Team Associated TC6.2 Touring Car
#2521
I recently got my hands on a 6.2 and it handles fantastic which leads me to the question of why everyone does the conversion to older suspension parts.
Can anyone tell me the reasoning behind this'and if it does make a difference what parts are changed.
Thanks in advance
Thanks in advance
#2525
Yes I am; sorry I should have been more specific. I have tried contacting the company with no luck.
I just would have assumed BD7 hubs.
Not a big deal but time to upgrade; a powerful lesson though; hop ups such as these are for a good time; not a long time.
#2527
Looking at getting these for my 6.2
http://www.reflexracing.net/RSD-TC62-Spring-Set_p_2157.html
Need to know if the standard shock spring cups will work since these are larger diameter, also what shocks work best
#2529
What's the advantage of running the DCVs over the stock axles?
#2532
http://www.reflexracing.net/RSD-TC62...et_p_2157.html
#2534
they do fit. I kept the standard spring cup - a bit loose but no problems.
If you want to change the shocks, TC7 will fit. They work great and also have the larger diameter and larger spring cups.
With the TC7.1 there are short shocks available at AE now. But to fit those, you need to change the towers and the top bearing caps and user shorter springs which makes it a quite expensive change.
#2535
What are the best ceramic bearings for the 6.2? Running black carpet
