Old 07-17-2015, 06:47 AM   #2176
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Coming back to onroad after 5yr hiatus, anyone have a pic with shorty packpack like to see wow its mounted.i do have a idea on what i want to do
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-17-2015, 09:59 AM   #2177
Originally Posted by Castradamus View Post
I started from the outer most hole testing. Got comfortable with position 'C' and it seemed to give me consistent traction. I ran a modified version of a setup that Christian posted on the RSD thread. Here is mine:
Front:
Piston 3x1.15
Oil 32.5wt
Shock position OOXO OXOO
Arms: RSD "c" position
Suspension mounts:
FF: ( ..)(.. )
FR: ( ...)(... )
0.5mm under all suspension mounts
Spool
Yokomo Blue
Short camber link. 0 outside 2 mm inside
WB 1mm short from std.
Rear:
Piston 3x1.15
Oil 32.5wt
Shock position OXOO OOXO
Suspension mounts:
FR: ( . )( . )
FR: ( . )( . )
0.5mm under all mounts.
Yokomo Black
1000cst rear diff
Short links 2mm inside 1mm outside
Click Here for original
Thanks for the help....it'll get me at least started. A few more questions though.
What sway bars are you using?
Does your steering hub hit the NEW sway bar link before the steering locks out?
daveb is offline   Reply With Quote
Old 07-17-2015, 10:36 AM   #2178
CristianTabush's Avatar
The sway bar links should act as your steering stips, but in case you want more throw you can replace the sway bar ball cups that come in the arm kit and use the std ones. In Place of the ball stud on the ball cup that attaches to the arm, use a set screw so you can attach the original ball end and pop it into the original sway bar ball. This will allow you to get a little more steering throw and some guys say it keeps the ball from popping off.
Personally, I tun AE Tc5 style sway bar mounts with xray 1.3 front sway bar in front and Spec R R1 1.2 rear bar in the back.
On springs, our new definitive spring set is awesome. For all of you that are converted to Yoke springs, these are worth a shot.
CristianTabush is offline   Reply With Quote
Old 07-17-2015, 12:39 PM   #2179
Thanks Christian! I'm just getting around to putting it all together and I haven't even thrown it down. I was assuming it'll still have enough steering with the links stopping it.
Old 07-17-2015, 12:44 PM   #2180
Yes, should be enough steering. The car rotates better, so it tends to need less lock.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
Old 07-18-2015, 11:09 AM   #2181
NutDriver's Avatar
Trader Rating: 15 (100%+)
Christian,
Can the springs you listed by used with the standard Associated rod ends and spring cups? I thought that Reflex went to 20mm springs for some reason a while back.
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 07-18-2015, 05:00 PM   #2182
SWTour's Avatar
I've been struggling w/ my TC6.2 since I got it. Don Natale from Team Associated rebuilt things on it for me, and I was still struggling, mainly because I'm just NOT an on-road guy...so I'm learning the NEW car and driving 4wd cars in general. I have a couple old HPI Pro2's that I've driven (and still use for VTA), but at my last couple races, I made great headway into the 6.2 and my driving... It's starting to get FUN!
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 07-18-2015, 05:11 PM   #2183
bertottius's Avatar
Trader Rating: 19 (100%+)
[QUOTE=SWTour;14100971]I've been struggling w/ my TC6.2 since I got it. Don Natale from Team Associated rebuilt things on it for me, and I was still struggling, mainly because I'm just NOT an on-road guy...so I'm learning the NEW car and driving 4wd cars in general. I have a couple old HPI Pro2's that I've driven (and still use for VTA), but at my last couple races, I made great headway into the 6.2 and my driving... It's starting to get FUN! [/QUOT
You have any of the suspension mods on it or did you go box stock?
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 07-18-2015, 06:39 PM   #2184
SWTour's Avatar
from what I can tell, it's still box stock w/ team mods (prior to new part mods) --
Running med - med/high grip asphalt w/ GT Bodies and the Gravity R/C (USGT Spec) tires.
Joe Myers
Old 07-18-2015, 09:36 PM   #2185
Originally Posted by NutDriver View Post
Christian,
Scott
They will need a bigger diameter bottom cup, at least. most people switch to Yokomo shock adjustment nuts and lower eyelets and spring perches. Our aluminum spring cups will work ok with the 14.0mm diameter springs, but they do get a little iffy on the bigger 14.2. This is a really worthy mod though, even if you just want to run Yokomo springs and HPI silvers for asphalt.
Additionally, we have our 6.2 springs, which are 13.5mm (now a lot of people are using the X Gear springs, which are also 13.5mm id) will bolt right on, but work better with our aluminum spring perches because they have a -1 offset, which allows you to use the standard turnbuckle eyelets AE switched to on the 6.2/6.1 and get you low enough ride height.
We only went to 20mm springs with our lowered towers on the TC6.1
Old 07-19-2015, 12:18 AM   #2186
Default Motor goes to part speed if you hit the steering too hard.
I just bought a used TC6.2, looks to be in excellent shape. I haven't run it yet, just getting it ready. Tonight I put on some DCV's in the front. The chattering at full lock went away. However, tonight I noticed if I turn to full lock very quickly with the motor at full speed, I get a click. Then occasionally the motor will actually "catch" and start running slower until I let completely off the throttle, hit the brake, and hit the throttle again, then it goes to full speed again.
I'm at a loss. I ran it and looked at the belts very closely, they are not rubbing. I also lowered the steering EPA so that the front steering is not even close to full lock. It still behaves the same. I also looked very closely at the steering and it's not hitting anywhere. I got my tried and true TC6.1 out and it does not act funny at all. I'm getting ready to start replacing electronics since I have spares of everything.
So has anyone else had this issue and if so, how did you fix it.
Thanks,
Glenn
EDIT: Update, I figured it out. First I plugged in another steering servo and the problem went away. The servo I plugged in was a slower standard SAVOX and I wanted to still use the faster Futaba 9451. So I plugged the Futaba servo into my TC6.1 and it worked fine. So I replaced the speed control (I had a spare Tekin RS). It worked fine with my faster Futaba servo, so I'm good to go except for a couple of hours of my life I'll never get back!
I'm going to replace the capacitor on the Tekin Speed Control I took out. I'm hoping that's all it is and I'll keep that as my spare.
glennhl is offline   Reply With Quote
Old 07-19-2015, 04:13 PM   #2187
engr673's Avatar
Trader Rating: 17 (100%+)
Anyone looking for an as new as it gets TC 6.2(15 minutes on it) please send me a PM. I have one for sale at the link below, you won't be disappointed! thank you!
Team Associated TC 6.2
engr673 is offline   Reply With Quote
Old 07-21-2015, 03:34 AM   #2188
20 SMOKE's Avatar
So what is the preferred body now,mostly carpet running but will go out doors
Jamie W
Old 07-21-2015, 07:23 AM   #2189
wtcc's Avatar
Pf MazdaSpeed 6 (not Gx) for Indoor and more technical Outdoor tracks and the Pf LTCR for Outdoor are the most used.
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 07-21-2015, 10:30 AM   #2190
I Remember a post about removing the screws that hold motor mount to spur gear bulkhead that it helps with flex on bumpy tracks or something has anyone tried this and what are the benefits
tbamsey is offline   Reply With Quote
