Old 02-12-2014, 01:45 AM   #586
wtcc's Avatar
Originally Posted by jha07 View Post
I'm in the same boat, deciding if I should upgrade from the 6.1. Why do you think the 6.2 adapts to other tracks easier?
The setup window is much wider and in comparison to the 6.1 this thing will take more speed through the corners because of its flex, even if your setup is not spot on. My 6.1 and 6.2 are dialed in, I only go for the 6.2 because I am a fanboy
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 02-12-2014, 08:49 AM   #587
rc car guy's Avatar
I'm looking for buy some yokomo springs for my 6.2 what springs would you buy the list I have is for carpet low-medium traction
Blue-12.12 YOKYS-14575L x4
Yellow- 14.71 YOKYS-1455L x4
Pink- 14.93 YOKYS-1565L) x4
Green- 16.06 YOKYS-15625 x4
what do you guys think?
rc car guy is offline   Reply With Quote
Old 02-12-2014, 09:15 AM   #588
John Tag's Avatar
Trader Rating: 41 (100%+)
Im running Blue rear pink fronts on low/med bite..Others are running Blue front black rears.
I found a killer set up for med/low bite at our local track. I will try and post later.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 02-12-2014, 10:11 AM   #589
AlanHall's Avatar
Trader Rating: 42 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
is there a common rsd piston/spring setup most are having good luck with?
and john, you said before that you are using the rsd 6.1 dcj setup? I have it with the 5x10x3 bearings
Alan Hall
AE B5r
AE B5/SC10
AlanHall is offline   Reply With Quote
Old 02-12-2014, 10:16 AM   #590
rc car guy's Avatar
3x 1.2mm piston a 14-15 lbs spring front and rear rsd bladder with 550 cst front and 400 cst rear, i found works for most tracks you can see similar settings with kevens set up
Old 02-12-2014, 10:53 AM   #591
rc car guy's Avatar
also i know its been answered in this thread before i just couldnt find the post i was looking for, what springs retainers would you guys recommend and do i have to get different threaded collars for the top? for the yokomo springs?
Old 02-12-2014, 11:55 AM   #592
Thumbs up
Are any of you interested in a BRAND NEW TC6.2 Roller Factory Team Kit with upgraded Ceramic Bearings and Complete kit of TC6.1/2 Springs?
Want to get $500 shipped USPS Priority Mail with tracking# to anywhere in the continental U.S.
-Chad
ROCCityDesign is offline   Reply With Quote
Old 02-12-2014, 12:00 PM   #593
AlanHall's Avatar
taxing..
Alan Hall
AE B5r
AE B5/SC10
Old 02-12-2014, 12:46 PM   #594
wtcc's Avatar
I used the 1/1/1.5mm pistons with AE 40wt oil plus the "old" RSD yellow (rear) and silver (front) springs this season on different indoor tracks and had podiums only (including two wins) in the LRP-HPI-Challenge in Germany.
For the 6.2 I am at 3x1.15 pistons, the 6.2 RSD springs light blue all around with AE 40wt oil.
AE / Reedy / RSD
Old 02-12-2014, 01:02 PM   #595
AlanHall's Avatar
thanks guys , I only picked up one set of rsd springs, maybe I should have gotten 2 kits . it looks like some are running same springs all the way around
Alan Hall
AE B5r
AE B5/SC10
Old 02-12-2014, 01:07 PM   #596
JayBee's Avatar
Trader Rating: 31 (100%+)
ALOT of folks swear by the Yokomo Pink fronts/ Blue rears, but I want to give my R&D 6.2 springs a go. Has anyone found success with these instead of using the Yokes?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 02-12-2014, 02:19 PM   #597
MiTaller-RC's Avatar
Send a message via Skype™ to MiTaller-RC
Questions??
Originally Posted by Scottmisfits View Post
The inserts don't break. It will be the block. New blocks come with inserts. And now you don't have to carry around a couple of sets of all of them, you carry a couple of sets total. If you keep breaking them on the right side of the car, keep building those ones. You won't have a pile of lefts sitting in your pit box.
I was kind of skeptical on them when they first came out but now I love them.
How do you measure the correct place to glue it?
JQ WE - Alpha Lutz WE - Xpert Servos - AKA
Tekno EB48 - Tekin RX8 - AKA
_________________________
=> BIMA RACING TRACK <==
MiTaller-RC is offline   Reply With Quote
Old 02-12-2014, 02:27 PM   #598
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
rsd blue white 6.2's have been excellent for me.
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 02-12-2014, 05:38 PM   #599
BulletMan's Avatar
Default A LITTLE HELP?
hello AE fans... i have a problem
Converting my 6.1 to 6.1W...
how do i get the front ride height down?
Stock shocks, silver spring.
vertical ball stud conversion
new front shock tower
shocks mounted 2/C
Its at 10mm! with shock adjusting collar at 0
i got the back down to 5.5mm by usuing 1/C, green spring with adjusting collar backed to 0.
Martin Vannieuwenhuizen
ASSOCIATED 2wd B4.2... BACK TO MY ROOTS
ASSOCIATED TC6.2, REEDY 6500, TEKIN RSX, 17.5 D4
ASSOCIATED RC-12R5.1 (lipo chassis), REEDY 7000, TEKIN RSX, 13.5 D4 1s
"racing since the 80's an XRAY was something you needed when you broke a bone."
BulletMan is offline   Reply With Quote
Old 02-12-2014, 06:00 PM   #600
John Tag's Avatar
shocks mounted 2/C
You can cut the top of the lower shock eyelet 1.5-2mm so the lower spring retainer sits lower...
