Team Associated TC6.2 Touring Car >
Like Tree3Likes
Old 02-28-2014, 12:31 PM
  #676
Trader Rating: 40 (100%+)
Does anyone make a stronger spool outdrive?
King of B Main is offline
Old 02-28-2014, 12:32 PM
  #677
R3VoLuTiOn's Avatar
Trader Rating: 29 (100%+)
Originally Posted by TJames987
i'm sure this has been asked before
but what parts do you need to make the yoke springs fit and not baggy on the shock. The yoke springs seem to be too big of bore. Do you need to replace the preload and shock retainer?
thx
You dont have to. I didnt for a long time and car worked well.
You can buy both from amain.
R3VoLuTiOn is offline
Old 02-28-2014, 12:45 PM
  #678
Associated have just brought out steel ones http://www.teamassociated.com/parts/details/31638/
scoyle is offline
Old 02-28-2014, 12:46 PM
  #679
HB Moose's Avatar
Is that really what you would want? If those are stronger you'd just break something else when you crash. Those are suppose to be less expensive than the rest of the drive train to replace.
HB Moose is offline
Old 03-01-2014, 12:38 PM
  #680
rdracer's Avatar
Does anyone have a setup for tc6.2, asphalt, med grip, 17.5 blinky?
rdracer is offline
Old 03-02-2014, 06:16 AM
  #681
Originally Posted by MDawson
Has anyone tried or know of a short shock/tower kit for this car?
im using Tamiya TRF short shocks with reflex springs and reflex retainer. getting much better adjustability with droop and ride hide compared to stock.
jonston is offline
Old 03-02-2014, 08:53 AM
  #682
Trader Rating: 27 (100%+)
Thanks.
Cant tell from the pics but is that a lowered shock tower or that the stock shock tower?
Ideally, I am looking for the lower shock tower, short springs with short shocks.
MDawson is offline
Old 03-02-2014, 09:20 AM
  #683
AlanHall's Avatar
Trader Rating: 43 (100%+)
What problem are you seeing with droop and ride height. Seems like I have plenty available either way
AlanHall is offline
Old 03-02-2014, 04:16 PM
  #684
Trader Rating: 15 (100%+)
Thanks.
Hey Mark, Im sure you can use a set of short shocks from the ARC R10 2013 and the lower shock towers from reflex racing. Springs choices will be from either arc, X-ray, or reflex. Thats the combo I would use.
trigger is offline
Old 03-02-2014, 04:22 PM
  #685
Originally Posted by trigger
Hey Mark, Im sure you can use a set of short shocks from the ARC R10 2013(shopviperrc.com) and the lower shock towers from reflex racing. Springs choices will be from either arc, X-ray, or reflex. Thats the combo I would use.
That was ALMOST there. The 6.2 has different mounting locations than the 6.1 on the shock tower.
MDawson is offline
Old 03-02-2014, 05:11 PM
  #686
The Evicerator
The Yokomo Ride Height adjusters fit the shocks.
thx
Steve Weiss is offline
Old 03-03-2014, 03:47 PM
  #687
Dan Hamann's Avatar
BD7 Collars?
Dan Hamann is offline
Old 03-04-2014, 08:16 AM
  #688
Rick Hohwart's Avatar
The AE steel spool outdrives work great. These wear well and unlike the plastic outdrives, they will not break nor do they appear to create problems with other components.
You do not use the blades with these outdrives so you no longer have to worry about blades breaking.
Rick Hohwart is offline
Old 03-04-2014, 09:11 AM
  #689
Thanks, already bought it and it works great ! No more broken blades. Do you know when those spacers you showed us will start shipping to hobby stores?
Old 03-04-2014, 09:29 AM
  #690
The carbon shims are in stock so should be hitting stores any day now. Or they are available on the RC10.com website.
