Old 03-24-2014, 03:01 PM   #796
Originally Posted by MDawson View Post
Factory advice.
Lol
Originally Posted by Rick Hohwart View Post
I set the droop even with the shocks off and set the anit-roll bar at this time. Then final droop settings when the shocks are on.
This. Sorry, also check the droop with the shocks back on also. When you put the shocks back on there shouldn't be much (if any) adjustment. If there is, look at your shock lengths, preload etc
Andrew Cartwright
A_Cartwright is offline   Reply With Quote
Old 03-24-2014, 05:25 PM   #797
Trader Rating: 74 (99%+)
Originally Posted by YoDog View Post
Pretty standard process.
1) fill with fluid.
2) push piston near the top of the shock body and wait about 10 seconds for the air bubbles to rise to just under the piston.
3a) Slowly pull the piston downward while rotating the shaft.
3b) Fill the remaining space with oil.
4) Set aside to allow bubbles to rise.
5) push the piston up half way and place the bladder on top of the shock body.
6) While pushing the piston up to about 75% of the total stroke (oil will spill out of course), use the eraser end of a pencil in the center of the bladder to press it flush to the top of the shock body while holding the piston at 75%.
Note: this will create a bit of vacuum under the bladder, keeping it somewhat sealed.
7) Place the top cap on and carefully tighten, trying not to rock the eyelet.
Hopefully you are not mistaking the noise you hear as being bubbles rather than the machine marks inside the shock bore. (something AE needs to address) This makes them appear "Cheap" IMO.
Well I built them that way and the noise im hearing is air. Also when I take the shocks apart theirs air bubbles in them. Replaced the o rings and seals and same issue
thecaptain is offline   Reply With Quote
Old 03-24-2014, 06:18 PM   #798
Dan Hamann's Avatar
Trader Rating: 14 (100%+)
The Reflex bladders really help because you can see if they are built without air or not. Otherwise, it is possible you have a scratched shock shaft or something else pulling in air.
RCAmerica - Xray - Hudy - RC^2 - Motiv - Team EAM - Sanwa - Avid - Max.FX - Protoform - Pro-Line - Gravity R/C - Prolevel R/C - 2MM Designs
Dan Hamann is offline   Reply With Quote
Old 03-24-2014, 06:48 PM   #799
YoDog's Avatar
Trader Rating: 26 (100%+)
+1 on the RSD bladders!
What time frame are we talking about? 1 race day, 1 month or perhaps minutes after building? I have noticed air in the oil when pulling out the bladders only to find that the air bubbles were created while pulling off the bladders.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 03-24-2014, 07:16 PM   #800
Well I used the rsd bladders and o rings. I cycled them a few times and left them for two nights at the track. To.come in on friday to find that they sounded like they had air in them. So I pulled them apart and saw air in them through the bladder. I have sanded the rings to make them fit snugger that didnt work. I have tried brand new o rings and bladders. This worked one time onlythen I change oil and it no longer worked.
Old 03-24-2014, 08:14 PM   #801
JimmyMac's Avatar
Originally Posted by mtbboy View Post
Agreed.
Droop setting seems to be a personal preferance issue.
I was recently shown a way to measure droop by AE team driver and fellow canadian Pete Tozer.
simple, accurate and fast.
Remove tires
ensure chassis is flat on setup board
Measure with digital calipers to top of axle..
Droop distance
4mm 24.5
5mm 25.5
6mm 26.5
7mm 27.5
This method removes the subjectivity of traditional under the arm methods.
This method is also transferable to every class of rc race cars
DJC
Reminds me of this old article by David Jun.
http://www.tamiyausa.com/articles/me...e#.UzD0QPldXNk
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 03-25-2014, 07:49 AM   #802
AlanHall's Avatar
Trader Rating: 42 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
i just set my ride height and set the car on the table , hold the tires down and pull up on the chassis to see how much uptravel i have before the screws hit. ive always had better luck setting it by feel and then measuring to be sure both sides are the same after .
Alan Hall
AE B5r
AE B5/SC10
AlanHall is offline   Reply With Quote
Old 03-25-2014, 02:47 PM   #803
I have been rebuilding my 6.2 and recieived my R-Factor RC (yodog) carbon upgrade kit.
I have been using the rsd bumper already and the support bracket was a perfect fit.
also the center line lipo support has taken 95% of the battery movement out
ed
Team Associated TC6.2 Touring Car-front.jpg   Team Associated TC6.2 Touring Car-side.jpg
Edwin Pibal is offline   Reply With Quote
Old 03-25-2014, 03:08 PM   #804
YoDog's Avatar
Originally Posted by Edwin Pibal View Post
I have been rebuilding my 6.2 and recieived my r factory (yodog) carbon upgrade kit.
ed
Looks good Ed!
Did you use the battery brackets as well?
It's surprising how much more secure the battery is with the inner stop plate.
By the way... the branding is R-Factor RC now. I think R-Factory belongs to someone else.
Old 03-25-2014, 06:46 PM   #805
Looks good Ed!
opps, my bad, have edited post now.
I did, I just forgot the take a photo of them, will post it up tonight 8)
ed
Old 03-25-2014, 10:55 PM   #806
Hi there can anyone help with a setup with the tc6.2, bumpy, low to med track, med size high speed corners and flowing
Can anyone help please
________________
TC6.2 MUCHMORE FLETA PRO MUCHMORE FLETA ZX 4.5 TURN
HITEC RIDE MUCHMORE SPEKTRUM
onroad racer is offline   Reply With Quote
Old 03-26-2014, 01:40 PM   #807
I have an original TC6.1 (not the WC) and I'm thinking about getting a TC6.2 to run in a second class. Does anyone know if the body post positions are the same between these two cars? How about the body post positions for the TC6.1WC? I am also considering a TC6.1WC because they are cheap now.
The goal is to reuse some existing bodies without cutting a new set of mounting holes.
rossb is offline   Reply With Quote
Old 03-26-2014, 01:53 PM   #808
No the body posts are in different spots.
Old 03-26-2014, 02:04 PM   #809
YoDog's Avatar
To clarify...
The body post locations from the TC6.2 to previous models are different however the TC6.1 and TC6.1WC are the same. The TC6.2 is such a different chassis, I don't understand why not name it the TC7.
Old 03-26-2014, 02:16 PM   #810
I see you have both the 6.1WC and the 6.2. Is the 6.2 worth the $120 price difference for stock 17.5 touring?
