Old 01-24-2014, 10:57 PM   #481
rc car guy's Avatar
I am going to post this here and the the keven herbert forum. My track is gaining traction A LOT of traction. My roll centers are as low as they can go, i am going up in shock oil but im pretty much at the top of that point, not going up in spring rate (14/8 lbs), running a 1.2x3 piston not going shorter on the track width, its much faster with the wider track width and a lot of traction and a shorter one. I am looking of ways to take a generous amount of traction out of my car. I am also running jaco blues and -1 deg camber also why does someone not make cf pieces that are thicker, or different weave for less traction, or some braces or something do the yomoko bd-7 parts bolt onto the associated car just as the top deck, and cvas?
rc car guy is offline   Reply With Quote
Old 01-24-2014, 11:35 PM   #482
JayBee's Avatar
Trader Rating: 31 (100%+)
What spring perches are you guys using with the YokOmo springs? Sorry if this question was answered before....
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-24-2014, 11:56 PM   #483
wtcc's Avatar
Reduce spring rate and use softer oil to have the car more near to the ground while cornering. Then control the leaning with the anti roll bar. Start with the softer ones. Also increase the droop number. A lightweight body and aluminium screws on the upside of the chassis can be a big improvement too.
If this all isn't enough you have to go the hard way:
glue on the sidewalls, reduce camber to decrease the contact patch and/or changing the balance to a bad understeer to reduce the forces going into the corner.
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 01-25-2014, 12:20 AM   #484
JustWill75's Avatar
Send a message via AIM to JustWill75
3racing blue light weight perches.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 01-25-2014, 06:22 AM   #485
DARKSIDE's Avatar
Originally Posted by Pete Martinez View Post
can someone lead me in the right direction for a good set up. I have never ran onroad before, I will be running on a carpet track that is 100 by 50 newly put down thanks for any help.
I would go with the box setup....being new you might find better results with a very neutral easy to drive car. Im currently running it and its fantastic. Try that 1st and then tweak it to your driving style and likeness
Myron
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Scale Nationals
Windy City RC in Arlington Heights IL
April 8-9
DARKSIDE is offline   Reply With Quote
Old 01-25-2014, 07:26 AM   #486
rc car guy's Avatar
I dont think I asked or you understood that correctly I reduced camber to -1 im not sure.how affective jacos become with less I am looking for LESS traction not more the roll of the csr is fine its not rubbing also the traction is everywhere its not just in the corners on the straights as well different top deck of different weave chassis or.something to take traction out
Old 01-25-2014, 07:32 AM   #487
John Tag's Avatar
Trader Rating: 41 (100%+)
A fast car will actually have some rubbing on bottom of chassie...
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 01-25-2014, 08:46 AM   #488
Pete Martinez's Avatar
Myron
thanks
MUGENRACING.COM/MBX7/
/B64/B6/RIP LIR/PHAT SCHEEMZ PAINT/WWW.RCNYC.NET/
BARNSTOMERSRC/REDLINE HOBBIES/WOLCOTT HOBBY & RACEWAY/
/FORT KNOX RC NYC/IRH RACEWAY/TEAM TIGHT TO THE PIPE RACING/
/TEAM RAMOS/
Pete Martinez is offline   Reply With Quote
Old 01-25-2014, 09:31 AM   #489
chevtech23's Avatar
Jaybee- I use the HPI pro 4 spring perches and the Tamiya TRF shock collars with the Yokomo springs, works good. HPI #73510, Tamiya #19444360 you need two of the hpi part, they come with 2 per kit
chevtech23 is offline   Reply With Quote
Old 01-25-2014, 09:34 AM   #490
Madulla's Avatar
All the 6.2s at our track are grip rolling everywhere. Maybe after snowbirds Kevin will put up a high grip setup. We are trying all different setups. Car is very fast, but you never know when it's going to flip off the track. This makes you drive not as hard and is slowing me down.
Hobbywing North America Team Driver
hobbywingdirect.com
CARCAR VP carcar.ca
Madulla is offline   Reply With Quote
Old 01-25-2014, 09:36 AM   #491
Gary NJ's Avatar
thanks
Pete - I started running TC a few weeks back, and that is excellent advice you got. Believe me, starting with something easy to drive and neutral - or even a little pushy - and then getting more aggressive is very good advice. If you're talking about Tom's new track, i'm sure once Mike Haynes runs there you'll have all the help you could possibly need. The class is fun - not easy to go as fast as the fast guys, but lot's of fun.
Gary - GMK Supply
www.gmksupply.com
Great products. Goofy names.
Gary NJ is offline   Reply With Quote
Old 01-25-2014, 09:51 AM   #492
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
His car wasn't even tippy at Victoria WCICS, have you guys tried his setup from IIC?
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 01-25-2014, 11:59 AM   #493
rc car guy's Avatar
If your running mod his set up is good im running stock and regaurdless of the fact that my chassis doesnt ru it still has too much traction
Old 01-25-2014, 12:02 PM   #494
I'd be trying either turning my steering down or standing the front shocks up one
Ed
Edwin Pibal is offline   Reply With Quote
Old 01-25-2014, 12:22 PM   #495
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
unpredictable traction roll.
I almost always go softer in shock oil and spring, let the car roll. If you take all the traction out you will be slowwwwwwww. Figuring how to drive the car in high bite will usually result in much faster laps. If the track has a lot of rolling corners and you are traction rolling mid corner. Removing some drag break may help, if you have any in. The drag break will cause the car to roll up on itself and not free up through the corner.
Slow in allows fast out. Break before the corner, roll in throttle around and out.
A soft car with droop will allow you to not only bottom out when over aggressive but it gives you visual clues on how far you have gone before traction roll.
If you use the wheels to slow the car you are loading up the chassis before the corner and then loading harder through the corner. When the slide stop the roll over begins. Changing how you enter the corner in that instance may help a lot.
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
