Old 11-21-2013, 02:21 PM   #91
the ae shocks on the tc6 were really painful to get right, but when i drilled a hole in the cap and switched to rsd bladders they became as good as any other top manufactures shocks, that made a big improvement when i drove the tc6.1
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 11-21-2013, 06:56 PM   #92
MostlyTorso's Avatar
Originally Posted by Rick Hohwart View Post
...With the AE car, this means gluing the inserts, using grub screws on the hub carriers and caster blocks (like evochick), and using shims on hinge pins.
The movement you describe might be a combination of several things. I think that using a grub screw (drill hole after inserts are glued) will fix most of this. You can shim the c-hub with a thin washer...
Really good advice (both Rick and Evochick)! Thanks so much--Now I have some work to do.
MostlyTorso is offline   Reply With Quote
Old 11-22-2013, 11:35 PM   #93
Hey I'm kind of set on a used 6.1 but the only thing I'm worried about is parts. Are most of the 6.2 parts going to fit on a 6.1, I'm assuming most would but I'm only a year in.
lee111m is offline   Reply With Quote
Old 11-23-2013, 06:27 AM   #94
Trader Rating: 72 (100%+)
The parts that take the brunt of an impact (e.g. caster blocks, hubs and control arms) are very readily available and are interchangeable between the TC6.1 and TC6.2.
waswadener is offline   Reply With Quote
Old 11-23-2013, 06:35 AM   #95
Trader Rating: 18 (100%+)
Aluminum parts and CF are new, most of plastic are the same.
thejo3 is offline   Reply With Quote
Old 11-23-2013, 03:13 PM   #96
Trader Rating: 28 (97%+)
Originally Posted by zaraz View Post
just pre ordered mine, does any one make a carbon front bumper support for this kit, I am a Tamiya person, this will be my second ae, I did have a tc3 back in the day, like to bling out my rc cars, thanks
anyone
zaraz is offline   Reply With Quote
Old 11-23-2013, 05:48 PM   #97
chevtech23's Avatar
anyone
a little early, considering the car isnt out yet
chevtech23 is offline   Reply With Quote
Old 11-23-2013, 10:04 PM   #98
rc car guy's Avatar
So whats different about this chassis compared to the 6.1 wc?
rc car guy is offline   Reply With Quote
Old 11-23-2013, 10:23 PM   #99
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Arm mounts, motor mount, dual bell crank, transverse servo mount...
Www.Rc10.com
Kyle Predmore
Facebook - "AE Fanboy"
B6D|B64D
TC7|TC6TEK|12R5.2|10R5.1
Logi Maker is offline   Reply With Quote
Old 11-23-2013, 10:23 PM   #100
rc car guy's Avatar
yes i can read the summary of the car, i meant if its narrower or thicker or something like that
Old 11-23-2013, 10:37 PM   #101
Logi Maker's Avatar
Looks to be the same as the WC with a few more holes for the arm mounts...
Kyle Predmore
B6D|B64D
Old 11-23-2013, 10:52 PM   #102
rc car guy's Avatar
cool thank you, cant wait to see how it performs guy at my track was talking about maybe getting one
Old 11-23-2013, 11:24 PM   #103
Logi Maker's Avatar
Being an AE guy since I started with a TC5 I have completely hated the arm mount sytem and the new version is a reason enough for me. Can't beat a new kit and the support from the numerous drivers... It's going to be a great car and the only thing I wish is that it came with all the bells and whistles offered separately. .. main ones being the DCJs and the ti ballstuds..
Kyle Predmore
B6D|B64D
Old 11-24-2013, 01:33 AM   #104
wtcc's Avatar
I often ask myself why many are wishing for DJCs...
I tried two different DJC designs and compared them on track with the standard kit cardans. The quality of the TC5 and TC6 axles was bad, they bind early and caused a bad chattering. Since the TC6.1 the cardans became much better, have nearly no noticeable binding at a full steering angle (if build and manufactured correctly). The effect on the timesheets and car feeling with a DJC is therefore zero.
So my choice for the TC6.1WC is the kit cardan as it causes no trouble and has long maintenance intervalls (and came with the kit ).
So had you guys much trouble with the kit cardans?
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 11-24-2013, 10:02 AM   #105
rc car guy's Avatar
i bought some from rsd and the dam pin kept falling out, so i quit running them also they weigh more= more rotational mass= less speed/more heat
