Old 01-07-2014, 09:02 AM   #316
rosko's Avatar
Originally Posted by johnson.t View Post
car is amazing!! fast and easy to drive!....had the chance to race it this past sat on carpet..took tq in Rcgt but end up 2nd in the main....first time this car been on carpet too..
https://www.youtube.com/watch?v=AXQy...e_gdata_player
Did you use the kit setup?
rosko is offline   Reply With Quote
Old 01-07-2014, 10:54 AM   #317
johnson.t's Avatar
no i didnt...i put my own set up on there.. i was surprise it worked! gonna do some more testing this week
INTEGY.COM SPEEDTECH.COM
TAMIYA M05..AE 6.1WC...and 6.2
*Westcoast raceway..Tq raceway..Cal raceway..Roadrunner raceway*
johnson.t is offline   Reply With Quote
Old 01-07-2014, 11:26 AM   #318
Svendc's Avatar
Originally Posted by wtcc View Post
Sorry, but this is not true. ThunderTiger will get the first kits in January... So no 6.2 for christmas
jep indeed, i still waiting, so i orderd in the meantime the new RSD springs.
I hope it will be quick now, because my TC6.1 is already sold.
VBC Wildfire D08
AE B5M CE
Svendc is offline   Reply With Quote
Old 01-07-2014, 05:33 PM   #319
The Evicerator
Aren't you glad you raced it now?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 01-08-2014, 08:52 AM   #320
johnson.t's Avatar
yes i am steve.....back like socal days now with the tc3
Old 01-08-2014, 11:21 AM   #321
Adonis_mp's Avatar
Started putting my 6.2 together using the Hohwart setup sheet and I have a few questions. I have only been in Touring for a few months now so please excuse the rookie questions. Under the Alignment section; (wheelbase 1mm front 1mm rear, are htese shims that I am placing somewere?) Shocks (HPI Silver, what is the spring rate of these or what are the RSD equivalant?) Thanks.
http://teamassociated.com/pdf/cars_a...ya_10-2013.pdf
I have Job Security, nobody wants my Job!!!!!
Losi 22-4 - MMP - Tekin Gen2 5.5 * Losi SCTE - RX8 - Tekin Pro4 4600 * 22SCT - MMP - Tekin Redline Gen2 6.5T * Losi 22B 2.0 - Tekin RS - Novak 8.5T * TC6.2 * TC6.1 VTA * Wraith - CC Sidewinder - HH TorqueMaster 35T * E-max - Rustler - Slash - 1/16 Revo
Adonis_mp is offline   Reply With Quote
Old 01-08-2014, 11:30 AM   #322
rc car guy's Avatar
The wheelbase check the back of the manual for that and google the springs and find the lbs and match it up
rc car guy is offline   Reply With Quote
Old 01-08-2014, 11:39 AM   #323
YoDog's Avatar
Trader Rating: 26 (100%+)
Those shims go on the lower arm hinge pins to set the wheelbase as these arms can be spaced forward or back to change wheelbase length and weight bias.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 01-08-2014, 06:09 PM   #324
The Evicerator
The shims are used to change the wheelbase of the car like already mentioned. If you look carefully at the setup sheet, you will see that the wheelbase line points towards the space between the arm and the "outside" mount. When the setting is listed as 1mm, you place a 1 mm spacer in this position. Note that you will have to put 2 mm of spacing on the other side of the arm ... Between the arm and the "inside" mount... to take up the remaining space so that there is no shop in the suspension.
Regarding the springs, I believe an RSD purple is equivalent. The rate measures out between 16.2 and 16.9 depending on the gauge, method, and measurer!
Hope this helps!
Steve Weiss
Old 01-08-2014, 09:05 PM   #325
rc car guy's Avatar
Ran the stock set up on the 6.2 tonight it was good but it rolled WAYY too much so I went to kevins set up to the best of my ability im sure I would have gotten it a bit better if it was on a 6.2 set up sheet... but the car wasnt too bad only .3tenths off but very consistent looking forward to Friday
Old 01-09-2014, 05:21 AM   #326
JustWill75's Avatar
Send a message via AIM to JustWill75
Raced my TC6.2 for the first time last night and it was a beast. I got to the track late so no practice just straight qualifiers and I was on pace immediately. Made the A main and finished 3rd. THIS WAS WITH NO PRACTICE! I can't wait to start putting some work in on this car. Easy to drive, very consistent and deceptively fast.
If you are still wondering if you should click that buy button. ......... CLICK THE BUTTON
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 01-09-2014, 06:01 AM   #327
rosko's Avatar
Lol my local hobby shop has one waiting for me. Ive had the exotek conversion on my 6.1 and if this car is as good i know the car is an animal. I wanted to try a xray t4 2014 which i really like but i thought my tc6 tek felt better.
Old 01-09-2014, 07:41 AM   #328
NEED-MORE-SPEED's Avatar
You should hop in your car, turn the key, place the gear shifter in "drive" mode and start heading to the local hobby shop and tame the animal.
NEED-MORE-SPEED is offline   Reply With Quote
Old 01-09-2014, 11:11 AM   #329
Trader Rating: 17 (100%+)
Having trouble with the build. When mounting the pins for holding A arms. The outer arm mounts don't line up with screw holes in chassis. I've tried removing the spacers to no avail. What am I doing wrong. This is for front and rear.
Team Schumacher USA
meddman is offline   Reply With Quote
Old 01-09-2014, 11:22 AM   #330
Trader Rating: 18 (100%+)
push harder to clip the plastic parts in the aluminum mounts.
thejo3 is offline   Reply With Quote
