Old 09-01-2015, 08:05 AM   #2221
Originally Posted by sublimize23 View Post
This is actually for the TC6.1 WC but probably applies to all, how much belt tension should there be? My car has some use so the belts are likely stretched a little, but I don't know about how much tension to set the tensioners too.
Tough question to answer; but I would look to your club members for input; aside; you'll know if it is too loose or tight. Going to petitrc off a spec sheet is your best bet.
TC7 Tamiya Mini M05 Motiv 17.5 R1Wurks 21.5 FUTABA
irvinew is offline   Reply With Quote
Old 09-01-2015, 12:19 PM   #2222
YoDog's Avatar
Trader Rating: 26 (100%+)
I can explain what I prefer to do. Question... What class/motor do you plan to run?
That having been asked, you want to run the belts as loose as possible without causing belt skipping. Tight belts cause undue drag on the drivetrain. I usually start at front belt a little tight with the rear tires removed. I then hold the front wheels against the bench and then rotate the spur gear by pushing it with my thumb. The belt should not skip with reasonable force. You can now start to loosen the belt 1 step at a time and repeat the skipping steps as before. (once you get a good feel for how much force to use, this process can go faster) There is no need to tighten down the bearing caps at this point. Just lightly tension the four screws as you will be removing and replacing them frequently, at first. Keep repeating this process until you can get the belt to skip then go back 1 notch. Do the same for the rear and remove the front wheels as not to influence your tension test for the rear. (removing the front or rear tires will help to isolate the area to be tested)
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 09-03-2015, 06:11 AM   #2223
Does anyone have a good set-up and/or starting point for asphalt oval? Our track is low/medium traction asphalt. 200 ft straights / 90 ft corners. The class is 10.5 blinky and rubber tires ... Other than that, no limits. Thank you.
RC4413 is offline   Reply With Quote
Old 09-05-2015, 05:29 PM   #2224
Default TC6.2 Mid Build Question- Need Help
Hello all, I'm a little more than half through the chassis build on my Associated TC6.2 and noticed that after mounting the shocks the shock is quite loose on the upper mount. The lower portion of the shock that snaps onto the ball link is very solid. The blue anodized shock mount seems too small for the mounting hole of the top shock cap. Its almost like they included the wrong shock cap in this kit.
Otherwise my build is going well, I'm looking forward to the electronics install.
Has anyone run into this problem before or am I missing something entirely?
Thanks for the help!
HK500Pilot is offline   Reply With Quote
Old 09-05-2015, 06:18 PM   #2225
JustWill75's Avatar
Send a message via AIM to JustWill75
I'm not sure if this is your first build but shock is supposed to be able to move freely on the mount. After you install the button head screw tat secures the shock, check to see if you can twist a little to the left and right with the button head keeping the shock from popping forward, you want that free movement. Now see if the shock can move up and from that same point, you don't want that movement... take a pic or a small vid so we can see what you are talking about. I do hope I helped a little...
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 09-05-2015, 06:49 PM   #2226
Thanks for the reply. This is not my first build. However, this is my first touring car build in about 6 years. I'm fortunate to have a new track coming to my area and I'm getting involved in racing once again, I couldn't be any more excited to get back into RC racing. I've been flying RC planes since 1979 and helicopters since 1989. I've previously built several 1/12th scale cars and 1/10th trucks and cars.
The shock cap will move side to side like you mention. However, it seems it is so loose that it will rattle. Movement up and down on the mount is very slight, but it is still there. I've never seen a shock so loose on its mount on any of my previous builds or cars I've had. I've double checked the instructions, its all pretty straight forward.
I'll just go with it as it is if this sounds like something normal.
Old 09-05-2015, 07:02 PM   #2227
Default 64 Pitch Gearing Starting Point
Can someone reccomend a 64 pitch gearing starting point for the TC6.2? The car will be used on an indoor carpet track that will be quite large. I will be using a Tekin 17.5 motor.
Old 09-07-2015, 08:32 AM   #2228
JustWill75's Avatar
I always start from a FDR (Final Drive Ratio) of 4.0
100 spur 50 pinion = 4.0
96 spur 48 pinion = 4.0
Then I make adjustments from there depending on the track. The lower the number the more top end you will have and the higher the number the more bottom end you will have.
Old 09-08-2015, 07:37 AM   #2229
Thanks for the reply, this information is very helpful.
Old 09-09-2015, 02:09 PM   #2230
bkfawcett's Avatar
Thumbs up 6 cent battery strap!
2 #64 rubber bands hold strong and allow easy battery swaps:
Team Associated TC6.2 Touring Car-img_2671.jpg   Team Associated TC6.2 Touring Car-img_2672.jpg   Team Associated TC6.2 Touring Car-img_2673.jpg
bkfawcett is offline   Reply With Quote
Old 09-09-2015, 02:39 PM   #2231
JustWill75's Avatar
The simplicity is what makes it cool...... But I'm afraid the rubber bands resistance or want to snap back may cause a lil tweak in you chassis. You may want to take the wheels off and place the car on a flat surface like you setup board or a glass. Tap on one end of the car front or rear and see if the car rocks. Do this with the battery in it..... If it rocks then you are tweaked and this can make your car harder to drive.
Old 09-09-2015, 03:25 PM   #2232
samething I was think
starrx is offline   Reply With Quote
Old 09-09-2015, 09:12 PM   #2233
bkfawcett's Avatar
Default 6 Cent Battery Strap
Yep! So, I'm going to check for tweak. It makes sense that the pull of the rubber bands may pull on the chassis, but I've been looking for something a little more elegant than Velcro or tape. [rant] I recall that my TC3, TC4, TC5 each had a simple strap or bar holding a sub-c stick pack in place with a couple of body clips, but coming up with a way to hold down a simple brick shaped lipo is still an afterthought... I'll try the new AE strap, but so far this car is running great this way for me! [/rant]
Old 09-09-2015, 10:12 PM   #2234
DARKSIDE's Avatar
HI
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 09-09-2015, 10:13 PM   #2235
DARKSIDE's Avatar
http://www.teamassociated.com/parts/details/31645/
The AE strap works great. I use it on all 3 cars. Never lost a battery either
