Old 01-24-2014, 04:42 AM   #466
John Tag's Avatar
Trader Rating: 42 (100%+)
Originally Posted by JustWill75 View Post
Had a great week with the TC6.2. Wednesday night finished Third in 17.5 and that was due to my own driver error. Did a little spring testing with Reflex, ARC and Yokomo Springs. I have to admit I really like the Yokomo Pink front and Blue rear. I did notice that in order to run them I had to use a different spring perch. I also noticed that even with the collars all the way up my ride height would not go below 5.5mm. For my track 5.5 is where you want to me but I still would like to know what is the best way to get the yokomo springs to work on the TC6 shocks? Note: I have not tried Reflex's new TC6.2 springs yet. I will order them soon.
To get RH with more adjustment..Take shock end(Tie rod end) and trim 1MM off end. That will give you all the adjustment you will need. Doing that will lower shock spring retainer.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 01-24-2014, 04:46 AM   #467
John Tag's Avatar
Originally Posted by TJames987 View Post
Hi Iím really confused about these arm mount dots. The kit setup has you use 1 one dot arm mounts which = 0 degrees. How does the rear end of the car get to 3 degrees of rear to using the one dot arm mount inserts?
The new setup sheets are kind of confusing too because they indicate inner and outer arm mounts for the arm mount inserts. Iím assuming inner means the mounts toward the centre of the carÖ What affect does changing the arm mount inserts in the front have, why not just adjust steering links?
Anyone else confused about this?
On the rear there is 3* toe in chassie design layout. So with 1 dots there will be 3* in the rear and 0* up front.
Old 01-24-2014, 05:00 AM   #468
JustWill75's Avatar
Send a message via AIM to JustWill75
Man do i feel dumb....... I mean that was so obvious that I'm almost embarrassed that i posted the question. .....
Any way thanks John I will do that. Has anyone tried the new reflex springs and does anyone know the release date of the Associated DCJ drive shafts?
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 01-24-2014, 05:25 AM   #469
chiefj48's Avatar
What spring perch do you use with the yokomo springs??
Do you need to replace adjuster also???
Part#???
chiefj48
Home of the; 2016 ROAR On Road Paved Nationals
Special Thanks, Serpent USA, Awesomatix USA, Valkaria RC, Trinity, Discount RC Store, Team Associated, Team Powers, Prime Hobby
https://www.facebook.com/ValkariaRcraceway/
chiefj48 is online now   Reply With Quote
Old 01-24-2014, 05:45 AM   #470
John Tag's Avatar
Part#???
I personally run the spring perch from Reflex for the TC6. Top adjuster I run stock.
http://www.reflexracing.net/RSD-13mm...ps_p_1480.html
Old 01-24-2014, 06:05 AM   #471
JustWill75's Avatar
those look just like the ones I bought from 3racing. I used them and the stock collars.
Old 01-24-2014, 06:40 AM   #472
JayBee's Avatar
Trader Rating: 31 (100%+)
http://www.reflexracing.net/RSD-AE-T...cs_p_1671.html
Will these work on the 6.2?
And yes...I was thoroughly confused with the dots. I can't remember but were you guys CA'n all the inserts into the chubs and steering blocks?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-24-2014, 06:41 AM   #473
chiefj48's Avatar
Thank you........
chiefj48
Old 01-24-2014, 06:47 AM   #474
John Tag's Avatar
Yes, Those are what I'm using.
Just use a dab of glue when the inserts meet the housing sides.
Old 01-24-2014, 06:54 AM   #475
rc car guy's Avatar
The outer insert holder is wider than the front thus giving it toe if you go to the back of the book and read on thr arm position it says thay if you have the same insert in the front and back of the rear than you have 3 deg of toe if you have a 1 and 1 and you go to a two on the inside you now have taken away .5deg of toeso a total of 2.5deg of toe in the car it explains that each insert is worth .5deg over the previous on
rc car guy is offline   Reply With Quote
Old 01-24-2014, 07:16 AM   #476
John Tag's Avatar
Correct..Like I said the 1 dot is 0* + add the 3* on the chassie design and that is 3*..I personally run 1 dot on rear and 2 out in front of rear arm for 2.5* rear toe. The Outer mounts are std front and rear they are the same. The rear toe is drilled into the chassie rear inner mount location design NOT the mounts..The mounts are used to adjust the amount of rear toe or front sweep with the inserts.
Example- Front Inner mount 1 dot and front outer mount 1 dot inserts stock set up = 0* front sweep/Toe at arms. I personally run 1 dot inner mount and 2 out outer mount for 1/2* front sweep.
Old 01-24-2014, 07:42 AM   #477
kghills's Avatar
Trader Rating: 40 (100%+)
I see Kevin's first setup had weight behind the battery and motor. His latest makes no mention of any weight. Just wondering if the weight should still be there. Seems like 20 grams back there would make a pretty big difference either way.
Keith.
Jason's dad
Check out Jason's video http://www.youtube.com/watch?v=eU2jqOnhJ9E
Photos: http://s816.photobucket.com/albums/zz90/kghills/Jason%20Hills%20RC/
Thanks to Team Associated and Reedy for their support.
kghills is offline   Reply With Quote
Old 01-24-2014, 10:06 AM   #478
rc car guy's Avatar
Keith.
It depends on your battery and how your car balances I personally have ni weight behind my battery and 14g infront of it and 26g behind my motor to balance the bar l/r also my battery is in the backwards position with the peice of servo tape behind the battery to push it forward the csr weighs 1382 fully loaded the tires read with in a few grams of each other
Old 01-24-2014, 08:05 PM   #479
Pete Martinez's Avatar
can someone lead me in the right direction for a good set up. I have never ran onroad before, I will be running on a carpet track that is 100 by 50 newly put down thanks for any help.
MUGENRACING.COM/MBX7/
/B64/B6/RIP LIR/PHAT SCHEEMZ PAINT/WWW.RCNYC.NET/
BARNSTOMERSRC/REDLINE HOBBIES/WOLCOTT HOBBY & RACEWAY/
/FORT KNOX RC NYC/IRH RACEWAY/TEAM TIGHT TO THE PIPE RACING/
/TEAM RAMOS/
Pete Martinez is offline   Reply With Quote
Old 01-24-2014, 09:37 PM   #480
mtbboy's Avatar
http://www.teamassociated.com/setupsheets/TC6.2/
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
