Old 03-04-2014, 03:19 PM   #691
The shims are really nice. A lot easier to adjust roll centers with the shims then washers.
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 03-04-2014, 03:33 PM   #692
The Evicerator
Agreed, they are a must for your toolbox!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 03-04-2014, 05:34 PM   #693
DARKSIDE's Avatar
also Im using the Servo Saver, XT/Futaba and its working just as well as anything else out there
http://www.teamassociated.com/parts/details/25162/
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
Final On-Road Race
Summit RC Raceway June 17th
Ft. Wayne IN
DARKSIDE is offline   Reply With Quote
Old 03-04-2014, 07:53 PM   #694
The Evicerator
Dan, yes they will fit.
Originally Posted by Dan Hamann View Post
BD7 Collars?
Steve Weiss
Old 03-05-2014, 11:17 AM   #695
Default What is the dcj size for the tc6.2?
Hi guys someone please help, I ordered parts from hksrc. Com. NEVER order from them, I just got ripped off. But basically here's my issue, I broke one of my front axles on my 6.1wc and figured I'd just replace the cvd with dcj axles. Reflex is sold out, I can't get the 6.2 ones because they are on backorder. I read somewhere that Tamiya has compatible front dcj axles?? Does anybody know of any dcj I can use or ones that are compatible with the tc6.1 wc??
Bgilli26 is offline   Reply With Quote
Old 03-05-2014, 11:33 AM   #696
Trader Rating: 34 (97%+)
Send a message via AIM to King of B Main
I bought spec r @ tq raceway
King of B Main is offline   Reply With Quote
Old 03-05-2014, 11:57 AM   #697
rc pete's Avatar
Originally Posted by DARKSIDE View Post
+1...
Got the same one one, works fine for me too.
You can get up to 24-25 degrees of steering throw with it on the inside wheel, which suits me fine, as it's slightly shorter than the stock arm.
If you like a ton of steering throw you may need to get the xray servo saver or equivalent, which is taller.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 03-05-2014, 12:18 PM   #698
Default 6.2 Dcj axles
The spec r ones fit with bearings and hubs and everything? Any modification needed? Can you please let me know a part number if you know it?
Old 03-05-2014, 06:20 PM   #699
Default spec r
I dont know the part # . But you dont need to do any modifications.
T
Old 03-05-2014, 09:01 PM   #700
T
Excellent thank you very much! Will post an update with part numbers once I get them
Old 03-06-2014, 10:08 AM   #701
YoDog's Avatar
Trader Rating: 26 (100%+)
Hi all,
I am finally back up and running!!
I have TC6/TC6.1 Servo mounts available without anodizing at this time. (tough to find economical anodizers in California)
A new direct fit TC6.2 Carbon bumper support and adjustable carbon battery stays for both the older 6.1 and new 6.2 styles.
If anyone knows of a reliable yet inexpensive anodizer please PM me so that we can turn these parts BLUE.
See the pics of the bumper support below and pics of the battery stays. Pricing and some other goodies are soon to follow.
Team Associated TC6.2 Touring Car-20140305_193946.jpg-comp.jpg   Team Associated TC6.2 Touring Car-20140305_194055.jpgcomp.jpg
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 03-06-2014, 10:56 AM   #702
JayBee's Avatar
Trader Rating: 31 (100%+)
With the Blue/ Light Blue RSD springs...what are you guys using for shock oils? This is for 17.5
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 03-06-2014, 12:09 PM   #703
Has anyone had trouble getting your shocks even? i built mine all the same however, one feels normal, two feel stiff, and one feels very stiff. they all move smoothly until i tighenten the bottom cap. I'm not sure how to fix it. are the holes in those bottom caps not centered? could that be the problem?
DOTMAN is offline   Reply With Quote
Old 03-06-2014, 01:09 PM   #704
First see if the bottom spacers slide smoothly on the shaft. If they don't, try gently reaming with a drill bit or arm reamer.
If that's smooth, you could try sanding them down a hair so the oring isn't pinched so much.
-Mike
Old 03-06-2014, 01:46 PM   #705
thanks for the tips, Mike. i'll give those a try
