Old 12-03-2015, 12:39 AM   #2386
S_fender's Avatar
Originally Posted by Randy Caster View Post
I am using a Yokomo shock end and spring retainer. For asphalt I run my shocks at 62mm, for carpet I cut about 2mm off the shock shaft and run them at 61mm.
Thanks for the answer.
How do you measure ? From end to end ? Or from hole to hole ?
Sébastien
S_fender is offline   Reply With Quote
Old 12-03-2015, 09:27 AM   #2387
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Glad to help. Those dimensions are taken from end to end.
Old 12-04-2015, 10:07 AM   #2388
Tim W.'s Avatar
Thinking about picking up a TC6.2 cause Amain has them for a great price but does this mean a new kit is coming? Kinda scared to buy one open the box and it be outdated!
Mugen Seiki, AKA, Werks Racing USA, Flashpoint, Upgrade
Tim W. is offline   Reply With Quote
Old 12-04-2015, 10:09 AM   #2389
Metalsoft's Avatar
Trader Rating: 69 (100%+)
Awe man, I looked at it at Amain, and I think it broke.
The front end is about as strong as wet paper mache.
Tamiya TB03 USGT - Custom Carbon fiber Chassis - Magoo Racing Inc....
Metalsoft is offline   Reply With Quote
Old 12-04-2015, 12:27 PM   #2390
Yes, a new kit is coming.
I did the same. 1 week after I bought my 6.1, the 6.1WC came out.
jha07 is offline   Reply With Quote
Old 12-07-2015, 06:44 AM   #2391
I got the Reedy 17.5 1s for this car. Does one gear the same way, around 4 or do they gear a tad lower given the higher rpm in this car?
TC7 Tamiya Mini M05 Motiv 17.5 R1Wurks 21.5 FUTABA
irvinew is offline   Reply With Quote
Old 12-07-2015, 10:32 AM   #2392
John Tag's Avatar
Trader Rating: 42 (100%+)
I have a fully loaded TC6.2 for sale in the For Sale thread. TC6.2 complete minus the Transponder and Receiver. Car, LRP Flow speedo,Servo,Battery and all the needed hop ups,Tuning Has allum front castor blocks,RDS Pistons,Yok Springs,Yeah Fan,RDS Fan mount,Front Gear diff ect ect.. Plus tons of spares. Tagstime@hotmail.com .
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 12-10-2015, 07:06 PM   #2393
TC5Driven's Avatar
Wow everybody must be sleeping on this site. The TC 7 has been introduced!
Check out the associated web site here.
https://www.teamassociated.com/cars_.../Factory_Team/
TC5Driven is offline   Reply With Quote
Old 12-10-2015, 08:15 PM   #2394
tbrymer's Avatar
They created a whole new thread for the new car
CRC - C&C Motorsports - SpeedZone
tbrymer is online now   Reply With Quote
Old 12-10-2015, 10:20 PM   #2395
Svendc's Avatar
yeah, there she is, and i impressed, al the things that i would see changed are updated.
So , also the next season... i stike to AE.
VBC Wildfire D08
AE B5M CE
Svendc is offline   Reply With Quote
Old 12-11-2015, 03:36 AM   #2396
DirkW's Avatar
There you go:
http://www.rctech.net/forum/electric...uring-car.html
Dirk
Current cars: Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Yokomo YR-10F | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): Xray T4'17| Yokomo YZ-2 CA(DTM?) | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 12-11-2015, 12:52 PM   #2397
Lone Drifter's Avatar
Now that the Tc7 is on its way Ive been looking on the Hobby websites and the Tc6.2 is stll pretty much still full priced. Guess Ill still use the 6.0 a little longer
USVTA , USGT and Wheeler
TC7, TC6, T3 11 & 12, and TLR 22-4
Lone Drifter is offline   Reply With Quote
Old 12-23-2015, 12:30 PM   #2398
For anyone holding onto their 6.2 looking for an aluminum chassis I have an Avid chassis with 4 days on it still in very good condition. About a .2mm bow front to back but still sits flat side to side, flattens out fine on droop blocks. One small scuff on the chamfering at the bottom, other than that just worn anodizing from the droop screws. $50 shipped in USA just PM if interested.
Old 12-30-2015, 05:16 PM   #2399
Scottrik's Avatar
Trader Rating: 243 (100%+)
Getting my TC6.2 together as my new VTA ride, a couple questions came up...
Question1: the eccentric cams that adjust belt tension and diff height...MY 6.2 manual lists the part numbers for the old TC5 pieces, the inner and outer sold separately. I'm pretty sure my 6.1 calls out the same pieces. NOW the 6.2 manual I just referenced lists a different part number for the cams AND both the inner and outer pieces are sold all together under one part number. Is there actually a difference with these cams on the 6.2 or are they just packaging the old parts together the way they always should have been?
Question 2: what is the deal with the .5mm shims spacing all the suspension mounts up from the chassis plate. What are these actually doing (other than making service a PITA)?
Question 3: a bit more "general" than the other questions, but what is the effect of raising and lowering the differential relative to the chassis? Trying to get the axles as straight as possible at your "selected" droop setting and ride height, or is there more to this? Differential height is not addressed in any of my setup guides (but then again neither was arm sweep...).
Thanks!!
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 12-30-2015, 05:59 PM   #2400
AE-Reedy
Thanks!!
#1 If I remember correctly the new number has more adjustment range than the older cams.
#2 It changes the hinge pin height which affects the roll centers. basically its part of the set up. We have optional CF ones that are one piece and slotted to slide under the arm mount. Less PITA.
#3 Raising and lowering the diff affects the car under braking and acceleration. You already mentioned getting the bones lining up with the out-drives. When they don't line up it makes the cars attitude change on power and off. For instance we used to run the front diff higher than the rear as it tended to help the car steer a little better out of the corner under power. Now we mostly just run med low front and rear.
Sean Cochran is online now   Reply With Quote
