Old 05-10-2016, 04:28 AM   #2506
Trader Rating: 18 (100%+)
Originally Posted by glennhl View Post
OK, I did the TC4/TC5 suspension arm upgrade that the factory team did before the TC7 came out. Has anyone done a TC7 arm upgrade on the TC6.2. If so, could you post some photos? Thanks.
http://site.petitrc.com/reglages/ass...ice2015121113/
Destiny RX-10s | CRC XTI-WC | 2016 X1 F1 | SMC Totemic | Team Scream
phatboislim is offline   Reply With Quote
Old 05-10-2016, 08:56 AM   #2507
Originally Posted by phatboislim View Post
Perfect, just what I was looking for, thank you.
glennhl is online now   Reply With Quote
Old 05-10-2016, 09:24 AM   #2508
no problem
Old 05-10-2016, 11:58 AM   #2509
Location: Beneath a rock down by the river. Don't have money for van
Spent some time comparing TC7 setup sheets with TC6.2 ones.
Apart the obvious changes there's some that would help the TC6.2 without changing parts. I see the box setup calls for short camber links all around, lessening roll. I will definitely try that and report back ASAP.
( ͡ ͜ʖ ͡)
30Tooth is offline   Reply With Quote
Old 05-11-2016, 12:26 PM   #2510
Originally Posted by RS_ZACH View Post
Anyone have a roller for sale?
Hi Zach,
if you are still looking for a roller and if you don't bother shipment from Germany, I would have one to offer.
PM me for photos.
Fantuzzi is offline   Reply With Quote
Old 05-12-2016, 11:22 AM   #2511
tazfam2's Avatar
Trader Rating: 39 (100%+)
I have a 2 race old team driver roller for sale. Pm me
tazfam2 is offline   Reply With Quote
Old 05-23-2016, 01:08 PM   #2512
dirt42fan's Avatar
Trader Rating: 135 (100%+)
I have 2 TC6.2 one for USGT and one for VTA. The USGT car is on point. Both have stock set ups under them. The VTA wants to spin out entry to mid corner. I have gone as far as Gold springs up front (since the body and car weighs more) and same results. I am just simply not able to push it like I can my GT car and yet its slower?
Anyone have any thoughts?
"Never apologize for hard racing" Scott Bloomquist
dirt42fan is offline   Reply With Quote
Old 05-23-2016, 06:37 PM   #2513
TC5Driven's Avatar
You might have a bad bearing in one of the rear wheels.
TC5Driven is offline   Reply With Quote
Old 05-24-2016, 06:38 AM   #2514
dirt42fan's Avatar
Sorry, I checked that. Should have said it
Old 05-25-2016, 03:36 AM   #2515
Try the USGT tyres in the VTA car and report back please.
( ͡ ͜ʖ ͡)
Old 05-25-2016, 01:10 PM   #2516
jpx
jpx's Avatar
I had a similar problem with my TC6.2 on high grip carpet using RideRex30.
I tried a lot of setup changes, but nothing really helped.
Finally I used additive on the front tires only on the inside half of the tires. As well the side walls of my tires got glued step by step by regluing the tires quite often.
I don't know, which one of both (half additive or glueing the side walls), but finally the problem was gone.
AE TC7 / 17.5T blinky GT
WRC f-one '016 / 21.5T F1
jpx is offline   Reply With Quote
Old 06-02-2016, 01:45 PM   #2517
dirt42fan's Avatar
Update: it appears it was the cvd. i replaced with DVC and cured.....
Old 06-02-2016, 10:35 PM   #2518
jpx
jpx's Avatar
Front or rear?
Was it broken or you just replaced it by try and error?
Old 06-03-2016, 12:55 PM   #2519
Since the rsd hubs and arms are not available anymore; is there any other c-hub that would work? yokomo BD7 perhaps?
TC7 Tamiya Mini M05 Motiv 17.5 R1Wurks 21.5 FUTABA
irvinew is offline   Reply With Quote
Old 06-03-2016, 01:02 PM   #2520
i'm using TC7 arms and hubs on my 6.1...so far very durable. much more than the 6 hubs that's for sure
