Old 04-08-2014, 05:59 PM   #871
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by turtlehill View Post
Anyone interested in the Associated DCV kits, they are in stock at Superiorhobbies.com. $31.95 + $6.50 priority mail. DCV rebuild kit is also in stock - $6.95.
It appears that Stormer has them in stock as well.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 04-08-2014, 07:17 PM   #872
turtlehill's Avatar
Default Stormers
Saw them at Stormers, but they don't ship to Hawaii. I guess their priority mail doesn't reach us.
turtlehill is offline   Reply With Quote
Old 04-08-2014, 09:03 PM   #873
Hi there
What losi pistons shoild i run in the tc6.2
_______________
TC6.2 MUCHMORE FLETA PRO MUCHMORE FLETA ZX 4.5
HITEC SPEKTRUM
onroad racer is offline   Reply With Quote
Old 04-08-2014, 10:21 PM   #874
JustWill75's Avatar
Send a message via AIM to JustWill75
Originally Posted by onroad racer View Post
Hi there
_______________
HITEC SPEKTRUM
Losi 56
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 04-09-2014, 08:05 AM   #875
mike ivy's Avatar
Trader Rating: 50 (100%+)
Just Picked up a TC6.2 should be here soon.Looking for these Spring holders (see pic's) anyone know how has these in Stock cant find any here in the U.S online shops
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 04-09-2014, 08:16 AM   #876
Trader Rating: 108 (99%+)
After several hours of tedious and hard work put into my shocks I have finally found a way for these shocks to not suck air and work well. Here is this method
1. Replace bottom plastic shock bushing with one(s) that are 3.75mm thick.
2. Silicone the entire inside of the bottom shock make sure there is some on the underside of each bushing.
3. Rub your NEW silicone o-ring in silicone, make sure there is excess silicone around the o-ring
4. Make sure everything is seated properly apply a small amount of silicone over the last plastic bushing that goes into the bottom cap.
5. Apply a small amount of silicone on the o-ring that goes over the threads of the bottom of the cap.
6. Apply a small amount of thread lock to the threads on the shock body for the bottom cap.
7. Insert lightly oiled shock shaft into assembly.
8.Slowly tighten down the bottom cap until it is fully tightened(DO NOT TORQUE IT DOWN). Then slowly back off the bottom of the cap a while moving the shock shaft up and down. You are looking to hear a sucking sound. YOU DO NOT WANT THAT!!!!! After you hear that sound tighten cap until you no longer hear that sound. Then tighten it another 1/8-1/4 turn.
9. Put eyelet on (10mm in between eyelet and bottom of cap(more will push the bladder up and give you inconsistent results) and fill with oil.
10. Run piston up and down about 20 times to get the air bubbles agitated.
11. Leave the shock shaft 1/2 way up and put into shock pump.
12. Pump shocks and leave in the pump pressurized for 1 minute.
13. Run piston up and down about 20 more times to agitate remaining air bubbles, reset to 1/2 way in.
14. Pump shocks again and leave in shock pump pressurized for 1 hour.
15. Take shocks out and run them up and down 20 more times reset to 1/2 way in.
16. Put shocks back in shock pump for 5-10 more minutes.
17. Repeat steps 15-16 until no air bubbles come out of shocks when the piston is run up and down.
18. After no air comes out of the shocks let them sit for 10-15 minutes in the open.
19. Take diff shim and insert it under top of shock holder, between that and the bladder. This is to take up excess space in the top of the shock. (may have to file/sand to shock) I put mine on the top of the the top holder, in between that and the top cap, I had to sand the top down to fit it flush.
20. Take your bladder and put on top of recently built shock take the back side of your exacto knife, the not bladded side. Gently push down the bladder around the outside (DO NOT PUSH IN THE CENTER)
21. Run the piston up and down 2 times while making small circles around the outside pushing excess oil out of the shock.
22. Pull piston down all the way, and screw on top cap.
23. check for air, if you hear air, redo it.
Hope this helps
thecaptain is offline   Reply With Quote
Old 04-09-2014, 08:59 AM   #877
Rick Hohwart's Avatar
Default New setup posted
The following setup sheet from the Worlds Warm-up has been posted.
Rick Hohwart - Worlds Warmup - TC6.2
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 04-09-2014, 09:25 AM   #878
skyball's Avatar
They look like 3racing: http://os.3racing.hk/products.php?products_key=4590
Christian
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
skyball is offline   Reply With Quote
Old 04-09-2014, 09:28 AM   #879
skyball's Avatar
Thanks a lot Rick. How did you like the handling of the car on that big track? Was there anything especially good or bad about it?
When I interpret your setup right, you seemed to be looking for front grip, right?
Christian
Old 04-09-2014, 11:04 AM   #880
Christian
The car was pretty good and easy to drive. This setup is where I ended up for B-main legs 1 and 2 when the car felt its best and was fastest relative to others. I could use more front grip but this setup was pretty safe.
www.reedypower.com
Old 04-09-2014, 12:35 PM   #881
Trader Rating: 21 (100%+)
They are going to be in at http://www.reflexracing.net/ From what I was told last week.
Blue
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 04-09-2014, 12:40 PM   #882
mike ivy's Avatar
Cool Thanks.
Blue
Old 04-09-2014, 07:06 PM   #883
turtlehill's Avatar
Default Spring cups
RCmart has them in stock. $4.50 + shipping
Old 04-09-2014, 08:04 PM   #884
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
are you going to start off with this setup for Speedtech club race or you going back to your origonal setup for tamiya ?
King of B Main is offline   Reply With Quote
Old 04-09-2014, 09:07 PM   #885
I will use this setup but will likely use the diff setups from the original setup which I believe is 1 million front and 3k rear. Since we have a practice day I will give it a try as is first.
www.reedypower.com
