Old 01-13-2014, 02:59 PM   #361
mtbboy's Avatar
Originally Posted by rc car guy View Post
For my track the car has too much traction with jaco blues and kevens set up unfortunately but its a great starting point if only it was on a 6.2 set up sheet
What is it that you feel the new setup sheet will aid you in?
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 01-13-2014, 03:10 PM   #362
rc car guy's Avatar
It will at least tell me I have everything in the right position for the ackerman its not really spesified it would just be a lot better and easier to follow
rc car guy is offline   Reply With Quote
Old 01-13-2014, 03:26 PM   #363
DARKSIDE's Avatar
He is going to repost it under tc6.2
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 01-13-2014, 03:29 PM   #364
mtbboy's Avatar
Kool.
Just curious.
Ackerman is .5mm on a short ball stud.
Old 01-14-2014, 10:35 AM   #365
Adonis_mp's Avatar
what would be the best way to tape the battery to this car, use the mounts or tape it to the chassi? if using the mounts, why not use velcro?
I have Job Security, nobody wants my Job!!!!!
Losi 22-4 - MMP - Tekin Gen2 5.5 * Losi SCTE - RX8 - Tekin Pro4 4600 * 22SCT - MMP - Tekin Redline Gen2 6.5T * Losi 22B 2.0 - Tekin RS - Novak 8.5T * TC6.2 * TC6.1 VTA * Wraith - CC Sidewinder - HH TorqueMaster 35T * E-max - Rustler - Slash - 1/16 Revo
Adonis_mp is offline   Reply With Quote
Old 01-14-2014, 12:57 PM   #366
John Tag's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Madulla View Post
I broke my servo (stripped gear) first run with the stock horn. I also run the larger RSD bumper. I put a large Kimbrough saver on and have the same lack of throw problem. I can only get 20 degrees, not the 27 I am looking for. I will have to do some more testing.
Also both cars at our club had extreme traction roll problems. I was running Kevin's setup, the other guy a completely different stock one. Any ideas to tame the extra steering with the car ?
With AE servo saver..2mm Ackerman spacer(1mm added to stock set up) I'm able to get 30* at each wheel if needed. That's using the smaller servo shim with Spektrum 6070 servo.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 01-14-2014, 01:08 PM   #367
rc car guy's Avatar
The 6.2 doenst allow you to tape it to the chassis you have to use the mounts as for the tape vs velcro I would imagine the tape held it in a bit better and is a few grams lighter and maybe has something to do with thr chassis flex but im not entirely sure we could tell the difference between the two for chassis flex for the velcro using the stock battery miunts you would need a fairly narrow velcro strap have only seen the wides ones being used or cut a thicker one to fit
Old 01-14-2014, 04:11 PM   #368
YoDog's Avatar
Trader Rating: 26 (100%+)
I have found the tape to be the most reliable method. It sticks to the battery which doesn't require so much tension to keep the battery in place.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 01-14-2014, 06:18 PM   #369
AE-Reedy
If you use a good quality tape you can reuse the tape over and over.
I use 3m and have had the same piece in the car for 3 track days.
Sean Cochran is offline   Reply With Quote
Old 01-14-2014, 06:43 PM   #370
John Tag's Avatar
You can also try Reflex Racing X Ray battery hold downs.
Old 01-14-2014, 08:27 PM   #371
rc car guy's Avatar
question? are there any upgrade parts other than ae site, for the 6.2?
in particular im looking for longer front body mounts i mount my body as high as it could go then added 2mm of shims under it and i still had to cut the front of the body pretty short, i am running the mazda speed 6 with a stiffer set up than kevens on ae site
Old 01-14-2014, 08:27 PM   #372
rc pete's Avatar
I broke a set of servo gears as well after tapping a board on my 2nd run with the car.
Solved that by:
- replacing it with a full metal low profile servo. I had the XPert on hand: http://www.xpert-rc.com/product_view...area=2&dcat=83
- adding some flex into the servo mounting. First make sure you get the bottom steering post screws tight, then take out the top 2 screws from the steering posts which will give the servo mount just a bit of flex when you do have impact. Next, mount the servo on the rubber grommets (most servos come with those) to again give it a little give. Note: you have to use slightly longer screws with the grommets.
Done! Worked great for me all weekend running the standard 6.2 (1/8 scale) servo horn with all of the steering you need.
This setup probably still provides a more direct steering feel than a servo saver, which can really soften that up.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 01-14-2014, 10:24 PM   #373
Can anyone help, what is with the 1mm vent hole in the shock caps ??
Can someone put up a photo please
__________
TC6.1 WC TEKIN THUNDERPOWER
TC6.2
SPEKTRUM
SAVOX
onroad racer is offline   Reply With Quote
Old 01-15-2014, 03:29 AM   #374
John Tag's Avatar
Sounds like your body is really to high. Front should be 4th hole up and rear 3rd hole up in body mount hinge location on Speed 6. LTC Front 1 down..Then is running a GX those are 1 down in rear from Speed 6 settings.. I actually had to cut my mounts.
Old 01-15-2014, 06:04 AM   #375
rc car guy's Avatar
You cut the body on the lines where your suppose to cut it? And yes its really high... but it barelly clears stuff I butched the first body but I have a replacement coming but even with the body mounted all the wayat the top its not really tall my rear body posts can go up like 6 holes maybe I got the wrong front body posts?
As fof the hole in the shock cap it allows the air above the bladder to escape and makes the car more consistent is what im told from the experienced tc guys
