Old 11-20-2015, 03:52 AM   #2356
Good to know about the tc4 ARM mod.....
bertrandsv87 is offline   Reply With Quote
Old 11-20-2015, 05:01 AM   #2357
wtcc's Avatar
Originally Posted by jha07 View Post
Can you elaborate what the TC5 front arms and steering knuckles and TC4 rear arms and Yokomo hubs change? Does it have to do with roll center?
I am not sure myself, as I didn't measure the changes. I just copied what Randy and Rick revealed in pictures on redrc.
I guess the geometry changed (maybe not the rollcenter in first place) and gets closer to what Yokomo has.
My own experience before was that you can make the car very fast with stock parts, but it was never as smooth and consistent to drive. So after the change it is much better on the long run. Just more predictable, consistent and forgiving. And for us good but normal guys this can easily bring 1-2 seconds on a five minute run.
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 11-20-2015, 06:13 AM   #2358
AM03GT's Avatar
Originally Posted by Svendc View Post
What I have understand is, the tc4 arms in rear are shorter makes de car easier to be stable in turns, but if you use the( ***) (*** ) insert in FR and( ***) (*** ) in RR, you make the car also smaller.... So this has the same effect?
It's a lot of geometry and physics. The TC6 arms i believe are longer so just bringing the inner hinge points to match the total rear width is a small part of the total effect.
a shorter arm will change the shock mounting position on the arm which changes the angle and depending on how much the resting length of the shock which will affect the pre-load necessary to maintain ride height as well as damping properties of the shock. The shorter arm with the same inner hinge points will affect camber change at the hub, speed/re-activeness of the arm to bumps, etc etc etc... i dont think i'm even 5% into what the changes do overall... just to one side of the rear suspension and not getting into how that affects the overall car.
that's part of the magic of tuning, i'm pretty sure 95%+ of us do not have the tools and equipment to actually test an isolated change without making a change in the overall setup.
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 11-21-2015, 02:01 AM   #2359
Svendc's Avatar
So the tc7 will be a total other car. New arms, hubs, other LG steering rack, undepended from floating Servo, new shoks... Improved Swaybar system... I'm exited...
Gtz
Svendc is offline   Reply With Quote
Old 11-21-2015, 07:47 AM   #2360
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by S_fender View Post
Hi Randy,
Can you tell us a little more about your shock's Length ?
Sébastien.
I am using a Yokomo shock end and spring retainer. For asphalt I run my shocks at 62mm, for carpet I cut about 2mm off the shock shaft and run them at 61mm.
Old 11-23-2015, 12:51 PM   #2361
YoDog's Avatar
Trader Rating: 26 (100%+)
A-Main just lowered the TC6.2 price to $369 so the new car should be out soon!
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 11-23-2015, 01:36 PM   #2362
Thanks. Do you have a link to a setup sheet using these changes? Also, is this something that is used on both carpet and asphalt?
jha07 is offline   Reply With Quote
Old 11-23-2015, 01:51 PM   #2363
YoDog's Avatar
I would imagine that the new plastic on the TC7 will bring the TC6.2 up to the modified geometry so it might be prudent to wait for the new parts from AE to be in stock. I would imagine the new arms and hubs will be a direct fit if AE maintains their usual rev release philosophy.
Old 11-24-2015, 10:43 AM   #2364
Svendc's Avatar
question is, would the new car have the same bodypost positions, because i will make at ones, some new body's for this winter and next season these days...
gtz
VBC Wildfire D08
AE B5M CE
Old 11-24-2015, 12:21 PM   #2365
YoDog's Avatar
gtz
If AE sticks to their usual rev pattern, they should be the same as the 6.2. Just the suspension plastics get updated.
Old 11-24-2015, 03:43 PM   #2366
DARKSIDE's Avatar
hum....6.1 and 6.2 are not in the same position....not sure TC7 will match up either
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 11-25-2015, 08:14 AM   #2367
Svendc's Avatar
exatly, if they make changes of the geometrie , it's possible they change also the shocktowers... shocks and rollbars...but do we know that in terms of weeks of months?
VBC Wildfire D08
AE B5M CE
Old 11-25-2015, 08:43 AM   #2368
wtcc's Avatar
http://site.petitrc.com/reglages/ass...yRace20150524/
On carpet it gave too much steering. Otherwise it runs very well
Old 11-25-2015, 01:01 PM   #2369
Thanks!
Old 11-25-2015, 01:48 PM   #2370
Svendc's Avatar
short camberlinks, arms in extreme rear possition, must be a lot of steering indeed. :-)
VBC Wildfire D08
AE B5M CE
