Old 11-24-2013, 10:52 AM   #106
wtcc's Avatar
That was my experience, too. Wasn't happy about it. Even the shrink stuff didn't prevent the pin from leaving its place...
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 11-24-2013, 11:21 AM   #107
chevtech23's Avatar
Currently running Stock AE cvs up front, no chatter at all, maybe people are running their EPA really far out?
I ran RSD v2 axles all summer on pavement up front, shrink wrapped, never had an issue, never had them apart till i pulled them out for a rebuild after 4 months of running. I did have increased inner wheel bearing wear due to the smaller size. what version are you guys talking about? pay attention to what direction the clips go, follow RSDs directions
chevtech23 is offline   Reply With Quote
Old 11-25-2013, 09:55 AM   #108
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Amain has a 12/15 release date posted....
Kyle Predmore
Facebook - "AE Fanboy"
B6D|B64D
TC7|TC6TEK|12R5.2|10R5.1
Logi Maker is offline   Reply With Quote
Old 11-25-2013, 01:24 PM   #109
rc car guy's Avatar
I had the first version I put thr together as directed a couple other guys had the same results
rc car guy is offline   Reply With Quote
Old 11-25-2013, 01:32 PM   #110
Trader Rating: 28 (97%+)
a little early, considering the car isnt out yet
I was told the tc6.1 uses the same front bumper system, I did not know they were different, thanks for the info
zaraz is offline   Reply With Quote
Old 11-28-2013, 03:55 PM   #111
Monsta's Avatar
Originally Posted by evochick View Post
The other thing you can do to remove some of the slop from the C hub and rear hub is to put a grub screw in the bottom of them,
I went to all the trouble of polishing my hinge pins so they move freely within the arms, this plus the grub screw i get absolutely no play + very free movement. It only takes 2 seconds to do.
So because i wanted to try something different i purchased a yokomo bd7, guess what after a few weeks of racing i have a play in the c hubs, ok not quite as much as unglued associated c hubs, but play non the less.
Some easy mods to make any 6.1/6.2 better for serious racing (im sure Rick has posted these before)
1) the above mod
2) reflex bladders in shocks
3) reflex 3x1.1 pistons
4) drill a small hole in your top shock cap
5) reflex or new associated drive shafts
6) steel spool outdrives (reflex ones were ok but didnt last long in Mod, yokomo/spec R spool was a little better)
Beth.
thanks for the grub screw tip, works a treat
BD7 '14 / Trinity / LRP / SANWA
F1R2 / Reedy / Hobbywing / SANWA
1:1 racer
HR31 Skyline - 350Kw RB30DET, 1130kg and 255 wide R comp tyres... needs more traction!
Monsta is offline   Reply With Quote
Old 11-29-2013, 10:30 AM   #112
Svendc's Avatar
Hi, one thing disappoints me on the new TC6.2. The same spool assambley as the TC6.1.
I find the slipperspool of the TC5 far better and more durable than the stock one.
Besides that i lovethe TC6.(1)2. Easy to adjust and handles very nice, without all the overkill like the MI5.
gtz
Sven
Svendc is offline   Reply With Quote
Old 11-30-2013, 09:17 PM   #113
rc car guy's Avatar
So which motor would you guys use for 17.5 tc including rotor and stator
Old 12-01-2013, 09:58 AM   #114
rangerjkb's Avatar
Trader Rating: 36 (100%+)
Send a message via MSN to rangerjkb
Really like the new design and may have to look closer at racing using AE chassis again! Can't wait to see it on the track soon.
Jason Burks
Murfdogg Products~Psycho Cells Racing~Hal's Hobby Warehouse~Avid RC~Kal-Gard~VP Powermaster
rangerjkb is offline   Reply With Quote
Old 12-01-2013, 10:38 AM   #115
DARKSIDE's Avatar
come on back Jason....how have you been?
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Scale Nationals
Windy City RC in Arlington Heights IL
April 8-9
DARKSIDE is offline   Reply With Quote
Old 12-01-2013, 10:50 AM   #116
wtcc's Avatar
I just came back from the LRP-HPI-Challenge. The qualifying and A-Finals were full of Awesomatix, Xray T4'14, Yokomo BD7 and Mi5. I took TQ, but ended up 3rd in the finals after some bad luck. It will be interesting to see if the TC6.2 will be faster than the TC6.1WC, after all chassis seem to be at the same speed level... If so
AE / Reedy / RSD
Old 12-01-2013, 06:29 PM   #117
rc car guy's Avatar
so are some of the options part for the 6.2 compatible with the 6.1? such as the dcj? or maybe the bellcranks/floating sevro, and motor mount?
Old 12-01-2013, 07:22 PM   #118
evochick's Avatar
I suspect the dcj's and steel spool outdrives, but everything else no.
UnRetired
evochick is offline   Reply With Quote
Old 12-06-2013, 05:16 PM   #119
Any possibilities the quality of the fit and finish of the plastics may be different? I know my WC out of the box came with slop. Just want something you don't have to put set screws in and all.....Just hoping
daveb is offline   Reply With Quote
Old 12-07-2013, 08:02 AM   #120
John Tag's Avatar
Trader Rating: 41 (100%+)
Looking forward to getting my kit's..Should be a great 2014..............
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
