Old 03-26-2014, 03:35 PM   #811
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by rossb View Post
I see you have both the 6.1WC and the 6.2. Is the 6.2 worth the $120 price difference for stock 17.5 touring?
It really depends on what level of racing you are at. The WC is a pretty good car and I still run mine all the time. Finally ran my 6.2 last weekend for the first time with good results. I put a setup on it and it was pretty good right away. I would say that the TC6.2 is more refined and has a bigger tuning window. I justified the extra cost because the new configuration is more in line with the state of the art in TC cars and I wanted to be more competitive on the bigger stage. The TC6.1 is enough of an improvement over the original 6.1 to be a good choice for your next car. Besides, you have spare parts already.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 03-26-2014, 06:12 PM   #812
JustWill75's Avatar
Send a message via AIM to JustWill75
It's worth every penny. I still have a TC6.1wc and it is a great car but but the 6.2 is so much better that like YoDog said, it should have been called the TC7.
Out of the box with no hop ups you can drive fast and with confidence. I just now started playing with other springs from Yokomo, ARC and RSD but that's it.....springs. The only thing I plan on adding to my car is the DCV drive shafts.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 03-27-2014, 07:48 PM   #813
TJames987's Avatar
Trader Rating: 10 (92%+)
Default why drill shock cap
Thanks for the response. Would drilling the shock caps be helpful in low traction high speed track conditions?
Originally Posted by mtbboy View Post
Hi.
the RSD bladders are made from a much softer material.
They aid in reducing the effect that the shock shaft has on oil volume as it fills the shock body by EASILY moving upward.
the holes in the shock cap further allow the bladder to move by decreasing an increase in air pressure in the air space above the bladder.
well worth the money .
DJC
TJames987 is offline   Reply With Quote
Old 03-27-2014, 08:11 PM   #814
Dan Hamann's Avatar
I felt it just helped with consistency regardless of traction levels. Air isn't fighting against the top of the bladder when the cap is sealed, even if it's only a slight pressure difference.
RCAmerica - Xray - Hudy - RC^2 - Motiv - Team EAM - Sanwa - Avid - Max.FX - Protoform - Pro-Line - Gravity R/C - Prolevel R/C - 2MM Designs
Dan Hamann is offline   Reply With Quote
Old 03-31-2014, 11:17 PM   #815
Trader Rating: 72 (100%+)
Does anyone have a copy of the setup Kevin Hebert used at Carpet Nats? If so, I would love to get a copy of your copy.
Bill S.
waswadener is offline   Reply With Quote
Old 04-01-2014, 12:02 AM   #816
LEM C's Avatar
Default SS
Do you guys use a servo saver or direct link per manual?
RC Cars-Lipos-ESC-Brushless Motors-Surface Radio-Carpet Track-Asphalt Track
LEM C is offline   Reply With Quote
Old 04-01-2014, 01:27 AM   #817
JayBee's Avatar
Trader Rating: 31 (100%+)
Servo saver for me bud.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 04-01-2014, 05:15 AM   #818
Hey guys
Are the spec r dvc any good and are they worth getting ?
_______________
TC6.2 MUCHMORE FLETA PRO MUCHMORE FLETA ZX 4.5
HITEC SPEKTRUM
onroad racer is offline   Reply With Quote
Old 04-01-2014, 09:02 AM   #819
YoDog's Avatar
I use a saver too. I prefer the Team Magic E4 saver. I gives longer throw and is a nice and tidy piece.
Old 04-01-2014, 10:18 AM   #820
DARKSIDE's Avatar
Originally Posted by DARKSIDE View Post
+1...
also Im using the Servo Saver, XT/Futaba and its working just as well as anything else out there
http://www.teamassociated.com/parts/details/25162/
works great
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Scale Nationals
Windy City RC in Arlington Heights IL
April 8-9
DARKSIDE is offline   Reply With Quote
Old 04-01-2014, 12:43 PM   #821
LEM C's Avatar
Default SS
Thanks a bunch guys.
Old 04-01-2014, 03:41 PM   #822
skyball's Avatar
...now that everyone is on their way to Orlando for the pre worlds warm up, i'm curious how Keven and Juho (and Rick?) running the TC6.2 will keep up with the other "big guns" there, for example Reinhard and Völker.
What do you guys expect? Does anybody know about a website where the event will be covered?
Christian
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
skyball is offline   Reply With Quote
Old 04-01-2014, 04:11 PM   #823
Skiddins's Avatar
Christian
If you can stomach all the ad's and low res video it should be on LiveRC.
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-02-2014, 12:33 AM   #824
skyball's Avatar
Skiddins
Thanks, will take a look. BTW, Rick is there too of course: https://www.facebook.com/photo.php?f...02692215838917
Old 04-02-2014, 03:20 AM   #825
I agree with you here about the throw, I have been using the kawada servo saver because its taller. only problem is I keep snapping the pin, I run on carpet with pvc borders and it isn't very forgiving when you hit.
can you tell me where I can get the TM servo savers from? I might give them a try.
p.s your carbon battery mounts came and they work very well, I love the fact that that are higher then stock and holds the pack in better.
the battery stopper I feel could of been 1 or 2mm further out as it looks like its is sitting right on the belt line.
jonston is offline   Reply With Quote
