Old 06-24-2014, 04:41 PM   #1141
AE-Reedy
Originally Posted by GizmoTLR View Post
kinda wish u would of posted this 3 hours ago lol, i purchased 2 bags total, oh well
i like overkill
one more stupid question from this noob... whats a good fan to run? right now i have my LRP Flow ESC fan rigged up behind it (i used an old spare b4.2 servo mount). Will that fan be enough or do i need something better?
Well now you have spares.
Fan, the LRP fan will be better than nothing but not the best you can do.
I guess it just depends on how hot it is where you run and how aggressive you are with your motor settings. I use the Superior Hobbies fan, it's expensive, but the best fan I've seen. I accidentally stuck my finger in it, broke my nail and cut the skin, so it's tough.
Sean Cochran is offline   Reply With Quote
Old 06-24-2014, 04:53 PM   #1142
samnelso's Avatar
Hanulec's WTF fan is baller. Fairly local to you as well. http://www.wildturbofan.com/
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 06-24-2014, 05:29 PM   #1143
http://www.sweepracingusa.com/Sweep-...ler_p_477.html
-Mike B.
Carnage9270 is offline   Reply With Quote
Old 06-26-2014, 09:44 AM   #1144
Default LRP Cooling Fan for the TC6.2
I just purchased the LRP 1/10 Scale Radical Cooling Set for my touring car.
I run 17.5 tekin redline motor.
My fan doesn't really fit, I was wondering if this is a common occurrence in alot of touring cars with this product. My solution was to take the side rails off and double side tape the fan to the chassis.
If I run my old LRP motor (the solder tabs point up instead of angling inward as the redline does) then the thing fits. I want my redline motor since I think it is a better motor.
anyway my question is; do I really need a fan in 17.5? is it just as well to stick with a heatsink and no fan? If a fan is desirable, can I get away with my aforementioned setup? If not, should I get the Associated fan; mind you it doesn't come with a heat sink; but I have one of those anyway. Some setups have a fan and no heatsink.
I really don't want to spend more money on an option I don't need in the first place so I am curious for some input on my fan problem here.
irvinew is offline   Reply With Quote
Old 06-26-2014, 10:33 AM   #1145
wtcc's Avatar
A fan in 17.5t makes sense! I am personally no heatsink fan, as I don't see any advantage. Use the fan without heatsink. If you have the L-shaped part from the motormount as spare then you can use it as fanmount. This will hold up better than the tape
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 06-26-2014, 01:00 PM   #1146
GizmoTLR's Avatar
i used a servo mount from a B4.2. works perfectly
B5M
B44.3
8.2e
GizmoTLR is offline   Reply With Quote
Old 06-26-2014, 01:38 PM   #1147
Thanks I have one of those; very helpful.
Old 06-27-2014, 12:21 PM   #1148
jpx
jpx's Avatar
currently I use a very good silicon tape and was happy - untill I read that!
Thanks for this easy idea - easy usually ist the best!
I still have several mounts form TC5 etc. ...
AE TC7 / 17.5T blinky GT
WRC f-one '016 / 21.5T F1
jpx is offline   Reply With Quote
Old 06-27-2014, 01:12 PM   #1149
wtcc's Avatar
Das klingt, als ob du zu wenig Zeit für dein Hobby hast
AE / Reedy / RSD
Old 06-27-2014, 01:18 PM   #1150
Whoa...
-Mike B.
Old 06-28-2014, 04:50 AM   #1151
jpx
jpx's Avatar
so isses - leider ...
bisher draussen 3 nachmittage Training und 2 Cup-Rennen ... is nicht viel
Old 06-28-2014, 08:12 AM   #1152
JayBee's Avatar
Trader Rating: 31 (100%+)
Default Its gotta go....no time
If anyone is looking for a slightly-used 6.2 (2 racedays on carpet), look me up. I will list everything pretty soon, just giving ya a heads-up. A pic of the car is in post #533, if you need to see it
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-28-2014, 10:22 AM   #1153
wtcc's Avatar
Schade... Ich fahre gerade auch fast 90 Minuten zur Outdoorstrecke schön zu wissen, dass du noch mitliest
AE / Reedy / RSD
Old 06-28-2014, 02:53 PM   #1154
GizmoTLR's Avatar
uhhhhhhhhhhhh.... anyone understand that? lol
B5M
B44.3
8.2e
Old 06-28-2014, 06:34 PM   #1155
JimmyMac's Avatar
Google translate...
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
