Old 07-12-2014, 07:29 PM   #1186
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Thumbs up
Originally Posted by Rick Hohwart View Post
This is correct. TC4 arms in the rear but TC5 arms in the front with a re-drilled shock position.
Rick do you have any pics on how and why this is being done
Is this just for mod / stock ? ???
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 07-13-2014, 03:25 AM   #1187
GizmoTLR's Avatar
Originally Posted by Bubblehead View Post
GizmoTRL, I'll be looking for you at Debbies, then there will be two.
Ron
Looking forward to it. The turnout has been great so far since the track has been done, probably the best iv ever seen since i got stationed here and found Debbies. I pit outside near the corner of the building, fell free to stop by and say hey. I will be there the 25th and 26th but i wont be racing on the 26th. Ill just be turn marshaling and working on my mod setup for the big race in a few weeks getting some practice laps between heats.
B5M
B44.3
8.2e
GizmoTLR is offline   Reply With Quote
Old 07-13-2014, 01:03 PM   #1188
Bubblehead's Avatar
You pit next to Tony?
Bubblehead is offline   Reply With Quote
Old 07-13-2014, 04:29 PM   #1189
GizmoTLR's Avatar
Yep. I pit by Tony, Phil, Andrew, and Jamison
B5M
B44.3
8.2e
Old 07-13-2014, 05:00 PM   #1190
Bubblehead's Avatar
I'll look for you there.
Old 07-15-2014, 04:47 PM   #1191
GizmoTLR's Avatar
Is there a certain gear diff to put in the front to replace the spool? I bought a Spec-R diff and put it in the rear and put the original rear gear diff in the front and now the entire casing wont move. Do i need to do anything different?
B5M
B44.3
8.2e
Old 07-15-2014, 04:58 PM   #1192
turtlehill's Avatar
Default Front gear diff
Are you sure you have it oriented correctly? It should just drop straight in. You may also want to go to a much stiffer gear oil for the front. 2.5M works for me.
turtlehill is offline   Reply With Quote
Old 07-15-2014, 05:30 PM   #1193
Trader Rating: 86 (99%+)
What do you mean entire casing?
thecaptain is offline   Reply With Quote
Old 07-15-2014, 06:36 PM   #1194
GizmoTLR's Avatar
Im running 100k in the front diff. The outputs and gears inside move normally. I dropped the diff in the bluk head with the same settings as the spool (low cam, 8 tension) and it does not spin in the bulk head. Its frozen so much that my 6.5t motor cant even spin it. But as soon as i put the spool back in, it moves just fine.
So again, is there a different diff housing that needs to be used for the front? Or can i just use the rear one since i have the Spec-R in the rear?
what are u using for 2.5m fluid? Link and description please?
B5M
B44.3
8.2e
Old 07-15-2014, 07:03 PM   #1195
http://www.teamgravityrc.com/store1/...29&id=26632441
-Mike B.
Carnage9270 is offline   Reply With Quote
Old 07-15-2014, 07:09 PM   #1196
Mine rubbed on the rear shock tower, check to make sure its clearing. Also make sure that your belt tension isnt crazy tight. It might change from spool/gear diff. Also make sure it spins freely before you put the upper bulkheads on. Also make sure that you dont have a bent bulk head upper/lower or a broken/twisted shock tower. Maybe you have a major tweek in the front bulkheads?
Old 07-15-2014, 07:49 PM   #1197
ViperZ's Avatar
When is the next version upgrade expected from TC6.2?
I have a TC 6.1 NIB, that I've been contemplating building up for VTA, and getting a new chassis for TC stock class racing. I have been considering a 6.2, but could wait for the next version.
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 07-15-2014, 11:11 PM   #1198
wtcc's Avatar
AE wasn't in a hurry with new versions in the past. The 6.3 or 7 will be released by the end of 2015, if they continue their rhythm. What I can imagine is an upgrade kit with optimized parts after the world championship. Maybe an aluminium chassis...
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 07-16-2014, 06:19 AM   #1199
ViperZ's Avatar
^^ Thanks. What's with the movement to aluminum chassis?
Old 07-16-2014, 07:05 AM   #1200
wtcc's Avatar
Not sure about it... At first I thought it should bring the weight lower to the ground, but then the manufacturers make them as light as the standard cf chassis. Then I thought it brings flex characteristics for highgrip conditions and therefore has an advantage, but commercial says it is good for low grip also So I don't know.
What I know is that it changes the car and that some drivers like it or it suits their cars setup... Until now I haven't seen someone in my region becoming faster with one. Lets wait for Christians (RSD) explanation
