Old 01-15-2014, 06:32 AM   #376
John Tag's Avatar
Trader Rating: 42 (100%+)
Front from bottom..Actually Body clip to secure body to car is 5th hole and rear is 4th hole up..Thats Body pin location..The hindge is 1 hole lower. No, Body is cut just above body cut line...Body's have 5.5-6mmm front bumper still. Bodies as mounted do pass tech no issues.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 01-15-2014, 06:39 AM   #377
rc car guy's Avatar
what ride height are you running?
rc car guy is offline   Reply With Quote
Old 01-15-2014, 06:57 AM   #378
John Tag's Avatar
5mm Front -5.25 rear
Old 01-15-2014, 07:22 AM   #379
rc car guy's Avatar
I dont know mines 5 the bodies should be the same ill look into it thanks for the help friend
Old 01-15-2014, 12:04 PM   #380
rc car guy's Avatar
Ok heres a picture of my set up you might have to zoom in to read the numbers but you should be able to read them
I started out with kevens set up a great start the car just had WAY too much traction especially in the rear
Also I had some spec r body posts that i slightly modified to run in the front so ill have plently of room to mount my new body
Old 01-15-2014, 12:14 PM   #381
What surface / grip level do you run? On our carpet tracks, I can't get away with bodies that low. They drag on the carpet and screw up handling.
-Mike
Old 01-15-2014, 12:32 PM   #382
Just getting back into racing and looking to pic up the TC6.2. I see a lot of used 6.1's and plan to mainly do club racing VTA or 17.5 class. I was also looking at the Xray t4-14 but it seems a but pricey and this car looks fantastic from what I've read on here so far.
Is it better to just spend a bit more for the 6.2 or pick up a used older model?
dreadwing is offline   Reply With Quote
Old 01-15-2014, 01:19 PM   #383
John Tag's Avatar
Carpet.. "Bodies" are 5.5-6.5MM from ground clearance..Higher than chassie.
Old 01-15-2014, 06:48 PM   #384
JimmyMac's Avatar
Set your body height (roof line as low as possible/within rule limit). Then trim body until it no longer rubs on the track.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 01-15-2014, 07:15 PM   #385
rc car guy's Avatar
i dont know if thats right... lets see a pic of your car with body mounted?
Old 01-15-2014, 07:30 PM   #386
JimmyMac's Avatar
Ok, let me get it out and toss a battery and body on it.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 01-15-2014, 08:04 PM   #387
JimmyMac's Avatar
Here ya go. Not a 6.2. But I race with Tag and I have a friend wanting a 6.2.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 01-15-2014, 08:09 PM   #388
rc car guy's Avatar
ya looks like you just cut it along the lines that come from the factory, from the pic im surprised that the front of your car doesnt rub... looks pretty low, but anyway i heard cutting the rear portion of the body after the rear wheel actually controls some sort of handling affect anyone know about it?
Old 01-15-2014, 08:18 PM   #389
JimmyMac's Avatar
I'm above the trim line. Maybe 1/8 inch? Maybe more? My other race body is cut even higher. As for the rear trim line. I heard about it, but I forgot what it did. I think some Biddy Design bodies have different trims lines for the rear panel.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 01-15-2014, 08:21 PM   #390
rc car guy's Avatar
http://racepf.com/blog/2013/12/tunin...ear-trim-line/
well thanks google... haha
