Old 03-17-2014, 12:24 PM   #736
Originally Posted by King of B Main View Post
Ask Johnson . His car was dialed yesterday !
Thanks mike .... I was running my 6.1wc that day!!
Team Integy .. Speedtechrc.com .. Gridworksracing .. .. Tq raceway ..Roudrunner raceway
AE6.1wc and 6.2
Awesomatix
johnsonthai is offline   Reply With Quote
Old 03-17-2014, 12:31 PM   #737
Originally Posted by Serpent ken View Post
I'm running the stock set up on my 6 .2. Our track is sprayed with fruit punch and with my nitro car it can be lose with foam tires. I'm running 32 aps tires I clean them with brake cleaner then put some paragon sauce on the tires in till I'm ready to run then I wipe off with brake cleaner found if you don't wipe it off and is moisture in the air like at night the tires get gummy and start picking up dirt and sugar form the punch. The thing i don't like is the spool,it causes a push on power like in the sweepers. So I'm going to change to a gear Diff . Spool does help pull the car out of corners when track is lose. It really depends on your driving style hopes this helps good luck
thanks for the help. I tried the kit setup but didn't care for it. I'm running a modified version of Hohwarts GCR setup. there was something odd on it though. not sure if it was right. he listed 3mm shims under the suspension mounts front and back. that seems awful high. I ran .5 yesterday and it wasn't back but not good. I wanted to see if anyone else had a good setup to try. I'll keep testing
DOTMAN is offline   Reply With Quote
Old 03-17-2014, 12:50 PM   #738
Trader Rating: 47 (100%+)
What kind of grip do you have? What is the size of you track? And what is type of lay out is it(yight technical, or flowy?
thecaptain is offline   Reply With Quote
Old 03-17-2014, 12:57 PM   #739
it's a medium sized track with medium traction and bumpy is spots. the layouts are usually somewhat technical
Old 03-17-2014, 01:09 PM   #740
I assume your running 17.5?
Old 03-17-2014, 02:09 PM   #741
Sorry, I'm running 13.5
Old 03-17-2014, 02:12 PM   #742
I could give you my set up if you would like. I run on a low-low medium bite tight technical track. I also run 17.5. It was ON RAILS and fast a he double hockey sticks :P.
Old 03-17-2014, 02:21 PM   #743
sure. i'd like to see what you're running. thanks
Old 03-17-2014, 07:25 PM   #744
Does car come lose when you hit the bumpy spots
Serpent ken is offline   Reply With Quote
Old 03-17-2014, 08:14 PM   #745
Sorry but due to some incompatability of rctech I cant upload my pdf version of the set up. Pm me and I will Email it to you, or something.
Old 03-17-2014, 10:07 PM   #746
no, it mainly lacked steering. it pushed on power and off too. it push more on power than off. the car could stand to rotate a bit more too. I should mention that i am using a spool instead of the gear diff in Hohwart's setup
Old 03-17-2014, 10:43 PM   #747
You have to get a diff. Get rid of the spool,if you want more steering because the spool doesn't allow you to free up when your hitting the corners
Old 03-17-2014, 11:22 PM   #748
i'll try it. thanks.
Old 03-17-2014, 11:49 PM   #749
YoDog's Avatar
Trader Rating: 26 (100%+)
If you are having that much under steer, it's not likely because of the spool. Something isn't right with your setup. You should still get plenty of steering without a front diff. What oil are you running in the rear diff? What springs and shock oil? If you post your settings, we might be able to point to something.
I know you said you have Ricks setup but you may be better off starting from the kit setup and make small adjustments starting with droop. If Rick is actually running 3mm on the arms, he is running a high roll center. He mentioned running a similar setup on his 6.1 awhile back. I tried that setup and it only worked well on a more grippy surface. A lower roll center will be more forgiving in my opinion.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 03-17-2014, 11:50 PM   #750
YoDog's Avatar
Hey dotman, where do you run?
I noticed you are in Pasadena.
