Old 04-02-2014, 03:00 AM   #826
John Tag's Avatar
Trader Rating: 42 (100%+)
I recently swapped to the X Ray servo saver..Its a really beefy unit. Its ultra strong and is slightly taller than most and allows a smooth wide steering curve. Getting 30* is no issue if needed. They are very strong and I have never seen anybody break one of those.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 04-02-2014, 07:31 AM   #827
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by jonston View Post
I agree with you here about the throw, I have been using the kawada servo saver because its taller. only problem is I keep snapping the pin, I run on carpet with pvc borders and it isn't very forgiving when you hit.
can you tell me where I can get the TM servo savers from? I might give them a try.
p.s your carbon battery mounts came and they work very well, I love the fact that that are higher then stock and holds the pack in better.
the battery stopper I feel could of been 1 or 2mm further out as it looks like its is sitting right on the belt line.
It's been a while since I bought any TM stuff but I used to order from their direct online store.
Thanks for the battery holder props! The stop is actually the same distance as stock so clearance shouldn't be an issue. If I moved it out any more, some batteries wouldn't fit. I run the thunder power 6000mah 65c race packs and they just fit without binding. No rubbing either. It's kind of a fine line... If too far out, the battery won't fit and the weight is shifted more to the right but if it's too far in, the belt will rub.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 04-02-2014, 07:33 AM   #828
YoDog's Avatar
+1 on that one John!
I use one on my pro10 pan car and it's one of the best I've used. I like the stacking spring design.
Old 04-02-2014, 07:33 AM   #829
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
For you AE guys TC6.2 Hiro Seiko titanium and blue alumn screw kits are on the way. Decided to go ahead and bring some in with the large following the TC6.2 has in the US.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 04-02-2014, 07:35 AM   #830
Trader Rating: 63 (98%+)
EA
Dang where were you last week when I pieced together an aluminum screw kit.
thecaptain is offline   Reply With Quote
Old 04-02-2014, 09:12 AM   #831
Team EAM
Sorry. I was working with Hiro Seiko trying to get them to build this kit and an Awesomaitx kit as its not something they were doing already due to lack of interest. I convinced them otherwise though! Sorry I was late on it though!
EA
Contact Us
Old 04-02-2014, 09:42 AM   #832
EA
True I only did it to reduce the rotation mass and the weight above the chassis, before the aluminum screws the car was 30 grams underweight. With the aluminum screws and aprox 49 grams on the chassis centerlined, I am only 2 grams over. No need to go to titanium to replace the ones under the chassis, as they are as low as it goes.
Old 04-03-2014, 05:43 AM   #833
skyball's Avatar
Originally Posted by Skiddins View Post
If you can stomach all the ad's and low res video it should be on LiveRC.
Skiddins
...well, there's nothing on LiveRC, but i found some news here: http://rcracingtv.net/2014/04/ifmar-...-warm-up-news/
Christian
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
skyball is offline   Reply With Quote
Old 04-03-2014, 06:58 AM   #834
Skiddins's Avatar
Christian
I seem to recall that LiveRC will be running sometime from Friday morning.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-03-2014, 04:07 PM   #835
RaceAce701's Avatar
Trader Rating: 83 (99%+)
ok everyone I am having violent traction rolling center to exit of corner
the car appears to be rolling over the rear and lifting an inside front tire
17.5 very high bite med tight layout
my basic setup
shocks
1.1 3hole
40wt front 35wt rear
yokomo blue springs front and rear
.5mm under all arm mounts
2dot out on all arm mounts
1mm infront of front arm
1mm behind rear arm
b hole front and rear arms
med length camber links 2mm on both inner 2mm under on rear hub
2mm droop over ride height
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 04-04-2014, 03:12 PM   #836
RaceAce701 - how are you building your shocks? Is there rebound or are you drill out the caps?
Andrew Cartwright
A_Cartwright is offline   Reply With Quote
Old 04-04-2014, 03:26 PM   #837
RaceAce701's Avatar
no rebound and the cap is drilled
Alex "ACE" Kubilus
ACE design works
Old 04-04-2014, 10:41 PM   #838
DARKSIDE's Avatar
thought I would share some update info on my TC6.2's...one I left completely box stock incl setup and the other, well added just about everything AE offers for an upgrade...here what I came up with
Ti Nitride Ballstuds
Part #: 31288,31291,31292 and 31293
Ballast Weight
Part # :31296
RC10TC6 Gear Diff
Part #: 31344
TC6.1 Ceramic Bearing Set
Part #: 31379
CF Arm Mount Shims, outer/inner
Part #: 31629,31630
DCV Kit
Part #: 31632
Belt Tensioner Kit
Part #: 31639
Fan Mount Set
Part #: 31640
Front Bulkhead Shim
Part #: 4617
Bearing, 5 x 10 x 3, metal
Part #: 91156
Servo Saver, XT/Futaba
Part #: 25162
96 tooth, 64 pitch Spur Gear
Part #: 4615
all of these add ons fit great and perform very well...I really like the fan mount and the fan seems to have plenty of air to cool the motor. The DCV kit is imo the most important upgrade to the original kit. All of these parts are on the AE site and worth looking into if you are looking for an upgrade to an already great chassis
http://www.teamassociated.com/cars_a...s_accessories/
Team Associated TC6.2 Touring Car-10.jpg   Team Associated TC6.2 Touring Car-3.jpg   Team Associated TC6.2 Touring Car-2.jpg   Team Associated TC6.2 Touring Car-7.jpg   Team Associated TC6.2 Touring Car-18.jpg
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Summer Slam
July 28-30
DARKSIDE is offline   Reply With Quote
Old 04-04-2014, 10:45 PM   #839
DARKSIDE's Avatar
more pics
Team Associated TC6.2 Touring Car-8.jpg   Team Associated TC6.2 Touring Car-9.jpg   Team Associated TC6.2 Touring Car-15.jpg   Team Associated TC6.2 Touring Car-16.jpg   Team Associated TC6.2 Touring Car-13.jpg
July 28-30
Old 04-05-2014, 02:28 AM   #840
skyball's Avatar
...2mm droop over ride height
Hey RaceAce,
I'd try less up travel (what you seem to call droop), like 1 to 1.5 mm.
Also from your description, the suspension seems to be too soft for the grip level, so slightly thicker shock oil (up to 50wt front) and / or harder springs may improve things. Also, what 3x1.1 shock pistons do you use? Many pistons from other brands (Tamiya...) don't really fit, because they have a smaller diameter and thickness then the original ones. I did'nt see stabilizers in your setup, do you use any (you should)?
Glueing the edges of the front tires might also help.
Christian
