Old 04-27-2014, 02:48 PM   #991
CristianTabush's Avatar
I think the benefit of the aluminum is not only the weight, the frequency of the chassis flex is different and that makes the car different I guess. Making a compound chassis could be an option, but maybe overly complex.
The change from one chassis to the other is time consuming, but I don't think it is something that you can rally worry about. For those with 2 cars, an option is to have one with each type of chassis. For those that don't, it's a matter of making a commitment to tuning the aluminum chassis, much like they maybe committed to the carbon right now. As I always say, it is an option that gives you different tuning possibilities.
As for the tires, yes, it seemed like at first it was heating the tires a little bit more, but I raised the inner camber links to 3mm from 1mm in the rear and to 4mm from 2mm in the front and the problem went away. I guess less camber gain and a lower roll center help out.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 04-27-2014, 04:17 PM   #992
My dad filmed this yesterday in one of my runs. Quality could be a little better, but you can see the car getting around the track really well.
https://www.youtube.com/watch?v=detD...ature=youtu.be
Old 04-27-2014, 04:26 PM   #993
Car looks really good, so quick through the in field
________________________
TC6.2 MUCHMORE FLETA PRO MUCHMORE FLETA ZX 4.5
HITEC SPEKTRUM RSD
onroad racer is offline   Reply With Quote
Old 04-28-2014, 11:02 AM   #994
Jorge T's Avatar
Car looked so good I'm getting one when the chassis come in!
RSD MS
Jorge T is offline   Reply With Quote
Old 04-28-2014, 11:27 AM   #995
I'm really excited about getting one myself. Then I have to wait for carpet season again
I don't think any of our asphalt tracks are considered "high bite".
-Mike B.
Carnage9270 is offline   Reply With Quote
Old 04-28-2014, 11:41 AM   #996
We'll have a carbon chassis a well. However I have a feeling the aluminum can work well on the asphalt as well.
Old 04-28-2014, 11:48 AM   #997
Yeah I'm really hoping for that. Loving the idea of not having to run the entire car though a detweek process after every tap or bump.
-Mike B.
Old 04-29-2014, 12:51 PM   #998
The more I watch this, the more I see how responsive this thing really is. Even clipping dots, the car doesn't even blink. Cristian, the work you do is amazing!
-Mike B.
Old 04-29-2014, 03:28 PM   #999
Tim Kowal's Avatar
R/C Tech Charter Subscriber
Default RROC Setup
Rick, Can you post your Tamiya track setup for those of us coming out to RROC, Thanks!
TEAM ASSOCIATED - REEDY - J CONCEPTS - RC3 GRAPHIX - KOOL AID - TEAM P-NUT MOTORSPORTS.COM - SUPERIOR HOBBIES.COM
Tim Kowal is offline   Reply With Quote
Old 04-30-2014, 07:28 AM   #1000
scoyle's Avatar
I may have missed this but the aluminum chassis is for the TC6.2 and not just for your own RSD car? Do you have a release date you are aiming for?
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 04-30-2014, 08:44 AM   #1001
It's just the aluminum chasssis. We also have a carbon one on the way. Both are designed to allow for more natural roll and pitch over the original unit. The parts should be ready tonship inside of 2 weeks.
Old 04-30-2014, 02:47 PM   #1002
turtlehill's Avatar
Default Roll Center
What shims are you using for the roll center? Does the chassis need a higher roll center than the carbon chassis?
turtlehill is offline   Reply With Quote
Old 04-30-2014, 04:00 PM   #1003
Currently I am running 0.5mm under the front mounts and 1.0 under the rear mounts.
I have not seen a need to change much from the carbon set up. However, with the chassis being 2.0mm instead of 2.25, the suspension mounts are automatically 0.25mm lower.
Old 05-02-2014, 01:16 AM   #1004
scoyle's Avatar
Chassis ordered, really looking forward to trying it...
Old 05-02-2014, 08:27 AM   #1005
I'm curious how you'd set this chassis up for med grip asphalt. I have my stock carbon chassis setup up with 3mm of shim all around. Curious how the aluminum chassis would react with that much shim.
-Mike B.
