Old 01-12-2014, 03:44 AM   #346
Got my 6.2 running great in practice in VTA yesterday. A few small adjustments and it drives (turns) better than my old 6.1. Can't wait to see how it does today against the guys that drive TC all the time .I just drive this class in VTA everything is is pan cars for me.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 01-12-2014, 10:51 AM   #347
Suspended
Trader Rating: 86 (100%+)
got some tc6 suspension parts and springs for sale
tc6 and t3 parts, motors, pinions, spurs, servos
littlealex is offline   Reply With Quote
Old 01-12-2014, 05:48 PM   #348
Ran my car for the first time and the thing was hooked up. Excited for the RSD springs to come to try next time. Compared to my 6.1WC....I'll take the 6.2. The only down side would be with the new front bumper (not connecting to top bulkheads) I see a small deformation on the corner of the chassis. My fault but as I don't recall hitting anything hard and as for speed, my track is fairly small. Nice job AE...
daveb is offline   Reply With Quote
Old 01-12-2014, 06:12 PM   #349
mtbboy's Avatar
I've been running the 6.2 for two weeks now.
The car is crazy consistant. Strongly reccomend everyone copies Kevin's setup to the letter. So easy to drive and fast. I've made slight droop deviations but that's it. Sell your 6.1,s gentlemen. This is not a facelift.
Well maybe Joan rivers.
With this car. You're the problem.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 01-12-2014, 06:41 PM   #350
rosko's Avatar
You running stk or mod
rosko is offline   Reply With Quote
Old 01-12-2014, 06:45 PM   #351
rc car guy's Avatar
For my track the car has too much traction with jaco blues and kevens set up unfortunately but its a great starting point if only it was on a 6.2 set up sheet
rc car guy is offline   Reply With Quote
Old 01-12-2014, 06:52 PM   #352
Trader Rating: 17 (100%+)
Started with the kit 40 wt shock oil. Rear was just a bit loose. Thinking of going to 30 rear and 32.5 front. Silver springs. Running droop at 4 front and 3 rear. Rear shock outside on arm and top on tower. Front inner and outer at -3 and 1 in rear.
Team Schumacher USA
meddman is offline   Reply With Quote
Old 01-13-2014, 11:01 AM   #353
JustWill75's Avatar
Send a message via AIM to JustWill75
I broke the servo arm that with my kit. I put a Tamiya servo saver on that looks great but it seems like i don't get all the throw From it. I can physically turn the wheels more than what the servo is doing. What servo saver are most using or should get another stock arm?
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 01-13-2014, 11:31 AM   #354
John Tag's Avatar
Trader Rating: 41 (100%+)
AE Servo saver is awesome..
http://www.amainhobbies.com/product_...-JR-Airtronics
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 01-13-2014, 11:33 AM   #355
Dan Hamann's Avatar
Trader Rating: 14 (100%+)
From what I have seen, most like this guy if you aren't going to use either the stock piece or an aluminum arm. The AE one that comes on the MGT is another option.
RCAmerica - Xray - Hudy - RC^2 - Motiv - Team EAM - Sanwa - Avid - Max.FX - Protoform - Pro-Line - Gravity R/C - Prolevel R/C - 2MM Designs
Dan Hamann is offline   Reply With Quote
Old 01-13-2014, 12:18 PM   #356
I run the v2 version of the xray one, as it has a high centre point to put the ball stud,
ed
Edwin Pibal is offline   Reply With Quote
Old 01-13-2014, 12:48 PM   #357
rc car guy's Avatar
ed
I run the same one in the highest middle hole its excelllent very good
Old 01-13-2014, 12:49 PM   #358
Madulla's Avatar
I broke my servo (stripped gear) first run with the stock horn. I also run the larger RSD bumper. I put a large Kimbrough saver on and have the same lack of throw problem. I can only get 20 degrees, not the 27 I am looking for. I will have to do some more testing.
Also both cars at our club had extreme traction roll problems. I was running Kevin's setup, the other guy a completely different stock one. Any ideas to tame the extra steering with the car ?
Hobbywing North America Team Driver
hobbywingdirect.com
CARCAR VP carcar.ca
Madulla is offline   Reply With Quote
Old 01-13-2014, 01:07 PM   #359
rosko's Avatar
Limit rear uptravel in rear to maybe 1.5mm
Softer springs f/r thinner front swaybar
Thicker front shock oil
Negative expo in radio -10 to -20
Old 01-13-2014, 01:19 PM   #360
rc car guy's Avatar
Like I said in my previous post kevens set up has too much traction im running 1.0mm 3hole pistons 50front 45rear with a 15lbs spring all the way around I am running .25mm rear shims for the roll center and as for front im running .5mm less than kevins set up im also running jaco blues did you follow kevins set up 100%? I also lowered my camber links equally as much as possible also if you do this change your droop front to 2.0mm above ride height and rear 2.5mm above ride height
