Old 01-09-2014, 11:41 AM   #331
Trader Rating: 18 (100%+)
I got the Yokomo springs with the Spec-R shock parts and the spring retains okay in the bottom, but pretty sloppy on the top (ae shock collar) and the shocks don`t stay on the ae ball stud from the arms. Any extra parts needed that I`m missing ?
thejo3 is offline   Reply With Quote
Old 01-09-2014, 12:04 PM   #332
Logi Maker's Avatar
Trader Rating: 49 (100%+)
You need the Tamiya collars along with the Tamiya of rings... they come seperate.
Kyle Predmore
Facebook - "AE Fanboy"
B6D|B64D
TC7|TC6TEK|12R5.2|10R5.1
Logi Maker is offline   Reply With Quote
Old 01-09-2014, 12:27 PM   #333
wtcc's Avatar
Originally Posted by Svendc View Post
jep indeed, i still waiting, so i orderd in the meantime the new RSD springs.
I hope it will be quick now, because my TC6.1 is already sold.
Got confirmation from TT today. They got enough kits in stock for all shops you should get yours soon!
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 01-09-2014, 12:52 PM   #334
John Tag's Avatar
Trader Rating: 41 (100%+)
Originally Posted by meddman View Post
Having trouble with the build. When mounting the pins for holding A arms. The outer arm mounts don't line up with screw holes in chassis. I've tried removing the spacers to no avail. What am I doing wrong. This is for front and rear.
1-Make sure your installing the insert on correct side of mount..Side with recess is correct.
2-Like said already ..Make sure they are fully seated..One of my cars I had to use a little extra effort.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 01-09-2014, 01:42 PM   #335
What are the o-rings for ?
Old 01-09-2014, 03:21 PM   #336
rc car guy's Avatar
I was told they were for the battery to hold in in better but they need to be much larger for that I used servo tape to take out slop
rc car guy is offline   Reply With Quote
Old 01-09-2014, 04:46 PM   #337
waltss2k's Avatar
I'm going to run Kevin s set up tomorrow night and see how it goes.
waltss2k is offline   Reply With Quote
Old 01-09-2014, 05:35 PM   #338
Can't wait getting my tc6.2 on Thursday, are there any tips and trick when building the car that anyone wants to share ??
______________
TC6.1 WC TEKIN THUNDERPOWER
SAVOX
SPEKTRUM
BORRCCC
onroad racer is offline   Reply With Quote
Old 01-10-2014, 05:29 AM   #339
I saw one person post about their arms being tight. Anyone else? Mine were so tight front and back I had to shave 1mm of the arms to have free motion. That seems a little much too me since that is the size of one of the spacers your supposed to run. Yes, my inserts were on the correct side and flush.
Associated TC6.2 VTA
Associated TC6.2 17.5
Losi SCTE | Tekin RX8/4600
Associated RC8Be | Tekin RX8/1900Kv | Hitec 7955 | Grid Mount
rcmiller is offline   Reply With Quote
Old 01-10-2014, 06:54 AM   #340
Mazinga's Avatar
I had my same problem with mounting my arms pin holder ,I find the solution in not tight the screw all the way in the back pin holder before try to put in place the front pin holder , it's a tight fit
tc6.2 , tc6.1 , desc410, sc10.2.
... English it's not my first language, so unless you want to speak italian, be kind grazie !! Ciao!!
Mazinga is offline   Reply With Quote
Old 01-10-2014, 08:42 AM   #341
Once you have the arms in place and on the hangars, just take a small wrench and tap the front and the back of the arms (with some force) and you'll notice the arms will free up.
daveb is offline   Reply With Quote
Old 01-10-2014, 10:15 AM   #342
rc car guy's Avatar
What is the height difference between the long and short ball studs? Specifically the 5mm long and short
Old 01-10-2014, 10:23 AM   #343
Scottmisfits's Avatar
Short/black - 5.75mm from shoulder to top of ball
Tall/silver - 6.5mm from shoulder to top of ball.
Scottmisfits is offline   Reply With Quote
Old 01-10-2014, 09:10 PM   #344
rc car guy's Avatar
ran the 6.2 tonight it did great I am still tweaking on my set up however rc tech wont allow me put the set up in a pdf and i cant find where the screen shots from adobe are going. So i wont be able to share it...
Old 01-12-2014, 02:02 AM   #345
David Home's Avatar
Started building my 6.2 yesterday, few problems, first off the arms are too tight, secondly the chassis is tweaked somehow? I was careful not to over tighten anything and used loctite. I'm thinking maybe the top plate? Is there are right way and a wrong way to tighten the screws down on it? I've the roll bars to fit next but feel like stripping it down and starting again
David Home is offline   Reply With Quote
