? And inner/outer ball and shims is listed as “silver +1” etc. What does silver refer to? Thanks!
silver refers to the color of the ball stud. silver or black. I think the silver is a little taller than the black.
DOTMAN is offline   Reply With Quote
Old 07-24-2014, 06:56 PM   #1232
can someone tell me the pros and cons of using shock fluid or diff fluid for rear diff and what weight would be good for 25.5 vta?
gearit is offline   Reply With Quote
Old 07-24-2014, 08:23 PM   #1233
Trader Rating: 45 (100%+)
As compared to a ball diff? I believe there are many videos regaurding this on youtube as well as many blogs the simple version is its much better and easier to tune with. Start with 2000 weight and if you need more onpower steering try 3000 keep in mind going up in weight will increase onpower steering but decrease lower speed steering, as well may cause the rear end to slide low speed, or at the beginning of acceleration.
thecaptain is offline   Reply With Quote
Old 07-24-2014, 09:33 PM   #1234
I would go with 2000wt oil in the rear
_____________________
TC6.2 MUCHMORE FLETA PRO MUCHMORE FLETA ZX 4.5
HITEC SAVOX SPEKTRUM
onroad racer is offline   Reply With Quote
Old 07-24-2014, 10:12 PM   #1235
Originally Posted by onroad racer View Post
Here is the link to the ear plugs, this is what Rick uses
http://www.drugstore.com/products/pr...rk=g&matchtype
Thank you, but how do you use these inside the gear diff?
LAGuy is offline   Reply With Quote
Old 07-24-2014, 10:13 PM   #1236
Thanks! I bought the kit used and still figuring everything out
Old 07-24-2014, 10:18 PM   #1237
YoDog's Avatar
Trader Rating: 25 (100%+)
Originally Posted by WildManDriving View Post
Hello all,
I have just purchased and started build my first AE TC getting the 6.2. I'm most likely have many questions to follow but start with are there other brands on gear diff's that fit and does the TC6 ball diff fit the .2?
M.Ellis
The. AE gear diff is quite good so why ask about aftermarket? You should be able to fit the ball diff but it may bind but once again... Why use a ball diff when the gear diff has proven to be the better choice?
The car is quite competitive right out of the box. There are some bits and pieces that make the car more durable and perhaps more consistent but the best advice is to take your time, build it right and use the box stock setup to learn the car then work with some of the team setups if the track conditions are similar.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 07-24-2014, 11:04 PM   #1238
GizmoTLR's Avatar
I ran the out of the box normal manual setup on my track (medium high grip hot asphalt) and i could not keep a solid line. It would push in turns like crazy both on and off power. I tried changing my driving style all the time and still couldnt get it. After hours of changing the shock angles, roll center geometry, droop, different oils (diff and shock), springs, roll bars, wheel base, and some help from WTCC here on the forums i was finally able to get it to stick on the track. Im sure the outcome is different for everyone depending on their track but for me it was nothing but a headache. But on a positive note it was a great learning experience considering iv never ran on road before.
B5M
B44.3
8.2e
GizmoTLR is offline   Reply With Quote
Old 07-25-2014, 12:17 AM   #1239
He said he just cuts them up and work them into the diff, i tryed and i would prefer oil rather then the ear plugs
________________________
Old 07-25-2014, 04:03 AM   #1240
wtcc's Avatar
I want to share some small changes.
One thing that is a little annoying, are the oversized lipo brace dimensions. My Reedy battery has around 2mm space in every direction. Together with only one stopper in the middle of the chassis the battery can rub against the belt. The tape should hold the battery tight, but it is not working in every situation. I dremeled two cf braces. The rear one has an inside stopper added and the dimensions are optimized:
Another change applies on the steering. The 6.2 steering arms are located high compared to some other TCs. Fitting the steering brace under the arms will lead to belt rub. Turning the steering arms around and then fit the brace underneath will work perfectly. The next problem that occurs is the steering links rub against the inner armmounts. I was somehow lucky, as I drive the shortest possible wheelbase in front. This way it works
And my new body
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 07-25-2014, 11:02 AM   #1241
Wouldn't flipping the steering rack over like that have a significant affect on ackerman?
Also, how are you running your wires under the top plate and not have them affect the flex. Every time I've tried to do that the wires end up touching when it flexes.
-Mike B.
Carnage9270 is offline   Reply With Quote
Old 07-25-2014, 01:41 PM   #1242
wtcc's Avatar
No. Ackermann is not defined in height difference.
I use smaller diameter wires than normal, as it makes no difference on track (length makes the difference) for blinky stock. And I filed away the egde on both sides of the topdeck to get a wider gap.
Old 07-25-2014, 02:30 PM   #1243
Bubblehead's Avatar
GizmoTLR you have a PM.
I ran my car stock set-up and so far so good I will be at the track tomorrow for more testing.
Bubblehead is offline   Reply With Quote
Old 07-25-2014, 02:45 PM   #1244
ViperZ's Avatar
Nice mods to the TC6.2, WTCC!
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 07-26-2014, 10:05 AM   #1245
Has anyone tried the green rear springs vs the silver? If so would the greens be better for a low to med asphalt track that has 180 degree corners and is very technical? I am running 30wt oil in the front with 30 in the rear with front and rear gear diffs.
Thanks Travis
TC6.1
Trav515 is offline   Reply With Quote
SEO by vBSEO 3.5.0
