Like Tree3Likes
Old 01-02-2014, 11:10 AM   #271
They are in stock at CML
kennytcr is offline   Reply With Quote
Old 01-02-2014, 11:53 AM   #272
Originally Posted by rc car guy View Post
The middle spot on the tower but with no washers under either side of the link for front and rear I also run sweep how would I put that into this car? Would I change the plugs to a size larger in the front?
That spot will be the same as the kit setup
As for sweep, you can use the new inserts upfront to give you the sweep you need
Ed
Edwin Pibal is offline   Reply With Quote
Old 01-02-2014, 12:38 PM   #273
rc car guy's Avatar
Ed
With the 1mm shim is the lower roll center the same as the 6.1?
rc car guy is offline   Reply With Quote
Old 01-02-2014, 01:23 PM   #274
On paper, yes, but can't be 100% sure as I don't have my 6.2 yet to measure against
Ed
Old 01-02-2014, 05:18 PM   #275
rc car guy's Avatar
Ed
Ok so to get the car set up the same as my 6.1 for kick up and such id just measure the distance from the center of the screw to the bottom of the chassis I say thr bottom because the 6.2 chassis is thicker?
Old 01-02-2014, 05:37 PM   #276
Adonis_mp's Avatar
Pulled the trigger on this 6.2, should be here by Tue.
I have Job Security, nobody wants my Job!!!!!
Losi 22-4 - MMP - Tekin Gen2 5.5 * Losi SCTE - RX8 - Tekin Pro4 4600 * 22SCT - MMP - Tekin Redline Gen2 6.5T * Losi 22B 2.0 - Tekin RS - Novak 8.5T * TC6.2 * TC6.1 VTA * Wraith - CC Sidewinder - HH TorqueMaster 35T * E-max - Rustler - Slash - 1/16 Revo
Adonis_mp is offline   Reply With Quote
Old 01-02-2014, 11:10 PM   #277
Mine came in the mail today....Starting the build
daveb is offline   Reply With Quote
Old 01-03-2014, 01:37 AM   #278
that's my plan too!
ed
Old 01-03-2014, 09:27 AM   #279
why is it that the setups posted on RC10 they always have some other brand spring or piston? What standard piston would be comparable to 3x1.1? I'm assuming the biggest maybe I'll run to the store and Losi 56's....Any suggestions what I should try as I plan on small carpet track. My TC6.1 has 47.5/AE Blue/#2 rear and 40/AE Silver/#2 front. I guess I'll do the same.
Old 01-03-2014, 01:58 PM   #280
Rick Hohwart's Avatar
In the case of my setup with 1.1 x 3 pistons, I am using AE's blank piston set and drilling three 1.1mm holes.
AE Blank Pistons
Using other brand springs gives a finer range of adjustment and sometimes they just work better. The reality is that AE silver springs are the only rate in the AE range that is normally used. In some cases, the blue or green may work but only rarely. RSD makes a wide variety of springs that work perfectly with the TC6.2.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 01-03-2014, 02:08 PM   #281
JayBee's Avatar
Trader Rating: 31 (100%+)
Where's all the new build pics???
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-03-2014, 02:25 PM   #282
chiefj48's Avatar
You know what's really sad??? I preordered this kit direct November 15, and it still hasn't been shipped. It's funny how all the hobby shops have them already, and those of us that preordered them are still waiting. Just that alone has me wondering if I should just stick with my T4,14. I preordered that and I was one of the first to get it.
It's just bad business if you ask me. I hope it's worth the wait.
chiefj48
Home of the; 2016 ROAR On Road Paved Nationals
Special Thanks, RocheUSA, SerpentUSA, AwesomatixUSA, ValkariaRC, Trinity, DiscountRCStore, Team Associated, Team Powers, Prime Hobby
https://www.facebook.com/ValkariaRcraceway/
chiefj48 is offline   Reply With Quote
Old 01-03-2014, 02:35 PM   #283
AE-Reedy
Who did you order from?
Sean Cochran is offline   Reply With Quote
Old 01-03-2014, 02:40 PM   #284
chiefj48's Avatar
Associated direct.
chiefj48
Old 01-03-2014, 06:56 PM   #285
CristianTabush's Avatar
Hey guys, we will be releasing a new Spring kit for the TC6.2 over the weekend. These new springs are 1mm shorter, for a better range of adjustment and also are now slightly over-sized to 13.5mm, instead of the previous 13.0mm. The new springs will come in 13.0,14.0,15.0 and 16.0 lb springs.
In testing the springs we found the bigger diameter to make the car easier to drive and have better bump compliance. The springs will also be a direct fit to the TC6 shocks without any modification or need for different spring cups.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is online now   Reply With Quote
